Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-16-2011, 06:17 PM   #1
57 3100
57 3100's Avatar
2003 S-10 "check engine" light
guys,
my 2003 s-10 extreme 4.6 v-6 with 65k miles.
when i get on the highway and am going 65-75mph my "check engine soon" code will flash on and off fast for about 20 flashes, then stop for about 30 seconds, the start the flashing again.
it will do this for 10 minutes or so, then stop.....
do you got any ideas what is going on ?
cant use my scanner because it wont stay on...
the truck is running perfect.
57 3100 is offline   Reply With Quote
Old 01-17-2011, 09:01 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 2003 S-10 "check engine" light
flashing light means you have a catalyst damaging missfire. the codes will remain for 40-50 ignition cycles without failure.
just thinking here; you have a wet enviorment now, right? is there moisture in the cap?
68C15 is offline   Reply With Quote
Old 01-17-2011, 04:56 PM   #3
57 3100
57 3100's Avatar
thanks for the info.... what is a "catalyst damaging missfire" ?
about 8-10 months ago i had a complete tune up and #5 injector replaced.
i didnt know the code would be stored for, so when i get a chance i will scan it and see what it says.
is the "catalyst damaging missfire" something serious ?
like i said, the truck is running perfect with no rough idle or while at speed.
thanks a bunch
oh yea, no possibility of any moisture in the cap..
leonard
Old 01-17-2011, 06:43 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
about $600 serious. that's the going rate for a GM catalytic converter. aftermarket ones only last about 6 or 9 months.
I'll be watching for your codes.
Old 01-17-2011, 07:07 PM   #5
57 3100
57 3100's Avatar
oh, a catalytic converter... no kidding ? wow, not cheap.
i will check the codes tomorrow when i get off work and will post.
how will the truck run if i take the cat converter out and not use one ?
will it screw with the computer ?
thanks again..
leonard
Old 01-17-2011, 07:13 PM   #6
57 3100
57 3100's Avatar
also,
does the blinking "service engine soon" light mean i am still experiencing an engine misfire ?
like i said, 8-10 months ago it was running really rough when i brought it to my mechanic and he did the tune up and #5 injector. now it runs very smooth.
or did the misfire from back then ruin the catalytic converter ?
leonard
Old 01-17-2011, 10:34 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post the codes. The codes are a starting point. If the cat is toast, you'll hear rattling.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-18-2011, 11:06 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
if it is damaged to the point of not doing it's job you will get a P0420 or P0430 (converter efficiency low, bank 1 or 2 respectively)
if removed you will have high cylinder temps and pressure burning pistons along with codes for insufficient EGR flow and poor driveability
Old 01-18-2011, 06:47 PM   #9
57 3100
57 3100's Avatar
ok guys,
i just did a scan, and it says there are no codes.
i am using a hand held actron pocketscan i bought 6 months ago from autozone. in the past when the engine light would come on and stay on, i would get codes that were for evap, i think.....cant remember, but i erased them at that time.
here is all i get now with the scanner hooked up and key on:
0 codes
mil off
monitrs
o inc
7 ready
misfire
fuel
comp
catlyst
evap
02 sensr
02 htr
and i get the same results when the engine is started.
my instructions are kind of vague. what is mil off and mil on ?
i only get mil off, and cant make it say mil on.
so, i still wonder why my service engine soon light flashes the way it does when im on the highway ? and im reading no codes ?
thanks for the help guys.... any suggestions ? should i just keep driving it since it is running fine ?
leonard
Old 01-18-2011, 07:01 PM   #10
68C15
blood type; Retumbo
68C15's Avatar
it sounds like your scan tool, or rather a code reader, is only able to acquire generic codes, not manufacturer specific. gen. are P0xxx while man. spec. are P1xxx, P2xxx etc.
mil on means PCM is requesting the light on.
I understand the data you show, nothing out of the ordinary.
you might end up taking it to a shop. my first move as a pro tech would be to hook up my enhanced scan tool and look at fuel trims and missfire data followed by a test drive.
Old 01-18-2011, 07:31 PM   #11
57 3100
57 3100's Avatar
thanks for the help..... much appreciated....
in the past, when i had a code to read, it did start with POXXXX if i remember correctly.
so, when my reader says "mil off", is that ok ? if not, what do i have to do ?
i guess the next day i ahve off i will have to take it to my mechanic.
thanks again..
leonard
Old 01-31-2011, 06:16 PM   #12
CC69Rat
CC69Rat's Avatar
57 3100 -- Do you run Ethanol gas in it?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-31-2011, 06:26 PM   #13
57 3100
57 3100's Avatar
nope, just regular gasoline...
havent had it up to 70mph for long, but i put my airrade air cleaner system back on, and so far so good... maybe the factory air cleaner was too restricting ?
Old 01-31-2011, 06:46 PM   #14
CC69Rat
CC69Rat's Avatar
I was thinking a rich condition, so yes .. maybe adding more air will lean it out to the point the CEL will cooperate? Is the the CEL or the SES light?
Chad
Old 01-31-2011, 07:03 PM   #15
57 3100
57 3100's Avatar
thanks... it was the CEL
