#1176 | |
Still Learning
Re: LFD's low buck truck build!
#1177 | |
Still plays with trucks
http://67-72chevytrucks.com/vboard/s...32#post4339032
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#1178 |
Well I hope to have some pics up this weekend (My wife has the camera up in Tahoe) so I can show some progress. The motor is in and bolted and I started working on the routing of the engine harness tonight before coming inside and ordering the chassis harness to re-wire the truck. I figure I will get the EFI harness routed and the computer mounted under the dash then I can figure out were I can best fit the chassis harness. I went with a EZ-Mini 20 harness for the chassis to try and save on some space plus I used on in my son's 51 F1 and really likes it. I also ordered a box of dyna-mat for the engine side of the firewall to help cut down on even more noise and heat. Then I ordered one sheet of their 1/4" thick deadener for the bottom of the hood. I want the truck to sound good from out side but nice and quiet inside. I still need to figure out my gauges but I think I will go with the set I listed before after I get every thing else done. Well that is about it for tonight, hope to have some real progress done by Sunday.
Kevin LFD Inc. |
#1179 |
Well it was a cold but productive day. I de-wired the truck of 95% of the stock wiring that was still in good shape but with all my added circuits it was creating a mess. Also I ended up mounting the computer and TCM in the same location the the old fuse box was located. I also spent a good amount of time making sure I would not have a fire wall full of wiring like I did before, that always bugged me. Now with the Dyna-Mat and no visible wiring nightmare I might be so ashamed to open the hood at our local car shows. I had to make a bracket to hold the ECU and TCM so I made one that lets both items slide in place for easy removal if needed and the bracket is screwed to the ribs of the brake booster support.
It is hard to tell but the motor is slid back about 2.5" to better tuck into the firewall with the tall truck intake. I had it at first in the bolt in location and it just looked wrong. I will continue the Dyna-Mat lower on the firewall once I get another box. I thought 12 sq ft would have been enough but I guess not. I made a bracket that the new pedal bolts to and then I welded the bracket to the booster support ribs so it is secure and still easy to remove the pedal with a few allen button heads. As soon as the new harness shows up and I have time I can start to focus on getting the interior back together but for now I am going with the bomb went off look! Kevin LFD Inc. |
#1180 |
Once the next box of Dyna-Mat comes in I will finish the interior and exterior of the firewall, it should really help on engine noise. I had most of the interior done before and it was night and day from with out it but I wanted it even better this time around. I know some may not like the look of it on the engine bay side but I think it will look really clean when it is finished up and all reassembled. I figure most new cars have foil backed deadener in the engine bay so why not give it a shot.
Kevin LFD Inc. |
#1181 |
What was I thinking?
I don't think the foil look will look that bad. For a driver it's more about comfort. If it was going to be a full blown show then i'd paint it. Definitely going to be a nice truck!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
#1182 | |
Kevin LFD Inc. |
#1183 |
i seen a couple of trucks where they put the turbo(s) under the bed right behind the cab or trough the bedfloor
its a little more complicated oiling the turbo (you either need a seperate tank and pump system or line from the engine to the turbo and a scavangepump back to the sump ) and some more piping to get the air to the intake , but you can use stock type exaust manifolds . and it saves a lot of heat under the hood and in the cab , it doesnt lag as some nay sayers want you to believe
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#1184 | |
Kevin LFD Inc. |
#1185 |
Restoration Virgin!
Hey Kevin....what's the gauge over the driver side AC vent....did ya put it in some kinda housing??....I really loved this build when you first did it....now it's gonna be even nicer!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#1186 | |
Kevin LFD Inc. |
#1187 |
Found it! http://67-72chevytrucks.com/vboard/s...d.php?t=260607
PS I used the green florist foam because resin does not melt it like regular foam. Kevin LFD Inc. |
#1188 |
think the lightblue high density foam stays together too with epoxy , they use it for surfboards , eazy to test just poor a little acceton on it
#1189 |
Life, Be In It.....
![]() Join Date: Oct 2003
Good to see your talents at work again. Looking really nice.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
#1190 |
Restoration Virgin!
Thanks for the follow-up Kevin...that's a very cool idea!!!
#1191 |
![]() Join Date: Apr 2008
Maybe I missed it in an earlier post but can you explain the reason you modified your brake pedal?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#1192 |
Maybe you could use some thinner and remove the stenciling from the dynamat under the hood? That would make it look more like OEM.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#1193 | ||
![]() Kevin LFD Inc. |
#1194 |
Glad to see you back. Looking good.
#1195 |
you might be able to get the ink of the dynamat with some thinner or aceton and a rag
#1196 |
Well the rain stopped for an hour or so and that gave me just enough time to get a few more things done. I put on the new Alt. that has the correct plug for my harness as well as both exhaust manifolds off a 2000 or so camaro and they fit great! I was worried about the drivers side O2 sensor but it fits with about 1/8" gap to the engine mount/frame stand. The engine wiring is now hooked up and I am happy with how clean I was able to route everything. I still need to get a hold of the filter box and intake set up for a stock 05 PU then I can start figuring the rest out. I will be re-doing my brake lines so I can get rid of the factory proportioning valve and run a summit racing one instead that will mount to the firewall brace just below the booster and really clean things up. Then the battery will be on the drivers side and I will re-use the LS power cables and block. Almost forgot I was also able to get the park/neutral trans switch installed along with my Lokar linkage.
I was wanting to get more done but with the rain I started off in the shop trying to get things cleaned up but that only lasted so long before the "Squirrel" popped up and I was side tracked and tried my hand at some air brushing. I have only used my air brush kit once before when I was painting my Dads M.B. last year so even know I need hours of practice I was happy with the results. So does anyone here have the stock air box and intake set up for a 04-07 truck that want to sell? Kevin LFD Inc. |
#1197 |
The rest of the pics for now.
Kevin LFD Inc. |
#1198 |
Some more progress! I am very happy with how the stock air intake and clutch fan are working out. It has taken lots of mods to make it all fit and look right but in the end it will be worth it. I still need to finish off the drivers side of the fan shroud so it is sealed to the radiator and pick up a 45* tube to hook up the Mas-air sensor. Then cut and re-crimp my A/C lines, finish wiring things up, re-do my brake lines to the new proportioning valve and fuel lines. More progress to come shortly.
Kevin LFD Inc. Last edited by Rokcrln; 01-08-2011 at 06:04 PM. |
#1199 |
Still Learning
It looks like you know what you're doing for sure! Man you are making this install look way too easy. I think someone has been doing his homework. Keep up the good work!
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 01-09-2011 at 02:44 AM. |
#1200 |
Time for the Cold Air Box set up. I will be blocking off the passenger front fender and pulling air through the radiator support. I started to build the box tonight and it is turning out well. The entire box assembly and the Filter box will be held in with plastic push-in style expansion screws. The bottom edge of the box will have a push on welting of some sort to finish off the seal but as it is right now very little engine compartment air would get in. Here are a few pics of the start of the system.
Kevin LFD Inc. |
