Old 02-02-2011, 09:38 PM   #126
robnolimit
robnolimit's Avatar
Re: No Limit '72 C-10
Ok, here's the proof. I could have stayed with the cool sunroof, but it leaks, and with all the rain we get here (12" - 14" a year) that just won't do. The last pict is a teaser. Our 5.3 wrecker motor is about ready to go in. We followed the harness rework thats posted here (we usually use a painless kit) it took about 7 hrs to do, and double check. things are going good.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-02-2011, 09:53 PM   #127
lolife99
67-72 parts collector,…
lolife99's Avatar
You guys don't mess around,...
You're going to have to get that thing lower to rock those IROC's.
Keith
Convert to disc brakes.
Old 02-03-2011, 03:31 AM   #128
N2TRUX
Happy to be here
N2TRUX's Avatar
Just proves there's more than one way to skin a cab.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-03-2011, 03:40 AM   #129
VA72C10
VA72C10
VA72C10's Avatar
it's late, I'll give you a pass
Old 02-03-2011, 03:48 AM   #130
N2TRUX
Happy to be here
N2TRUX's Avatar
Actually I think it's early, but whos counting.
Articles-
"Refining Sierra"
Old 02-03-2011, 10:15 AM   #131
gcburdic
Restoration Virgin!
gcburdic's Avatar
Whoa Rob....only 12"-14" of rain a year...a monsoon!!!
Nice finds there....ya done yet?!?!?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-03-2011, 12:50 PM   #132
michaelnolimit
Active Member
I thought the 'skin' joke was pretty good. Yep, I feel for you guys as I watch the news and see the snow, rain, ice,....Brrrrrrrr, Its so cold here I had to wear a long sleave shirt today. I think friday we will work on rear shocks and panhard rod. The first real upgrades.
michaelnolimit is offline   Reply With Quote
Old 02-05-2011, 02:43 PM   #133
robnolimit
robnolimit's Avatar
I'm feelin pretty good about this. After dropping another 2" in back, we ran into the same trouble as everyone else. The shock issues. After researching the other kits, and solutions, and thinking about it, we came up with a plan. Here are some of the problems we noted. 1. No room for a longer shock, even with reworked or 'dropped' mounts. 2. shock angle gets worse, the lower you go. 3. If we go another 2" (8 total) we're screwed again. 4. the exhaust is a nightmare. 5. the inboard shock design doesn't handle that great. With this in mind, we set out for a fix. This is the whole idea behind the JT, to come up with tested components that WORK, and will HELP get more trucks on the road to be enjoyed.
Old 02-05-2011, 02:49 PM   #134
robnolimit
robnolimit's Avatar
I am also using this forum, and site to set the record straight. I am sure we will be copied. Now there is lasting, dated proof, and those who 'knock-off' will be called out. This kit will come with 2 different length shocks. A 10" stroke shock for the stock to 4" drop guys, and a 8" stroke shock for the 6" to 10" drops. Once the stock shocks and mounts are gone, the new lower mounts are a direct replacement.
Old 02-05-2011, 02:51 PM   #135
robnolimit
robnolimit's Avatar
The new upper mounts locate to the frame with a factory 5/8" hole. We provede a big bolt to hold and align the new mount. You have to drill the two 3/8" holes.
Old 02-05-2011, 02:54 PM   #136
robnolimit
robnolimit's Avatar
Then your all but done. Just bolt on the shocks and mount studs, all included.
Old 02-05-2011, 03:00 PM   #137
robnolimit
robnolimit's Avatar
After somt drive time, I am happy to report that the difference is clear. Body roll is reduced, and the ride is very smooth. The outboard location is a benefit in many ways. With a good quality monotube shock, these kits wil run about $185.00 I think thats a good deal for the gains. Just remember, You saw it here FIRST.
Old 02-05-2011, 03:07 PM   #138
SCOTI
SCOTI's Avatar
Hey, I like that Panhard frame mount. Looks like a good, functional idea.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2011, 03:19 PM   #139
67cheby
67cheby
67cheby's Avatar
nice work on the shock mounts also , looks like a clean, nice solution !!
67cheby is offline   Reply With Quote
Old 02-05-2011, 06:52 PM   #140
Alvin
Never Done?
Alvin's Avatar
I like the shock mounts! Any thoughts on installing them on a bagged truck? Would sure give some more room for exhaust over the axle.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 02-05-2011, 07:07 PM   #141
lolife99
lolife99's Avatar
Just curious,... what size drop springs do you have installed in these pics?
Also,... what is this extra tab?
(circled in red)
Keith
Old 02-05-2011, 07:26 PM   #142
robnolimit
robnolimit's Avatar
Sould be fine with bags. I plan on using a 255 bag on the back soon, as I need to tow a small trailer. Currently it has a 4" drop spring. As for the tab, this is part of the panhard rod mount plate. ( one on each arm) This is a planned mount for the rear sway bars we are working on.
Old 02-05-2011, 07:35 PM   #143
lolife99
lolife99's Avatar
Thanks for the reply.
Do you have any plans to try this shock set-up with a 5"-6" drop spring?
I would think the upper shock bracket placement would only work with the 4" drop springs you installed?
Keith
Old 02-05-2011, 08:59 PM   #144
BossHogg69
motor exploder
BossHogg69's Avatar
x2 on this one, since I'm running a 6" drop spring and am very interested in this shock mount you've come up with...
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-05-2011, 11:01 PM   #145
SCOTI
SCOTI's Avatar
With that arrangement of the brackets, it's limited @ the upper mount because of the bed floor. The lower mount can possibly drop down some but will likely encounter scrub-line issues @ some point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2011, 11:34 PM   #146
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Great build. Subscribing.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-06-2011, 01:19 PM   #147
robnolimit
robnolimit's Avatar
More drop is no problem. The shock in the photo Measures - now get this - 22.5" open, and 12.25" closed. Now, not too many of us have use for 10+" of travel, but the longer shock has a larger resivour. To go lower, we just use a shorter shock. The shock shown will still have a 1/2" of stroke left when the axle hits the frame. For trucks with shorter springs and C notches, we use a shock that measures 9" closed, and 16" open. This still has 7" of travel.
Old 02-06-2011, 01:33 PM   #148
SCOTI
SCOTI's Avatar
That's hard to tell from the pics & good for those w/more drop. That's still a decent length shock.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2011, 01:37 PM   #149
Hart_Rod
Hart_Rod's Avatar
Rob - I like the new setup. I am running an aluminum rear differential cover that is causing intereference with the long double adjustable panhard bar. I think the new bracket that you have on the passenger job might correct this interference issue. Can the bracket be flipped over and still bolt on? How much would just that bracket be? Here's some pictures of what I'm talking about. Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 02-06-2011, 01:50 PM   #150
lolife99
lolife99's Avatar
Rob,... don't you think a spring with 2" more drop will change the angle of the shock?
I picture it being "layed down" at a more horizontal angle,... unless the upper shock mount is moved forward.
Maybe it's not enoungh to matter.
Your thoughts?
Keith
1972 chevy, c-10, no limit engineering
