Old 12-09-2010, 11:04 AM   #1
dyno
dyno's Avatar
Just completed; '80 K20 4x4 Orange Metallic
I've been working on this build for a year and just finished it up. I've had this truck for almost 20 years and have primarily used it for ranch work and hunting. I broke a valve spring on a hunting trip last year and one thing led to another. Here's some old pics I dug up:
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 12-09-2010, 11:09 AM   #2
dyno
dyno's Avatar
Re: Just completed; '80 K20 4x4 Orange Metallic
So here we go...I rebuilt the top end of the motor, started detailing things out in the engine compartment. Then I got a wild hair and said "I need a winter project." Figured it would be a great project to do with my 12 year old boy.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 11:19 AM   #3
dyno
dyno's Avatar
Well, all that engine compartment detailing was a waste of time. Time for frame off! The old gal was full of rust and bondo so the only original sheetmetal I kept was the raw cab. All other panels and bed came off donor rigs. Stripped the whole truck down to bare metal.
I probably should have gotten a different cab as well due to all the rust around the window channel. What a pain that was to fix.
Epoxy primed everything, then filler primer, block sanded twice:
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 11:19 AM   #4
spudz
spudz's Avatar
looks good so far!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-09-2010, 11:22 AM   #5
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Looks great....you have a really nice garage too with lots of space & light to work!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-09-2010, 11:23 AM   #6
dyno
dyno's Avatar
I spent weeks looking at metallic orange colors, finally decided on Nissan A17 Lemans Orange Metallic used on the 350Z. Went with Valspar 999 base and Valspar clear. I had huge problems with fisheyes in the clear so I hosed on 8 coats, cut and buffed whole rig.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 11:30 AM   #7
dyno
dyno's Avatar
Well, here she is all put back together. I always like the 73 egg crate grille so I modded the core support to accept it. I also changed out the round headlights it had for the rectangle style.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 11:35 AM   #8
dyno
dyno's Avatar
I wanted to use some tasteful diamond plate inside so I did the rockers and dash insert. I always hated those door speakers so I went with the stock dash speaker and AM FM AC Delco radio.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 11:39 AM   #9
dyno
dyno's Avatar
Well, that's about it. It was a great project my son and I. He is all fired up now and wants to get started on one of his own!
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 12:19 PM   #10
Jonboy
Slots go on anything!
Truck turned out great. Definitely a different look with the 73-4 grille and square lamps, but I dig it. Good work.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-09-2010, 01:17 PM   #11
dyno
dyno's Avatar
Thanks. Yep, the grill swap was a huge pain but I like it too. I had to swap out the upper radiator grille panel and changed the hood latch from cable type to outside latch. Also had to fab brackets to mount the grill to. The headlight swap was easy as all the mounting holes were there.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 01:50 PM   #12
lycominghunter
That is awesome. I've got the same truck...your's is just a lot nicer! HA. Great work!
lycominghunter is offline   Reply With Quote
Old 12-09-2010, 02:12 PM   #13
manimal
manimal's Avatar
That truck is gorgeous! Nice work.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 12-09-2010, 02:45 PM   #14
kikkegek
kikkegek's Avatar
wow! nice looking truck!
good work! must be nice to have the space to do a build like that!
kikkegek is offline   Reply With Quote
Old 12-09-2010, 05:44 PM   #15
87 chevy silverado
how did you do the diamond plate on the tail gate?
nice truck
87 chevy silverado is offline   Reply With Quote
Old 12-09-2010, 05:50 PM   #16
dyno
dyno's Avatar
I just glued a piece of hardwood to the back of the aluminum plate with PL400 subfloor adhesive, and screwed it on from the backside with wood screws thru the stock holes. It sits in there perfect and is very secure. The tough part was modding the trim around the tailgate latch.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 06:11 PM   #17
87 chevy silverado
i was thinking on doing that one day.thanks for the info.
Old 12-09-2010, 06:31 PM   #18
nbpro
Nice work love the Orange Metallic
nbpro is offline   Reply With Quote
Old 12-09-2010, 06:39 PM   #19
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice job! That truck looks really nice. That is a nice shop too! I also spy'd a nice K5. Is that a project of your too?
Ryan
1969 Chevy milk truck
Old 12-09-2010, 06:53 PM   #20
Dalaigh
Canadian Trucker
Dalaigh's Avatar
That colour is the exact same colour I painted my Vstar only I put Candy Apple Red in with the clear.
Truck looks great! What size tires are on it?
Dalaigh is offline   Reply With Quote
Old 12-09-2010, 07:14 PM   #21
dyno
dyno's Avatar
Yep, I did the Blazer about 10 years ago. I sold it this summer. Pretty hard to part with, but got big bucks for it to help ease the pain!
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-09-2010, 07:15 PM   #22
dyno
dyno's Avatar
My favorite size; 255/85r16
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 12-11-2010, 11:31 PM   #23
russgt
russgt's Avatar
Beautifull truck! Who made the front bumper? I know that warn use to make one like that but no longer does. I have been searching for one for a while
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 12-11-2010, 11:35 PM   #24
sandnuriz
sandnuriz's Avatar
Looks great
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 12-12-2010, 09:33 AM   #25
justpball
justpball's Avatar
Very nice build! Truck looks great!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
