Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-12-2011, 01:16 PM   #1
BIG KRIS
BIG KRIS's Avatar
5/7 drop
Is there anyone running a static drop on the track,and if so how well does it work?
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 01-12-2011, 11:12 PM   #2
regan wilson
regan wilson's Avatar
Re: 5/7 drop
Are you talkin bout a 4-7 swap ?
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 01-13-2011, 12:22 AM   #3
BIG KRIS
BIG KRIS's Avatar
Re: 5/7 drop
Like a djm or belltech drop kit.
Dropmember
Old 01-13-2011, 12:52 AM   #4
leddzepp
Moderator
leddzepp's Avatar
Re: 5/7 drop
I have a 5/6.5 drop....real close to what you are seeking. Look at the last page of my build thread for pics. I have a C-notch on order, as there is only about 1" of clearance between the rear axle and the frame.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-13-2011, 10:30 AM   #5
kpeztruck
kpeztruck's Avatar
Re: 5/7 drop
I tried the 3.5/5 drop, and never got the truck to hook at the track. Mind you, I was trying to run low to mid 5's in the 1/8 mile. The spring rate was to high to transfer weight from the front, and the rear spring rate did not allow proper anti-squat to work properly. I ended up using Moroso trick springs and QA1 stocket star R series front shocks, and Koni double adjustable coil-overs, and an anti-rollbar from Bickel in the rear. Good luck, let me know if I can help you in any way. I should have an front suspension at market in the next couple months that will help considerably with weight, geometry, etc. Thanks Paul
kpeztruck is offline   Reply With Quote
Old 01-13-2011, 11:56 AM   #6
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Re: 5/7 drop
I'm running a 4 1/2 f and 6 1/2 r cpp springs right now and pulled consitant low 1.6 and a hand full of high 1.5 60' on drag radials. I'm gonna change that setup though as soon as i can was fighting traction problems all of the time out.
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 01-13-2011, 02:57 PM   #7
BIG KRIS
BIG KRIS's Avatar
Re: 5/7 drop
Thanks for the replies.I wanted to know more out of curiosity than tryn to do it. I got a chasis shop DSR RACECRAFT that my buddy owns that's gonna hook me up.
Dropmember
Old 01-13-2011, 06:23 PM   #8
Wild83C10
Wild83C10's Avatar
Re: 5/7 drop
Keep in mind everyone that replied is probably running trailing arm rear suspension and your running leaf springs. A big difference between the two.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-13-2011, 07:10 PM   #9
BIG KRIS
BIG KRIS's Avatar
Re: 5/7 drop
Gotcha. I really just asked out of curiosity. I'm most likely gonna stick with a four link and maybe still do a front crossmember.
Dropmember
Old 01-14-2011, 09:20 AM   #10
kpeztruck
kpeztruck's Avatar
Re: 5/7 drop
Sorry, I did not realize what year truck, and with what rear suspension we were talking about here. The 4-link will work well for you. I know a lot of S10 guys are running Cal-tracs with success for stock type suspension set-ups. I have never seen anyone run Cal-tracs on full size trucks. I seem to always assume we are talking about trailing arm rear suspension. LOL. Paul
Old 01-17-2011, 10:41 PM   #11
72MARIO
72MARIO's Avatar
Re: 5/7 drop
I have Cal-Tracks the truck hooks up really well. I bought there axel flip setup. Had to put in a CPP heavy duty C notch. for travel
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-18-2011, 12:54 AM   #12
3r!c84
Badass
3r!c84's Avatar
Re: 5/7 drop
5/5 drop no wheel hop problems with the flip kit
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-18-2011, 04:35 AM   #13
BIG KRIS
BIG KRIS's Avatar
Re: 5/7 drop
Nice!
Dropmember
Old 01-18-2011, 02:39 PM   #14
vincentgkirkland
vincentgkirkland's Avatar
Re: 5/7 drop
4.5 / 7 cpp no big problems Name:  Picture008.jpg
Size:  24.8 KB vince 72super10
72 SUPER10
vincentgkirkland is offline   Reply With Quote
Old 01-19-2011, 12:46 PM   #15
team39763
Re: 5/7 drop
There's tons of guys down here in the RGV with dropped trucks that seem to hook just fine. These guys are low, like 5/7 and lower. Them RGV trucks are some of the quickest in the state. They have lots of videos on youtube and on the Edinburg track website.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 01-19-2011, 10:30 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 5/7 drop
My 73 works decent foot braked 1.67 60's. It wanted a light duty 3 leaf pack. the 7 leaf heavy half set was junk.
Old 01-19-2011, 10:59 PM   #17
3r!c84
Badass
3r!c84's Avatar
Re: 5/7 drop
you feel it hook up more with 3 leafs? ive got the stock 4 (or 5 leaf) i wanted to take 1 out and see if the truck will squat alittle more at the line. and hook up a little better
-00 Saturn 5spd
1/4:13:90
Old 01-19-2011, 11:34 PM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 5/7 drop
I went from the 7 leaf to the light duty 3 leaf pack and both shocks pointing forward at the same time... im not sure which made the biggest change but Cal tracs recomends the lightest leaf pack you need to hold up the vehicle.
Old 01-19-2011, 11:35 PM   #19
3r!c84
Badass
3r!c84's Avatar
Re: 5/7 drop
what caltracs are u using? and i cant find anytype of slaper bars or caltracs for a flipped rear end
-00 Saturn 5spd
1/4:13:90
Old 01-19-2011, 11:52 PM   #20
team39763
Re: 5/7 drop
Calvert makes the caltracs in a flipped version. I'm told that they also sell their split monoleaf setup for these trucks too.
Old 01-20-2011, 12:10 AM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 5/7 drop
Its one of these two. I cant recall the part # of mine?
http://calvertracing.com/cart/ymm.ph...2FC1500+PICKUP
Old 01-20-2011, 12:13 AM   #22
3r!c84
Badass
3r!c84's Avatar
Re: 5/7 drop
the 3204 one. but its outa my price range
-00 Saturn 5spd
1/4:13:90
Old 01-21-2011, 03:14 AM   #23
Super73
Super73's Avatar
Re: 5/7 drop
Why do people still think squating is better for hooking??
Right and why is that? Depending on where you instant center is set, you could be inducing a lot of antisquat. With the stored energy of the light leafs, antisquat puts the tire in to the ground, adding force on that tire.
What hole are you running the caltracs in?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-22-2011, 02:00 AM   #24
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 5/7 drop
Bottom hole, with a half turn Pre load. I need to scale it and see how outta square it is
