Is it worth it? Truck price question
Ok so I found an 81 silverado crew cab that would be a perfect start to my cummins conversion project. Take a look at the pics and tell my if you think the asking price is worth it. It has a 350 and 4 speed manual trans. 2wd. Body appears to be in good shape. Motor has been rebuild recently, new clutch and new exhaust.
They are asking $1950 |
Re: Is it worth it? Truck price question
If the body is in goodshape i'd say a good deal if you want a 2wd, might find a cheeper one with a blown motor tho...
84 K20 Long Box W.I.P ![]() 78 Burb - parts now [Rolled] ![]() 68 c20 dump bed ![]() WHEN IN DOUBT--- FLOOR IT ![]() |
#3 | |
It doesn't look too bad except for that gap in the pinch. Offer low and and see what he says.
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
78K & 79C Jimmys
looks good from here!
if it was up here for that it would prob be sold all ready lol
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
In pic #2 there looks to be damage in front of the rear wheel???
In Pic #4, is there some damage under the front dr door?? Also, is there something wrong with the area below where the gas tank inlet would be on the driver side??? If I am seeing things in these 2 pics then I would think thats a pretty good price.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
Getting Old; Going Broke
It's had steps cut in to the bedsides, so you can hoist yourself up to reach stuff inside the bed.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I try to never pay for anything when buying a vehicle that I don't need. In this case, the rebuilt engine, SM465, new clutch and new exhaust will all be removed for your Cummins swap. So, you have to figure out how long you're likely to use those parts prior to the swap to see if it's worth it to you.
You could likely find a nicer truck with a blown engine or worn out big block for the same money.
#10 | |
On a side note I notice your a firefighter ![]() ![]() |
Oh here is a photoshop of what it will look like with the paint job and general look I'll have when its done. Stolen pic from somewhere else and changed to fit my purpose.
78K & 79C Jimmys
thats a cool idea,only seen that on newer ones
If the floor pans/rockers are rusted and the frame has rust, then I would look farther south a state or two to get a rust free one. Any rust at all scares me on an old truck - indicates it can be lurking anywhere just waiting to pop out. For a major rebuild/mod truck, not just an "as is" driver, I think you are always better off with a rust free truck to start with.
