Old 10-13-2010, 02:58 PM   #226
LEEVON
LEEVON's Avatar
Re: Project "Popeye"
Originally Posted by Detroit3100 View Post
great build. Did you ever switch to the LS1 oil pan or are you still running the truck pan? do you have any motor mount pics...my 6.0L seems to sit low, espically the pan when I have it air'd down.
Yes, I did have to switch to the LS1 pan, the truck pan was about 4" below the front crossmember and hit the ground first. The LS1 pan is about 1" above it, just perfect. It was kind of a fiasco though.. I bought a pan cheap, cleaned it up I discovered that it was badly broken in two places. I took it to a boat shop and the guy was supposed to call before doing any repairs to let me know how much $$$. Well he called after it was done and needed $250. I told him to keep it! But he said he'd let me have it for $150 cash...so I took it home and then realized the repairs were crappy. I'm hoping it doesn't crack or leak.
I'll get some engine mount pics for you.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-13-2010, 05:10 PM   #227
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I saw this thread a while ago; when you first got it. I thought I was subscribed, but I guess I wasn't. I just found it again. You've been busy.
I thought about doing the trailing arm set up on my '51. Looks like that is working out great for ya.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 10-13-2010, 09:44 PM   #228
LEEVON
LEEVON's Avatar
Yeah, the arms worked out great. I think the ride will be worth it. I've been through your build a few times too, I love the s-10 bed, still considering doing that in Popeye.
Old 10-13-2010, 11:55 PM   #229
nickp51chevy
I thought about doing the S-10 bed but I decided not to. The pix of that on my build thread are from Bluejeep; he put the S-10 bed in his.
Had;
Old 10-14-2010, 09:39 AM   #230
67cheby
67cheby
67cheby's Avatar
the s-10 bed thing had my curiosity up, so i had to check that out , i think that would be killer on POPEYE, i like it with the tubs in it in case you ever run wider wheels
67cheby is offline   Reply With Quote
Old 10-14-2010, 10:18 AM   #231
LEEVON
LEEVON's Avatar
I might have to do some small tubs, looks like I've only got 1/2 tire clearance at ride height. Surely an S-10 bed can be found cheap.
Old 10-14-2010, 10:03 PM   #232
BlueJeep
BlueJeep's Avatar
Yes, I did the s10 bed floor in mine and I like it. I first had the tubs, but cut them out later so that I could haul plywood in the bed. Here's the pics again:
Mock up:
Since mine's a long box, I had to add to the front:
Wheel tubs filled in:
And how it looks currently:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 10-14-2010, 11:47 PM   #233
LEEVON
LEEVON's Avatar
Ooops, got you mixed up with nickp51chevy. Bed looks really good!
Old 11-05-2010, 11:07 PM   #234
breezy
Jumped over here to see what popeye was. Looking good. I have a 52 big truck in hidding I want to put a tube frame under with a suicide front and chop with a straight 6 or even better a straight 8.I just sold my 52 Daily driver. Metric subframe with v-8 auto, ps pb and cruise. You should have seen peoples faces when I'd blow by them on I-44. I'll try to post a pic or 2.
Not trying to jump on your thread here. Looks like you have a nice little place to work on your toys also.
breezy is offline   Reply With Quote
Old 11-06-2010, 10:06 AM   #235
LEEVON
LEEVON's Avatar
Oh man that's a cool truck!
Old 11-06-2010, 09:17 PM   #236
breezy
Thanks I have my moments.Yours has me itchen to start my tube frame truck. I really wish I could sell the 71. I'm just getting tired of it. The only reason I want TBI is something to do more or less. 700r4 should be put together this week. I may try to get it in next weekend.
Old 11-21-2010, 09:39 PM   #237
LEEVON
LEEVON's Avatar
The transmission is finally in for good and the Hurst shifter cleaned up real nice after a soak in oxalic acid and some soda blasting then a little grease. It shifts nice and smooth, not sloppy like I expected. I also mocked-up the brake booster and decided that I'm going to move it up to the firewall. The brake arm hits the clutch arm and also there is no room for exhaust on that side.
I spent some time yesterday modifying the center crossmember to make room for the driveshaft. Luckily I had some 1/4" plate and was able to cut a section out and fab a hump. I have a driveshaft being made next week.
As you can see I have a large but manageable to-do list left for the chassis! This week is brake lines...
Old 11-21-2010, 10:07 PM   #238
FnLow69
FnLow69's Avatar
looks good man....
FnLow69 is offline   Reply With Quote
Old 11-21-2010, 11:23 PM   #239
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Looking good leevon.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 11-22-2010, 10:20 AM   #240
67cheby
67cheby
67cheby's Avatar
looking good man
Old 11-22-2010, 12:10 PM   #241
bjcaldwe
bjcaldwe's Avatar
Nice. Ive got one of those boards in my garage too, but not as much marked off.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 11-30-2010, 12:53 AM   #242
fishnixon
fishnixon's Avatar
Nice thread Leevon...Great work. I'm learning as I lurk on the site. The under frame power brake setup and your exhaust situation is an eye opener. I have a bone stock 55 second generation big window shortbox and plans are formulating, but reading and doing research are going to pay off. I'll keep lurking, and you keep posting pictures...deal? You're son is going to love the truck when it's done!
Rob
fishnixon is offline   Reply With Quote
Old 12-11-2010, 11:42 PM   #243
52 Rat
52 Rat's Avatar
The build project is coming along good. Looking good.
For those that are looking for a small wheel tub, check out the trailer fender at Tractor Supply or Northern Tool. I was looking at them this weekend and they would be easy to cut and weld into the bed sides. I think I'm going to use the trailer fenders.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 12-13-2010, 03:08 PM   #244
Wvgearhead
Leevon, where are you sticking your gas tank. I see your air tank is where most mount there gas tank.
Wvgearhead is offline   Reply With Quote
Old 01-14-2011, 05:58 PM   #245
LEEVON
LEEVON's Avatar
Thanks everybody!
I'm going to leave the tank in the cab, it doesn't bother me to be there. If it was more of a street rod or highly finished I might consider moving it but for now it's good.
I've let this thing stall out...lost my sister on 12/13, she was 27 and had three kids so priorities changed a bit. It's funny how things come into perspective and become irrelevant at times (like one's hobbies). Slowly getting back to "normal" though, and I'm going to try and do SOMETHING, anything on the truck this weekend to get the fire back. It's been really freakin cold here too and I'm a big baby about cold so that's not helping either.
Old 01-14-2011, 06:02 PM   #246
67cheby
67cheby
67cheby's Avatar
cant wait to see progress, and im am truely sorry for your loss, God bless you and keep your head up, have gone through more than my share of the same kind of losses i understand
Old 01-14-2011, 06:23 PM   #247
LEEVON
LEEVON's Avatar
Thanks Mike. I remember that day I came by (10th) vividly for some reason, it was a fun day with my daughter and a nice to visit with you.
I'm getting back to it though, starting with that brake booster bracket. Just need a little motorvation.
Old 01-14-2011, 06:50 PM   #248
67cheby
67cheby
67cheby's Avatar
lets get crack- a -lakin
Old 01-14-2011, 10:01 PM   #249
bjcaldwe
bjcaldwe's Avatar
Sorry to hear about your sis. There has been a lot of that over here in the last two months. I understand about the cold. Y'all definitely got it worse. I look forward to your updates and hope you get your mojo back.
Old 02-04-2011, 05:17 PM   #250
dougminton
dougminton's Avatar
looks good. subscibed
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
