Old 01-27-2011, 11:30 PM   #51
my4by2
my4by2's Avatar
Re: 1977 Chevy K30 Crew Cab Build
Here's a shot of my rear bumper after they cut it out & installed the new reverse LED lights. It's still not re-powdercoated, so it'll look a lot better when it's finished. Also I have new taillight covers for it with all LED bulbs like the rest of the truck which will look really good.
my4by2 is offline   Reply With Quote
Old 01-27-2011, 11:40 PM   #52
MTCK
MTCK's Avatar
Looking good! Bend that tie rod and you have bigger problems....
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-27-2011, 11:43 PM   #53
my4by2
my4by2's Avatar
BTW - now they get to start on installing a late model Blazer fuel door into the rear right side of my bed, modifying the bed floor to clear the filler neck & then filling the two exisiting fuel filler holes already in the bed. Truck is a LOOOOOOONG way from being finished, but still hoping for June!
Old 01-28-2011, 12:02 AM   #54
my4by2
my4by2's Avatar
Finally here's a shot of the unfinished front fuel tank crossmember. Don't mind the yucky looking bed underside - it'll be getting stripped & re-undercoated at the same time the cab does. And yes, the rear axle is still awaiting powdercoat since not everything back there is finalized...
Old 02-08-2011, 08:37 PM   #55
my4by2
my4by2's Avatar
Here's a pic of the freshly powdercoated wheel - loock frakin' SICK!!! Sorry the polished beadlock ring isn't installed - will upload one with it later.
Old 02-09-2011, 02:04 AM   #56
Gordonr1973
Home Built '87
Gordonr1973's Avatar
TOTM winner when done!! Pretty unique!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-09-2011, 12:27 PM   #57
johnnypop
Wow! Your truck is exactly what I am looking to build for my next big project, It's coming together great!
johnnypop is offline   Reply With Quote
Old 02-09-2011, 12:40 PM   #58
Dalaigh
Canadian Trucker
Dalaigh's Avatar
I was wondering what my rims would look like black with the polished ring, I would love to see that. Great looking build
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 02-09-2011, 01:56 PM   #59
jitteryguy
GoatLube Experss
jitteryguy's Avatar
the truck is look'n good ! if ya ever make it to Qalat look me up, I'll buy ya dinner at FOB Lagman.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-10-2011, 09:24 PM   #60
my4by2
my4by2's Avatar
Thanks for all the great comments!!! The shop building it is closed this week for the King of the Hammers race, so nothing's getting done unfortunately... Hopefully will have something more to post next week on it!
Old 02-12-2011, 07:14 AM   #61
my4by2
my4by2's Avatar
So... I'd like to hear anyone's opinion on the STS remote turbo systems. Pros/Cons - Likes/Dislikes. Want an extra "power adder" & I am thinking of adding one to my truck & think it'd make it an even nicer driver given its weight. My rear toolbox will be big enough that I could have the air intake run up into it with a custom air box & all. Waiting to hear back from my engine tuner to get his thoughts to, so this is in the VERY early planning!
Old 02-12-2011, 04:04 PM   #62
MTCK
MTCK's Avatar
I have never had one of these on the truck, but in my opinion, I would not want a turbocharger hanging down below a truck that sees anything but pavement use. The oil lines could cripple you, and the chance of damaging ($$$$) the turbo with dirt, or an impact from a flying rock would be a downside. I would opt for a supercharger if you need a power adder. Maybe something like this?
http://www.summitracing.com/parts/VOR-4GL218-040SQ/
-Marcus
Project Plow Truck
Old 02-13-2011, 12:20 AM   #63
my4by2
my4by2's Avatar
Thanks for the input! Also considering doing a stroker kit, cam & some better heads to maintain an overall stock look. Still VERY early in the planning of all this engine mod stuff, so a little ways to go before finalizing anything!
Old 02-14-2011, 10:07 PM   #64
my4by2
my4by2's Avatar
Ok, so it's looking like I may go with this supercharger kit from Trick Flow with the black powdercoated compressor. WIll also upgrade the engine with a LS valvetrain kit & a double-roller timing set. We'll see what happens.
Old 02-14-2011, 10:19 PM   #65
MTCK
MTCK's Avatar
Very cool. That should be a good combo with the NV4500. Does it have an air/water aftercooler?
-Marcus
Project Plow Truck
Old 02-14-2011, 11:46 PM   #66
my4by2
my4by2's Avatar
Yes it does - it's in the pic with the license frame hanging on it. I am waiting to hear back the engine guy that the tuner recommended on some other parts I want to go in the engine as well as how we are gonna tune it, so will keep the updates comin'. Trevor & the guys are back from the King of the Hammers race, so the wrenches should be turning again!!!
Old 02-15-2011, 10:00 PM   #67
my4by2
my4by2's Avatar
Well, the grand supercharger dream is now kaput.... After many a conversation & realizing that we still needed ALL the electronics & related accessories I decided that it would just get WAY too expensive to go with the supercharger & still have to buy all that crap...
Anyway, I decided to go with a new Mast Motorsports LY6 HO 6.0L that already has upgraded cam & springs plus it makes 480HP to boot! The best part is that it comes with ALL harnesses, ECM, pedal assembly & basically all the other goodies to make it work for me!
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Bedside is cut out & all the new sheet metal should be getting welded in tomorrow as well as the old fill holes getting filled. Will hopefully be getting some additional pics to post by the end of the week, so be on the lookout for them!!!
Old 02-18-2011, 10:03 PM   #68
my4by2
my4by2's Avatar
Well, ordered an onboard air kit for my truck last night so I can have air whenever I need it. It's from Firestone & it's got a 3 gallon tank they'll have to mount up. Also working on getting a LED light bar from Vision X installed on the lower cross brace of the front puch bar their gonna be fab'ing up for me. No pics today, but should have a few early next week of the bed side fuel door weld up.
Old 02-18-2011, 10:15 PM   #69
joe231
joe231's Avatar
Cool!
Are you going to use a round fuel door?
I have been considering a 88-98 fuel door on mine, but I'll probably just stick with a square door.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-18-2011, 10:41 PM   #70
my4by2
my4by2's Avatar
Nope, no round door. Since my truck is the early body style I just didn't think it would look right & was a little to "modern"... We went with a fuel door off of a K5 Blazer - it's the standard square door, but already set up for the right side behind the wheel well. Believe it or not, Brendon Thompson is the one that's gonna be welding it all in for the shop. If you follow American Chopper you've seen him working at Paul Jr's shop - he lives up near Auburn though & is into rock crawling & that's how he knows Trevor & Beau. Like I said, hopefully will have pics of it all by Tuesday of next week, but we'll see.
Old 02-18-2011, 10:53 PM   #71
joe231
joe231's Avatar
That's cool!
Your fuel door is gonna be famous
CHEVY ONLY
Old 02-18-2011, 11:02 PM   #72
my4by2
my4by2's Avatar
What color did you use on your truck??? Mine's gonna be white as well, but have yet to lock in a color really...
Old 02-18-2011, 11:07 PM   #73
joe231
joe231's Avatar
my truck isn't painted yet...as of now it is calico....blue, black, gray, and mostly gray primer. I'm leaning heavily toward converting it to 4x4 and painting it snow camo.
you and every one of the other 4x4 crews are inspiring me
CHEVY ONLY
Old 02-18-2011, 11:16 PM   #74
my4by2
my4by2's Avatar
Oh, ok - was judging off your avatar pic... I am leaning mostly towards GM Summit White that they used on almost EVERY GM pickup forever! For the black rallye stripes & side pin stripes however they are gonna need to find a semi-gloss color that matches my powdercoated items - will also go on the LMC grille insert.
Old 02-19-2011, 08:53 PM   #75
my4by2
my4by2's Avatar
A little change of pace to break up the norm. Here's a few pics of a "modified" square body CUCV over here in Afghanistan - was WAY redneck-ified!!! Hehe
Also some shots of some of the cooler vehicles I get to tinker with! The little one was built by an off road place in Utah - there were 3 of them here. It was pretty cool with a GM 6.2L diesel, TH400 trans, remote shocks & Dana 60's front & rear from Dynatrac.
