Old 07-03-2003, 02:42 PM   #1
Richard Dobson
Core Suppoort Cushions
I have noticed that there are core support cushion sets for 67-68 Chevy & 69-72 Chevy. I have also noticed that LMC sells a set that must me generic for 67-72. I bought one from LMC and noticed that the cushions are 1/4" approx. thicker than the ones for a 67-68 which is the front end that I am putting on my truck. Will this cause fit-up problems with sheet metal components fenders, grill, hood etc.?
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 07-03-2003, 05:15 PM   #2
john
member #16
john's Avatar
You will probably have less problems with fit if you call one of the board vendors and replace cab and support mounts at the same time. You will more likely get the right parts for your truck. If you replace just the support mounts you will probably have to shim the cab mounts anyhow. 1/4" is quite a bit. Good luck John
john is offline   Reply With Quote
Old 07-03-2003, 08:23 PM   #3
MOTHERTRUCKERS
It's a good idea to change all mounts at one time to keep your fenders etc. in alignment, and yes 67-8 and 69-72 are different core mounts.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 07-03-2003, 11:33 PM   #4
Nelson
Front & Rear cab cushions usually come together in a set with hardware.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
