12-11-2010, 10:50 AM | #76 |
Re: 1960 GMC Suburban
Fast work.
http://s1299.photobucket.com/user/jb...23904108567829 |
12-13-2010, 02:10 AM | #77 |
Momma Tried.
How did you polish them?
Ross 1980 c10 4x4 project (Sold):http://67-72chevytrucks.com/vboard/s...d.php?t=377155 1999 F-150 4x4 (DD) Saving up for a 64 17 and loving it. |
12-13-2010, 10:18 AM | #78 |
1960 GMC Burb
DUDE...I can't believe you are making me do this on this forum. I APOLIGIZE to all in advance that I have to use the following 4-letter word in such a loving and family oriented forum thread. It is a F.....F......FO.....Fo...Ford.( ugh... there I said it) .. F@&d product called Automotive Bright Metal Cleaner 8A-19522. The can I have is literally 30 years old, I got it in a bulk purchase from a closing gas station. But, it seems that they still sell it. Also, I have heard that once you remove the rust you should then apply then apply (F@&D) Super Seal Anti-Corrosion compound (F3AZ-19515-SA) to prevent it from rusting further.
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
01-10-2011, 10:37 AM | #79 |
1960 GMC Burb
Well it has finally happened ! the paint has started ! This is the first under coat of white. A light sanding then the 2nd coat will go on and then the gloss coat. Then the sides can be final sanded for paint. The roof of these monsters is a real job to fine sand without leaning on, and denting in the roof.
My brother-in-law did a great job of block sanding the roof. Hopefully in the next couple of weeks this puppy will be done enough to come home.
01-10-2011, 11:24 AM | #80 |
Looks KILLER, Before you put your cowl vent back on, fix a piece of heavy plastic or metal screen to the underside. This will keep debris from filling your vent plentum or let moisture built up with the debris.
Jake
01-10-2011, 03:13 PM | #81 |
Just here to tinker
Alright! I've been waiting to see some paint on this girl! Can't wait to see the rest of the pics.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
01-10-2011, 10:37 PM | #82 |
1960 GMC Burb
thanks for the tip on the screening. Great idea.
I've been Sooo waiting for paint that I have been eying the roller and brush sitting in the garage.
01-10-2011, 11:32 PM | #83 |
Kit and others,
You can fix the screen to the intack with clear rubber silicone. That way you can peel it off if needed with put worring about it. Turn it upside down fit the screen spot the silicone and let dry (mash the screen down into the silicone to get a good grip, use several spots. put the silicone inthe groves if the bars so you won't see it from the top side.
01-11-2011, 06:59 AM | #84 |
Redneck Hillbilly
Just found and read through your thread here. Very cool 'burd, and the history makes it even better. Glad to see you are still sticking with the project over the years. I will be with the others waiting to see how it all turns out.
01-12-2011, 12:21 AM | #85 |
1960 GMC Burb
Got the hood with final primer and ready for paint. Should be able to put both coats and clear on tomorrow...I hope..I hope....I hope...
01-12-2011, 08:59 AM | #86 |
Kit,
IF your going the OEM route, DON'T forget that on the front nose cap there is a approx. 2" wide section around the headlights that gets painted white, no matter what the rest of the colors are. I had to make myself a note to remember this on my two tone.
01-13-2011, 12:17 AM | #87 |
1960 GMC Burb
Where is the white paint ? Mine has original chrome rings as shown below and there wasn't any white paint around the headlights. So I'm a little confused, which isn't out of the ordinary for me anyways...
01-13-2011, 12:26 AM | #88 |
Rollin' Old Skool
i believe he's referring to the area around the grill support and front fenders:
01-13-2011, 01:52 AM | #89 |
Double check that. That detail may be a Chevrolet only thing, and may not apply to GMC's. Looking good!
01-13-2011, 09:44 AM | #90 |
OEM4Me.
You are correct, I was mistaken on the white trim. I was reading another thread and they were talking about a true OEM restoration paint job. THE GMC'S DID NOT HAVE THE WHITE TRIME RING - SORRY
01-13-2011, 11:35 PM | #91 |
1960 GMC Burb
No Problem !. Thanks anyways as all information is worth knowing and looking into.
01-18-2011, 12:27 AM | #92 |
1960 GMC Burb
Making paint progress. Over the weekend got the roof final paint and clear coat. Also, some of the small pieces are finished.
01-18-2011, 12:30 AM | #93 |
1960 GMC Burb
Today we got the dashboard painted and a lot of prep work around the windshield. Did find some stress cracks around the windshield area that need attention before paint and the new windshield installed.
Piece by piece it get's closer to getting finished.
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT Last edited by KIC; 01-18-2011 at 12:32 AM. |
01-18-2011, 12:46 AM | #94 |
Just here to tinker
Great progress man! Keep it up!
01-18-2011, 09:04 AM | #95 |
65 suburban vortec 5.3 bagged
very nice!!!!!1
02-05-2011, 02:28 AM | #96 |
1960 GMC Burb
Well...it is slowly dragging on. Not much done that shows. a little more metal work and decided to fix a cracked hinge are on the rear door before paint. Of course, just as we are ready to paint, the weather turns to crap and work piles up for everybody.
Hopefully painting the hood tomorrow and the area around the windshield so I can get that reinstalled. The hood really looks nice..can't wait for paint !
02-05-2011, 02:32 AM | #97 |
the hood does look clean!
02-05-2011, 01:26 PM | #98 |
Wow the chrome rings look real good. I thought they were painted on mine now I'll have to try and polish them. Here are a few pictures of the dash and headlight rings on my 61. As you can see the dash looks to be a flat charcoal (black with a touch of brown). And, my headlight bezel seem to be painted but may be too far gone to polish, but Ill try anyway. Im learning a lot from your build. Thanks !!!!
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
02-05-2011, 02:07 PM | #99 |
Awesome Suburban man. I wish I had something my Dad passed down to me, that would be so cool.
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
02-05-2011, 03:04 PM | #100 | |
Senior Enthusiast
