Old 10-07-2010, 11:53 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
starter solenoid wires- which goes where?
I recently bought a 72 Chevy c10 with no engine and trans. I am slowly getting it back together with a 30 and 700r4. I can't remember for the life of me which wire go where on the starter solenoid. It has been years since I swapped engines in a truck without an HEI. Since I didn't do the swap, I didn't pull everything, and the P.O. didn't label anything. THere is a yellow and a purple wire...Which goes where on the solenoid ?!?!
WIDESIDE72 is offline   Reply With Quote
Old 10-07-2010, 11:58 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: starter solenoid wires- which goes where?
on HEI purple wire goes to terminal closest to block...idk bout yellow wire, thats for coil? i think
John
1999 Toyota Tacoma 4x4
Old 10-08-2010, 12:24 AM   #3
GruntMoanCough
GruntMoanCough's Avatar
Yellow to "R" terminal and purple to "S" terminal.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 10-08-2010, 12:14 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
Thanks guys for the quick help. That's two less wires I have to try and figure out!
Old 10-08-2010, 12:34 PM   #5
GruntMoanCough
Maybe this will help you figure out a couple more, thanks to member boundstaffpress..... http://farm4.static.flickr.com/3645/...c2a8064d_o.jpg
Old 10-08-2010, 04:27 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
DEFINITELY!!! I thought I was going to have to break down and spend $30 on an assembly manual just for this!
Old 10-08-2010, 04:51 PM   #7
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
If I remember correctly, you can do away with the yellow wire altogether. Just need the purple for cranking power. I don't have yellow on either of my rigs and they are both HEI.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-08-2010, 05:57 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Sounds to me like he does not have HEI.
The S terminal is normally closest to the block, and the R is normally to the outside. But, not always.
Old 12-10-2010, 10:43 PM   #9
johnyoung
I also need some help. Bout fried my wiring harness today. I believe we hooked the yellow and purple both to the inside and it sent power back through the outside harness. Good part is the motor did start. Which wire goes to the new hei dist we installed on my 73 model 454 installed in my 72/67 hybrid - we call her "El Diablo" as she has fought us all the way. Hope to start a build thread next week. HELP an old hillbilly out
johnyoung is offline   Reply With Quote
Old 12-10-2010, 10:57 PM   #10
darthwall
just do what longhorn said those 2 wires to go on the starter
darthwall is offline   Reply With Quote
Old 12-11-2010, 12:18 AM   #11
Hubscrub
Cruzin
Hubscrub's Avatar
you don't use the yellow for the dizzy on an HEI because you don't get a full 12volts that it needs. You need to run a wire from your ing. unfused port for power the hei.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-11-2010, 11:50 AM   #12
Shyguy
Junior Member
Shyguy's Avatar
Just to add a little, I ran a wire like you described, but I put an in-line fuse in it.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-11-2010, 02:06 PM   #13
Hubscrub
Cruzin
Hubscrub's Avatar
thanks i forgot that/ i always run fuses on mine to
Proverbs 3:5,6
Old 12-11-2010, 02:23 PM   #14
oldblue1968chevy
Hmm
Po Installed HEI, and its a red wire goig to it, but NO idea where it goes to...?
John
