06-16-2003, 05:02 PM | #1 |
putting power steering on 71 250-6
hey knew to the board and was wondering if you guys could help me out with a quick ?
I am trying to put power steering on a 71 250-6 already have the box but the only brackets I can find are 77 bolt on the block fine but none of the pulleys line up the later model water pump is longer and the balancer needs changed wich is were the proplem lies will the later model balancer work and how the hell do I get it off as I see no holes for my puller? |
06-16-2003, 06:43 PM | #2 |
your best bet would be to find a car/truck with the complete setup and get it all.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
06-18-2003, 08:31 AM | #3 |
I did the switch also............... really simple, be you might have to notch the bumper bracket, because the box will hit it............. You have the wrong brackets and pump.............. try getting one off a 68-72 six cylinder............. after those years things start to change for the worst as far as interchangebility
71 GMC Stepside 250/350 Turbo better known as "Fred Sanford 77 240 Mercedes Benz 92 300E Mercedes Benz 70 Firebird 400 85 600 Ninja |
06-19-2003, 02:56 AM | #4 | |
