11-16-2010, 10:05 AM | #176 |
Re: late build thread...LOL
he made the holes in the sheetmetal kikke , you probably can drill them in the mdf and then put them against the door and drill trough
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
11-16-2010, 10:12 AM | #177 | |
Hope this make my question clear.
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
11-16-2010, 02:35 PM | #178 |
Drill holes in the door and reach in put nuts on the back side
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
11-16-2010, 02:52 PM | #179 | |
11-17-2010, 04:33 AM | #180 |
he man! I really love your midconsole and the way it curves.
Does your 91 model also have the floor heater in the middle under the dash? if so, what did you do to it when placing/building the mid console?
11-17-2010, 06:45 AM | #181 |
yea it does, if you look close right below the steering wheel in the pic you can see a little notch that lets the heat out...it is about 6in long and 3/4 in high
11-17-2010, 07:44 AM | #182 | |
That was what I was planning on doing myself, if I start in this idea. I would really like very much to build something like this, but I have the 4WD-selector in the way. But since I almost never operate this handle, I am considering building a mid-console over it, with a hatch that moves the display away, so the handle can be accessed.
12-08-2010, 12:47 AM | #183 |
Loving what your doing with it, giving me some crazy ideas for the crew cab/short box project. Keep up the great work. Can't believe I missed this till now...
Any idea what your WMS to WMS is front and rear on this thing? I want to compare with my 1 ton single wheel measurements to see if I can manage a 20x12 in the rear. And skinnys up front. thanks!!! |
12-09-2010, 05:07 PM | #184 |
thanks for all the info on your crewcab. i really like the stance so i ordered a djm 5/7 lowering kit, eagle alloy 225's in 20x8.5 255/35r20 and 20x10 295/30r20,
my wheels should arrive today at discount tire. what size rear tire are you runnng on your suburban? |
12-10-2010, 09:43 PM | #185 |
Devillusion what is WMS? Burb has 285/30/20 all the way around...
12-10-2010, 09:44 PM | #186 | |
12-10-2010, 09:57 PM | #187 | |
I know the two versions of the 14 bolt full floaters (3/4 and 1 tons) were either one of two options...67.5 on normal dually and single wheel versions, and 63 on the cab and chassis duallys. Just not sure what the half tons measure.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
12-10-2010, 10:00 PM | #188 |
i can check for ya bro!
12-10-2010, 11:28 PM | #189 |
Thank you very much.....I appreciate it ALOT!
I know this will cause you some work, so I truly do appreciate it. Unless someone out there has some information to save him some labour? Again...TY!!!
12-10-2010, 11:39 PM | #190 | |
the two sizes on the axelhousings themselves and two types of hubs the combinations give the 4 trackwiths you do need to change the mounting for the backingplates of the brakes if you mix and match them http://www.pirate4x4.com/tech/billav...ble/index.html has a LOT of info on the subject
12-11-2010, 12:45 AM | #191 |
I thought that too, but I had a few people "set me straight" that there was only the two, I always thought there were three as well. I thought there was one that the front tire of the dually lined up with the outer rear, one that lined up with the center of the rear duallys (mine), and one that the front lined up with the inner (typical dually with box/fenders).
Guess I should be starting a new thread...this one is starting to hijack a little to much....sorry. Either way I would appreciate the half ton measurements...
12-11-2010, 12:46 AM | #192 |
Think I passed this beast on the I-10 in Pensacola a little while ago, more like a month or so ago now, I was going west you were going east. Was it you? lol
12-11-2010, 09:05 AM | #193 |
Yea i was headed to panama city for a car show, I live just across the line in bama.
12-13-2010, 12:42 PM | #194 |
low n' slo
man how did i miss this one! sick burban man..do you have a pn for that knuckle in your steering shaft? i have an extra crossmember that im thinking of getting chopped but i was wondering how much the knuckle was too. thanks!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-17-2010, 07:50 AM | #195 |
I got it out of a van in the junk yard, most vans have them, and a lot of the newer trucks do to
12-17-2010, 11:50 AM | #196 |
Cool man, I'll have to catch you next time you're out this way to check this thing out
12-19-2010, 02:48 PM | #197 |
Cool burb, man!! The attn to detail is first rate...the lace on the side stripe is really cool, I've seen that before and I know it's not easy...Keep it up!!
12-31-2010, 09:23 AM | #198 |
The lace is skulls...LOL
here are my new shoes!
12-31-2010, 10:12 AM | #199 |
Lookin good!! Love the 225's!!!! 20x10 on all four?
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
12-31-2010, 11:55 AM | #200 |
67-72 parts collector,…
Wheels look great!
What size tires?
