Old 09-15-2010, 04:19 PM   #76
69CST-V
69CST-V's Avatar
Re: 1952 chevy home made frame build
Subscribed.....Nice work
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 09-16-2010, 12:32 AM   #77
Thinkblue4 Evr
Thinkblue4 Evr's Avatar
Thanks Guys we have been laggin the past few weeks because of football and Dad going back to work instead of working on the truck every day. Thanks its a boost when people say things like that about what we have built.
1952 Chevy 3100
1986 Corvette Suspension
350 motor Tune Port Injected
Thinkblue4 Evr is offline   Reply With Quote
Old 09-19-2010, 08:48 PM   #78
Thinkblue4 Evr
Connected the shift linkage to check for clearance. Also mocked the front part of the exhaust up to check for clearance.
1952 Chevy 3100
Old 09-23-2010, 03:07 PM   #79
Cautrell05
The whole package looks really good. Only things I see that need attention are put a couple small gussets behind the upper control arm mounts as menioned. An unsupported slab of 1/4 inch will eventually sag in. Wont take much to make it bulletproof. The other thing I see being a problem is the rear diff is rubber mounted on the back and solid mounted on the front. That will put added stress on the front of the case and the front mount and eventually one of them will crack. other that that, A+ on the rest. keep it up.
Nick
Cautrell05 is offline   Reply With Quote
Old 09-23-2010, 11:27 PM   #80
Thinkblue4 Evr
Well we have gusseted the plates now with the addition of the upper shock mount. And in the back we will eventually change the rubber bushings to neoprene which will help. The original Batwing that came out of the corvette had a huge crack in it which was probably because of the same reason.
1952 Chevy 3100
Old 10-03-2010, 08:16 PM   #81
Thinkblue4 Evr
We havent done much but put the clip on to check Our stance and to see if we are going to need spacers on the front. I say yes but dad says know I think the wheels need to come out about an inch he says they are perfect. I dont know what do you all think? Pics. Also what we have been working on to stay organized.
1952 Chevy 3100
Old 10-03-2010, 08:55 PM   #82
NONHOG
NONHOG's Avatar
Cool cabinet! Maybe do a write up over.....http://67-72chevytrucks.com/vboard/f...splay.php?f=89
As far as wheel track? Can we see a straight shot? From what I see it looks goos as is. But a lower front shot might make it easier to tell.
Nice truck !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 10-12-2010, 11:35 PM   #83
Thinkblue4 Evr
Well we havent been knockin stuff out like we were but we got the front accessories onto the motor and ordered some parts. We also got rid of the smog pump and moved the alternator in so it would clear the inner fender. We found an electric site called larryselectric and they have a tpi wire harness without all the smog stuff and security features the corvette had and it also came with a new computer to run the new harness that should be here Friday. heres some pics.
1952 Chevy 3100
Old 12-01-2010, 07:49 PM   #84
jevonniespapi
Great work!
jevonniespapi is offline   Reply With Quote
Old 12-08-2010, 12:30 AM   #85
hotrodjoe1952
hotrodjoe1952's Avatar
Please tell me you have a blue print of this frame because I want to purchase a copy of it for my build!
hotrodjoe1952 is offline   Reply With Quote
Old 12-08-2010, 01:34 AM   #86
Bugeyev8
Bugeyev8's Avatar
great project and nice work, I think you did a great job so far but....I see one issue that I think could be better, I know its been said before but I think the upper a frame brackets are not safe, its not ideal to but weld a plate like that and put that type of stress on it, I would take some plate and make some triangles and run them on the inside of the frame on each side of the plate you have there...please don't be offended by this ..I just see a potential issue
Bugeyev8 is offline   Reply With Quote
Old 12-09-2010, 01:10 AM   #87
Thinkblue4 Evr
Unfortunately we do not but we did use the measurements from the original frame from the Factory Assembly Manual. Personally i do not know of any plaes that would have a blueprint computer document.
1952 Chevy 3100
Old 12-09-2010, 01:13 AM   #88
Thinkblue4 Evr
At this time I do not see a need to put these gussets in as it is not going any where and we are not near the time to drive it yet so we have time to include them in the bracketry.
1952 Chevy 3100
Old 12-09-2010, 01:19 AM   #89
Bugeyev8
Bugeyev8's Avatar
I understand...keep working on it !!
Old 12-09-2010, 01:23 AM   #90
Thinkblue4 Evr
Thank You for the concern.
1952 Chevy 3100
Old 12-13-2010, 02:49 PM   #91
71'tahoe
71'tahoe's Avatar
Exellent build! Where did you get your measurements for the front suspension? Are the lower control arms mounted level front to rear with the ground? What angle are the uppers mounted on? Are they mounted parelle with the frame rails? I did what you are doing! Im thinking of c-4 vette suspension in my 58' truck. Just curious as where you got your measurements. Some guys wont come off there demensions for nothing..lol
Greg
71'tahoe is offline   Reply With Quote
Old 12-14-2010, 01:23 AM   #92
Thinkblue4 Evr
Greg
Hey Greg
When we were taking the suspension pieces off of the corvette we took measurements of where things were supposed to be mounted. So everything is mounted like it was on the corvette. We will be putting the same suspension on my Grandpas 59 project that he just bought after we finish our current project.
1952 Chevy 3100
Old 12-14-2010, 05:40 AM   #93
franky69c10
chevy runs deep
franky69c10's Avatar
Look'n good
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 12-15-2010, 03:21 PM   #94
71'tahoe
71'tahoe's Avatar
Hey Greg
Thanks! I didnt know you had a corvette to strip parts off of. I was thinking maybe you bought the parts already off. I appreciate the reply!
Greg
Old 01-09-2011, 09:44 PM   #95
Thinkblue4 Evr
I have not posted anything in a long time and we have gotten a little bit done. Also Dad got laid off again so the tempo should pick up again like it was. We finished the rear section of the floor and prepared the cab to be removed and we mocked up the rear cab mounts along with the battery bracket. We built a cab dolly and had the cab on it in a couple hours. We also acquired many parts over christmas and one of them was the wiring harness. We made the plate for the fuse boxes and computer to attach to and mounted it in the cab.
1952 Chevy 3100
Old 01-09-2011, 09:49 PM   #96
hotrodjoe1952
looking good, i love the craftsmanship of this build
Old 01-10-2011, 12:02 AM   #97
BC Toy chest
BC Toy chest's Avatar
Wow, I'm impressed, she looks good.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 01-10-2011, 01:21 AM   #98
Kim57
Kim57's Avatar
Looking good guys.
Kim
Kim57 is offline   Reply With Quote
Old 01-17-2011, 01:27 PM   #99
hotrodjoe1952
from the center of the rear wheel to the center of the front wheel what is your dimensions on the wheel base? i love this build, i have a great idea on how to do mine now so thank you very much.
http:www.electronicshve.com
Your Ultimate Choice for all your Electronic need's!
Old 01-17-2011, 08:37 PM   #100
Thinkblue4 Evr
Thank You to everyone for the positive feed back
The wheel base is the stock 116 inches.
1952 Chevy 3100
