67 short fleet
I have owned this truck for about 16 years. I have been collecting parts for it since i bought it. I thought I was going to save a bunch of time and money and purchace a different cab. Well after blasting it, it is as just about the same as what I already had.
My current task is to get the cab done and then I will do the frame next. The truck will get a drop I think 4.5/6 range. More pictures to come soon. Last edited by 67_ShortFleet; 09-09-2011 at 12:43 PM. |
Re: 67 short fleet
so what's the plans?
R.I.P. Killer 71 10/26/07 |
Re: 67 short fleet
My plans are to re-use the current 350, just freshen it up. I may put a 700-r4 in it. I have a factory air unit for it, but I will convert it to a sanden compressor. I plan on 2.5 inch dropped spindles and 2 inch lowering springs in front. The rear will get 6 inch lowering springs and maybe c-notches. A rear mounted gas tank will also be installed. The fuel filler will be in the bed floor or under the taillight. The color will be gold and white with all the trim. I hope to find a buddy bucket seat for it. When I can afford it, it will get some nice wheels.
Tot Roddin'
Re: 67 short fleet
Looks like a great build, best of luck!
Just so you know... a c-notch will not be required for a 6" drop in the rear. If you have any questions about the install of the 4.5/6" drop kit, just let me know. I've posted the entire install in my build thread in my signature (Blank Slate).
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: 67 short fleet
looks like a nice truck to build it reminds my of my first truck (1972 chevy SWB fleetside).
1991 1500 longbed: my daily driver ![]() 1937 chevy 2dr sedan. dads project ![]() |
Re: 67 short fleet
more pictures. The tailgate is a $20 rust free dented to hell swap meet buy. I still have alot of work to do on it. I may cut it accross the top and drill out the spot welds so I can straighten it easier. This is the (better) cab. It has been stripped and sand blasted and epoxy primed. The last picture I am marking to cut the outer floor extension out to get ready for a new one.
Re: 67 short fleet
Should be a great project. Note on the 700R4, I'm running a 400sbc with decent cam and 3.05 gears. The vehicle lugs on the highway (60-65) at 1300-1400 rpm. I think this due to the cam not being able to produce power at that rpm. I'll be puting in 3.73s to get it up to 1700 where it runns a hole lot better. Good luck
69 C10 "Torchered" RC Crawler Nut http://www.dorkstarproductions.com/orcrc.com/forum/ |
Re: 67 short fleet
more pictures
Re: 67 short fleet
more pictures.My son having some fun with my patina pump. I cleaned up the firewall a little. I also added a 72 throttle pedal.
Re: 67 short fleet
A pillar work being done.
Re: 67 short fleet
More patch panels. I found this bike while looking for truck parts at the junk yard. We have already had our $5 worth of fun with it.
printing is my trade
Re: 67 short fleet
Subscribing to what looks like a really fun build!
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184 |
Re: 67 short fleet
Long time with out progress. I've gotten back to it over christmas break. I installed the cab support and the inner a pillar/kick panel bottom. I got some firewall patches from a board member. Nice stuff!
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
Re: 67 short fleet
More pictures. I also got a drip rail from the same donor. The one on this cab got hit and it looks like it would be easier to replace than straighten. Firewall panel is removed and patch is close to the right size.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! Last edited by 67_ShortFleet; 12-31-2010 at 12:44 AM. Reason: spelling error |
#15 |
Re: 67 short fleet
nicw work that looks good
#16 |
VA72C10
![]() Join Date: Mar 2008
Re: 67 short fleet
Very nice work so far! Looks to be a nice build!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#17 |
Re: 67 short fleet
I made some more progress today. The A pillar is almost done. I picked up this ebrake handle and cover for $5 this fall. It is a little early for a wiring harness, but I found this on craigslist. The price was right so I bought it. It looks like quality item.
#18 |
Re: 67 short fleet
wow nice job i gonna need to get me a cover as well
#19 |
Tot Roddin'
Re: 67 short fleet
Nice progress Matt!
Also... do I see a new 'white' gas pump between the garage doors in one pic? Did you get rid of the patina pump?
#20 |
chevy runs deep
Re: 67 short fleet
Sweet look'n good
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
#21 |
Well I made some more progress. Firewall and floor patches are welded in. Just a few pin holes to fill. I cut out the rusty B pillar and have the patch close to fitting. What a PIA to fit all this stuff.
#22 |
Re: 67 short fleet
your doing great and it amazes me that you only have one page!
#23 |
Under Construction
Re: 67 short fleet
subscribed... keep up the great work!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#24 |
Re: 67 short fleet
I really like the light Idea, you can never have enough light. The truck is really coming along and its great to see your replacing all that rust with new metal. Look forward to seeing more pictures.
JRBECK64 |
#25 |
Re: 67 short fleet
i second jrbeck64
