#26 |
VA72C10
![]() Join Date: Mar 2008
Re: [PROJECT] Laidout53 Part II
very nice!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#27 |
Well i got the frame rails capped and the tie rod notches cut. only got on welded in. heres the pictures for today.
![]() ![]() ![]() Smoothed... ![]() ![]() Tie rod notch welded... ![]() Smoothed... ![]() ![]() let me know what you all think Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 10-25-2010 at 05:35 PM. |
#28 |
VA72C10
Looking good as usual! Keep at it! You're making nice progress.
#29 |
What was I thinking?
![]() Posted via Mobile Device
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
#30 |
subscribed!! keep up the good work and thank you for building your crossmember, i am gettin gmore courage to do the same... on the next project.
Build Thread - Papa's truck build up |
#31 |
Thanks guys...hopefully I can get the other notch in tonight.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#32 |
low n' slo
![]() Join Date: Mar 2009
looking good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#33 |
You definitely have the 'touch' for fabbing. I like it!
#34 |
Well i worked on it last night and today. Got the other tie rod notch done and the welded and smoothed. All the joints will get plated later. Today I got the front crossmember in and made the upper A-arm mounts still need to make some gussets for them.
Anyways here are the pictures... ![]() ![]() ![]() ![]() Crossmember tacked in... ![]() ![]() ![]() ![]() Lower arm bolted up... ![]() ![]() The upper arm mounts...(forgot to take progression shots) ![]() ![]() ![]() ![]() ![]() Spindles and rotors on... ![]() ![]() What do you think? Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 10-25-2010 at 05:36 PM. |
#35 |
VA72C10
Looks great!!!
Keep up the good work....because the sooner this is done the sooner you can get back to the 69 ![]()
#36 |
67cheby
![]() Join Date: Sep 2008
wow..amazing job
#37 |
you can work on my truck anytime you want !! great job !!
#38 |
Man thats looking killer!
#39 |
Thanks guys
#40 |
Junior Member
Awesome work as usual!
#41 |
Commander Taco Bello
tivo activated
#42 |
Heres tonights progress, got the gussets made and welded for the upper arm mount. Also got started on the front clip/radiator mount.
Heres the pictures... ![]() ![]() ![]() ![]() ![]() ![]() Justin
#43 |
Maybe one of these days I'll attempt a full frame build. You make it look so easy.
#44 |
Well i got to work on the frame last night a today, got the bag mounts made up front. Had to get 2" drop spindles, so i got those installed mocked up the rack to make sure it would fit. Also got the frame gussets cleaned up and tack where there suppose to go.
Anyways heres th pictures... bag mounts ![]() ![]() ![]() ![]() ![]() ![]() ![]() rack mocked up ![]() ![]() And the frame gussets tack on ![]() ![]() ![]() ![]() Justin
#45 |
vw guy & now c-10 guy
looks awesome man. really like the frame gussets, function and style
#46 |
67cheby
WOW.... this rocks !!
#47 |
I love the detail aspect w/the gussets....
#48 |
67cheby
its going to be a shame to cover up that frame with a body !!
#49 |
I don't no whether to be motivated or discouraged.
#50 |
I had the same thought this morning when I checked the update....
