11-16-2010, 03:14 AM | #1 |
73-87 1-ton capacities
didnt reall know what else to call the thread but whatever, i was wondering of the 73-87 1 ton which year would be the heaviest duty? (like payload capacities, axles, etc.)
1998 Ford Ranger FX4, 3.0 V6, 5 speed manual 1999 Ford Explorer, 4.0 V6, 5 speed auto O.D. 2005 Chevy Colorado, 3.5l inline 5, 4 speed auto 2001 Gmc sonoma 4.3l V6, 4 speed auto soon to have 1981-88 k30 |
11-16-2010, 05:04 AM | #2 |
Re: 73-87 1-ton capacities
They may have gotten a bit heavier towards the end of their run, but I would think most 73-87 1 tons are about the same. They can vary within the model year from about 8,800GVW to over 10,0000GVW. In most 1 tons I believe you will find the 14 bolt full floater rear end.
Interestingly my '73 3/4 ton is only rated 800lbs less than my '79 1 ton. (8200 vs 9000 GVW)
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. Last edited by Number21; 11-16-2010 at 05:05 AM. |
11-16-2010, 06:52 AM | #3 |
Next!
Some of the "1 ton" Cab and Chassis actually are 11,000 gvw.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
11-16-2010, 08:08 AM | #4 | |
Charlie Daniels w/ a Tq Wrench
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
11-16-2010, 11:01 AM | #5 |
Arrived on a Pale Horse
As mentioned the above factors all affect the capacity of the truck. If you're looking to Max capacity you'll have to roll with a dually.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
11-16-2010, 07:51 PM | #6 |
I have a 1991 V3500 same as an 86 k3500 (same idea as the burbans/k5s)
dana 60 front 14 bolt rear factory overload springs. its set for 9900# EDIT its an SRW truck and came with 16's not 16.5's
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 and some K5's lol Last edited by iroc12valve; 11-16-2010 at 07:52 PM. Reason: additional info |
11-16-2010, 08:44 PM | #7 |
I'll have to check the GVWR on my 78 K30 Dually tonight when I head out to the gym, it's pulling DD duties right now
11-16-2010, 09:43 PM | #8 |
well i was most likely goin with a crew cab dually 4x4, preferably an 80s one because i like the style of the front end and interiors, and at some point i was goin to upgrade the rear to a dana 80 with 3 inch wide leafs, probly do that after i get the money to do a diesel swap
11-27-2010, 04:51 PM | #9 |
Checked mine, it's 10,000 GVWR
11-28-2010, 01:58 AM | #10 |
Hello,
My '84 K30 cab-and-chassis has a GVW of 11,000 lbs. For what its worth, the cab-and-chassis frames were slightly heavier than the K30 pickup frames (either SRW or DRW pickups). Channel height was the same, but rails were approximately .030" thicker. They also have a heavy crossmember for the rear cab mounting, as opposed to the individual mounting brackets found on the pickup frames. Just something to think on... Hope this helps, Joe Posted via Mobile Device |
11-28-2010, 07:15 PM | #11 |
A friend of mine just bought a 79 GMC High Sierra 35 1 ton ex firetruck and I dont know much about it other than it was GVWR at 27,500!!! We have no idea why just thought it was very odd
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
11-28-2010, 07:56 PM | #12 | |
If that was true, he would have to have his CDL's to even drive the truck.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 11-28-2010 at 07:58 PM. |
11-28-2010, 08:40 PM | #13 | |
11-28-2010, 08:45 PM | #14 |
My 88 2wd crew cab dually come from the factory at 10,000 pound, but I think I read that the crew cab dually 4x4 was 11,000 from the factory. Then I have a 79 k-30 single wheel that is 9200lb, which is ironicly the same as my old truck I had, an 82 3/4 4x4 with the semi-floater 14 bolt...
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out) 1986 ElCamino (needs motor) 1970 C30(future service truck for my ag-equipment repair business) 1970 CST10(parting out and partial donor for the '70 C30) 2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto |
11-28-2010, 08:52 PM | #15 |
My rollback is made on a 1977 GMC Motor Home Chassis...GVW is 14,500
19.5 wheels and 4 wheel disc brakes..454 th400 and gets the job done..truck is 7,000lb's empty..Have been on the scales at 16,800 loaded.. frame is doubled from factory over rear axle. Last edited by 70BLAZERX2; 11-28-2010 at 08:54 PM. |
12-10-2010, 01:00 AM | #16 |
very nice rollback you got there, like the color and stacks
12-10-2010, 09:50 AM | #17 |
12-10-2010, 06:15 PM | #18 |
Next!
Is that the one off CL for $900.00?
12-11-2010, 11:35 AM | #19 | |
Awesome link!!!
1976 K20 350/205/465 - "Big Red" 2010 VW GTI 2013 VW Touareg |
12-11-2010, 03:44 PM | #20 |
yea i checked that place the other night and found ALOT of usefull info on there
