Old 02-13-2011, 02:10 AM   #51
hardwaa
hardwaa's Avatar
Re: Post your Bed Wood/Metal - Customized/Modified or Stock
Mine
Super cheap, Easy to access rear suspension and gastank. Not scared to scratch it up.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 02-13-2011, 03:39 AM   #52
Miller92
Miller92's Avatar
Originally Posted by kirtzen View Post
It might be hard to tell what this is. When I did the Rhino linings I had the bed off. I was affraid that when i put the bed back on that i would scratch the back of the cab. So I decided to Rhino line the front of the bed and the back of the cab. This worked great, even if I decide to change the color all I have to do is tape to the edge of the lining. No need to paint between the cab and bed anymore.
Attachment 695557
Kirtzen, you're a pretty dang smart fella! I want to put the Rhino lining in my bed as well and now that I seen this pic imma have to steal your idea. lol did you do the lining yourself or have somebody else do it?
Miller92 is offline   Reply With Quote
Old 02-13-2011, 06:10 AM   #53
skoffice
skoffice's Avatar
Hey hardwaa, how did you attach your tubs to the bedsides? I'm doing to be doing something similar soon except I'm just going to leave the center of the bed floor open. Looks good!
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-13-2011, 08:55 AM   #54
lakeroadster
I used (2) pieces of 3/4" pressure treated plywood for the bed floor. Functionality on a budget and not beauty was the goal. The center seam is covered by a stainless bed strip and the wood is attached to the bed around the perimeter with carriage head bolts.
Used Thompsons Waterseal to seal all the plywood and painted all the bed angles and other surfaces that contact the wood.
Cut wood for the wheel tubs and fabricated supporting steel inside the wheel tubs for the wood.
A full size long bed rubber bed mat was then cut down to fit my widened mini-tubbed short bed. The mat is about 1/4 inch thick and is very heavy.
lakeroadster is offline   Reply With Quote
Old 02-13-2011, 03:02 PM   #55
SCOTI
SCOTI's Avatar
For you guys using the "pressure treated plywood" on your floors, did you just mount the bed 'strips' above the wood surface or route the edges for a flush fit?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-13-2011, 03:21 PM   #56
lakeroadster
I just mounted it on the top. Routing with plywood would likely lead too problems since the plywood is laminated.
Old 02-13-2011, 03:29 PM   #57
SCOTI
SCOTI's Avatar
That's what I was thinking but wondered if there was an alternative I wasn't aware of....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-13-2011, 06:24 PM   #58
mister twister
mister twister's Avatar
not a very good picture but here is my bed i built on a budget. I used 1" nom pressure treated pine boards. Cut the grooves in with my buddies table saw w/ a dado blade. I thought it turned out pretty decent and i can still use it to haul stuff..
mister twister is offline   Reply With Quote
Old 02-13-2011, 06:26 PM   #59
skoffice
skoffice's Avatar
Hardwaa, it wouldn't let me reply a PM to you, but thank you for the info! Sorry to clutter up the thread folks. Lets see more beds!
Old 02-16-2011, 09:26 PM   #60
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Hey gang,
I just stumbled up on this thread and thought I'd post my "So. Georgia Farmer" built marine plywood floor! Works. why mess with it !!!
TobyArnot is offline   Reply With Quote
Old 02-17-2011, 05:30 PM   #61
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Post your Bed Wood/Metal - Customized/Modified or Stock
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-17-2011, 07:05 PM   #62
1Bad62Pro/Street
Thinking about this:
Stepside Version of this:
Old 04-17-2011, 03:42 PM   #63
1Bad62Pro/Street
Talking Re: Post your Bed Wood/Metal - Customized/Modified or Stock
Bump for the new fellas on the board.
Still pondering what I'm going to do with my bed.
Old 08-13-2011, 12:11 AM   #64
1Bad62Pro/Street
Working on my bed. Will post pics later.
Cut the tubs out.
Old 08-15-2011, 10:27 PM   #65
1Bad62Pro/Street
Still working on my bed.
Cut the mini tubs out.
Going to use stainless steel tubs.
Old 08-22-2011, 02:13 PM   #66
Rob1961
Here is a few of my metal and Black Walnut
Rob1961 is offline   Reply With Quote
Old 08-22-2011, 02:37 PM   #67
RUSHNBOBO
Rushnbobo's 1968 C30 dually
-factory bed shortened to 8' .....narrowed to 6'6"
-rebuilt entire subframe w/channel iron
-bed lowered on frame approx 3"
-diamond plate trim over oak
RUSHNBOBO is offline   Reply With Quote
Old 08-22-2011, 02:38 PM   #68
jimmydean
jimmydean's Avatar
I spent a better part of the weekend planning out my bed. I hope to get started on it in the next few months with the intent of having it all done in time for the frame swap.
Some great ideas already posted. Mine is a little different, but should fit in well.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-22-2011, 02:43 PM   #69
1Bad62Pro/Street
Another idea I have for my bed!
Polished stainless steel strips separated by black walnut stringers and stainless steel carriage bolts. You guys feel Ole' One Bad?
http://www.truckinweb.com/features/0.../photo_09.html
Old 09-14-2011, 02:06 PM   #70
1Bad62Pro/Street
Just an update on mine so far:
Old 09-14-2011, 02:10 PM   #71
Scot_Douglas
Scot_Douglas's Avatar
Cedar planking from the local DIY home shop (used a dado to make the cuts for the strips) + three coats of teak oil:
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 09-14-2011, 03:23 PM   #72
steverino66
a couple shots of mine from July:
steverino66 is offline   Reply With Quote
Old 11-20-2011, 10:12 PM   #73
1Bad62Pro/Street
Old 11-21-2011, 09:02 AM   #74
SIDS65
72 Longbed floor shortened.
SIDS65 is offline   Reply With Quote
Old 11-21-2011, 11:08 AM   #75
kieth
kieth's Avatar
Here is my bed floor, black pine , Polished SS runners, and hardware:
kieth is offline   Reply With Quote
