Old 11-13-2010, 06:44 PM   #1
80sbc
Talking Djm flip kit
Just installed a djm flip kit will drop the front in the morning. How many coils should i cut to level the truck out? Thanks in advance.
80sbc is offline   Reply With Quote
Old 11-13-2010, 06:47 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Djm flip kit
As a general rule,... I use this formula:
1/2 coil = 1" of drop.
Keith
Convert to disc brakes.
Old 11-14-2010, 11:36 AM   #3
cor86
Re: Djm flip kit
I also used the DJM flip kit and found that 1/2 coil, along with DJM's 3" spindles, will make it level. Hope that helps.
cor86 is offline   Reply With Quote
Old 11-14-2010, 01:12 PM   #4
mooseknuckles
mooseknuckles's Avatar
Re: Djm flip kit
I cut off one coil and 3" drop spindles for a slight rake.
mooseknuckles is offline   Reply With Quote
Old 11-14-2010, 10:52 PM   #5
1LowToy
Re: Djm flip kit
Not to hijack a thread. Can I go 3/4 coil? Any pics? I have a few days off for TG and I think I can do the drop then as I think I'll have my goodies in order.
1LowToy is offline   Reply With Quote
Old 11-15-2010, 12:48 AM   #6
SuperNova22
Re: Djm flip kit
Is that the 5" DJM flip kit? Did you need to install c-notches?
SuperNova22 is offline   Reply With Quote
Old 11-15-2010, 01:49 AM   #7
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Djm flip kit
I'd say go the full coil from the stock coil but any more the coils will fall out of the spring pockets when you lift the front of the truck up
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-15-2010, 07:56 AM   #8
jasonroman
jasonroman's Avatar
Re: Djm flip kit
x2?
how hard/easy was install?
no need to take bed off for this kit?
jasonroman is offline   Reply With Quote
Old 11-15-2010, 12:44 PM   #9
80sbc
Re: Djm flip kit
Its the 5" flip kit and i didnt have to take the bed off or c-notch the frame. It was pretty easy. The hardest part was grinding off the old bump stops.
Old 11-15-2010, 02:25 PM   #10
3r!c84
Badass
3r!c84's Avatar
Re: Djm flip kit
Get 3 inch drop spindle and cut a coil
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-15-2010, 06:15 PM   #11
Silence86
Silence86's Avatar
Re: Djm flip kit
is the front lowered at all?
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622
Silence86 is offline   Reply With Quote
Old 11-15-2010, 06:19 PM   #12
80sbc
Re: Djm flip kit
The front is stock height
Old 11-15-2010, 10:43 PM   #13
lilpoindexter
lilpoindexter's Avatar
Re: Djm flip kit
Did you measure the drop on the rear with the flip kit?
lilpoindexter is offline   Reply With Quote
73-87, djm, djm flip kit
