#76 |
Re: '60 GMC Suburban (Project D-Daddy)
awesome burb dude, im diggin the look!
66 suburban 51 Merc 2 door coupe 38 Chevy Business Coupe (gf's) 76 Airstream Sovereign |
#77 |
Just here to tinker
![]() Join Date: Jun 2008
Thanks guys! I'm so ready to have this girl on the road. I'm trying to think of all the little things I need to fix while my gas tank is in the shop.
Turn signal switch: check wire new tail lamps: check fuel pump:??maybe ????? I think that is all that is missing to get her on the road. I do know that she needs shocks badly, but that won't stop me from driving her. ![]() Also, besides a crappy ride, is there any harm in driving with the rear axle riding on the bump stops?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#78 |
Resistance is Futile
With the big tires it will probably ride OK, but I wouldn't stick my tongue out too much!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#79 |
Just here to tinker
So I was wondering if I were to get Jeep lift springs, if that would allow me to be lower but not sit on the bump stops anymore? Any ideas guys?
Or maybe I could just install air shocks in the rear. Would that work as well? I really hate the idea of having a crappy ride.
#80 |
Just here to tinker
Well, I rigged up a one gallon gas can today and drove around a bunch. My gas tank should be done at the metal cleaners by wednesday but I just learned today that I am going to have to put a liner in it. Which is a bummer because the local shops are charging about $150 for a liner and test. That means I'll have about $300 into this tank. FML. No going back now though, since I already have $150 into it. Let this be a lesson to those others who want to restore their suburban tank.
Anyways, to make myself feel better I drove up to work and showed off my suburban then I drove back home and took some pics of both my girls. Enjoy. ![]() ![]() ![]()
#81 |
CLASSIX Truck Club
Looking real good. How many leafs you take out? I took out 4 and sits about the same as yours an I'm not on the bump stops. An I also have an extra set of back doors if you need anything. Yours look complete though.
#82 |
Just here to tinker
Mine has a trailing arm rear suspension since it is a '60.
#83 |
![]() Join Date: Jan 2011
Looks great!! are you going to air shocks or airbags inside the Jeep springs?
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
#84 |
Just here to tinker
I'm not sure what I am going to do about the rear yet, right now this gas tank ordeal is slaying my wallet.
So, I just got the tank back from the cleaners and it looks amazing...but, the process melted away the solder for the neck filler (see pics) and now that is one more thing to have put back on. I don't have the tools to do this repair so I have to take it to a shop. Now, it is going to need a liner (because it is bare steel right now) + neck filler re-soldered + 1/8" drill hole filled + sender modification to flip the pick up tube 180 degrees. I am going to be over $350 into this tank. No me gusta. But, I will have the factory tank in brand new condition so I guess it's not all for nothing. Here are some before and after pics: ![]() ![]() ![]() ![]() ![]()
#85 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Looks great......your doing a great job....lots of fun soon I am sure
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#86 |
I hate it when that happens. You plan on spending so much on one thing and then in order to make it happen you keep having to spend more. Your going about it the right way though. Looks like you will be driving around in no time.
#87 |
60-66 Nut
Wow that tank looks almost new. What process was used to clean it? Too bad the filler and vent tube came off.
#88 |
65 suburban vortec 5.3 bagged
awesome job the sub is looking great!!!
#89 |
Just here to tinker
Well, I know they had to "burn out" the old liner to ash and then remove it. I think from there they had some kind of acid dipped staged. I'm not sure which process melted the solder joints; the acid bath or when they were burning out the old liner. At the end they washed it and heated it up to get all the moisture out. I am pleased with the way it turned out though. I'm sure I'll be happier when I get it back from the radiator shop all assembled, lined and ready to go. Hopefully by next week!
#90 |
Just here to tinker
OK, gas tank still isn't finished but that hasn't stopped me from driving it a mile to work...
![]() Anyways, I lined the suburban up with my camper today to get measurements to see if I need to modify the location of my hitch (which I do) and I took some teaser pics. ![]() ![]() ![]()
#91 |
I have car A.D.D.
Very cool Suburban. I love the GMC grille. I hope to be getting one of these as soon as my 86 pick up sells.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#92 |
1960 GMC Burb
Cool pictures with the trailer. My dad used to pull our old Shasta with our 60. This is the only picture I could find so far...
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner ![]() 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT ![]() |
#93 |
Just here to tinker
I love that picture man. I was thinking of that one when I parked my truck by the camper. If you find anymore, definitely post 'em!
#94 |
Cort,
Your Burb is absolutely awesome and inspring me to get off my a$$ and get after mine. I was thinking of selling it for another hot rod but seeing yours and the others since I got on this site a few days ago has me itching to do mine the way I want it. Keep the momentum going and thanks for sharing your build. |
#95 |
Just here to tinker
Thanks Mike! I see you live in Roseville, I'll actually be down in Sacramento this week visiting family. I am originally from there.
I hope you keep your burb. I am looking forward to seeing it lowered.
#96 |
Thanks Cort. I've just been looking at pics of lowered burbs and keep envisioning what mine will look like once I get it down where I want it. I'm leaving this week for a mini vacation but as soon as I get back it's full steam ahead on the burb. Will you be coming down for the Sacramento Swap meet on April 17th? There should be lots of great deals on some of the parts you may need for your burb. You can find out more at www.SacramentoSwapMeet.com
Have a good trip to SacTown. |
#97 |
Cool Combo !! Restoring old trailers are almost as much fun as the trucks. Matching paint on the trailer with whitewalls and baby moons.. Cooooool.
#98 |
![]() Join Date: Mar 2011
nice burban wish my paint was unmolested, looks great with the trailer!
#99 |
Just here to tinker
Alright, here are some pics of the tank ready to go in. Tonight I hope to install it and actually drive around for a little while.
#100 |
