03-20-2011, 09:06 AM | #1 |
Hard to shift automatic column lever - Help!
Hi al,
So my 68 with powerglide can be pretty hard to get into park. Coming out of park into reverse and from reverse into D is awesome. What can cause this? Linkage? Something in the column? Bear in mind I am putting a 700R4 in within a couple of weeks so it may just go away but what causes this? Thx in advance. Last edited by ubtripn; 03-20-2011 at 09:06 AM. |
03-20-2011, 09:15 AM | #2 |
Redefining LowBudget
Re: Hard to shift automatic column lever - Help!
flip the hood up and pull the bolt out of the adjuster and see if its in the column or the linkage?? you should be able to move the linkage by hand under there to the trans...make sure you block the wheels.....then make sure its back in park...seector in park and put the bolt back in.. it should line up too
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
03-20-2011, 09:56 AM | #3 |
willd do, thanks.
03-20-2011, 10:00 AM | #4 |
check the bushings where the linkage connects to the column they wear out and need replacement many times
03-20-2011, 10:23 AM | #5 |
on it, thanks
03-20-2011, 10:24 AM | #6 |
Drive out the pin that retaines the gearshift lever to the column under the steering wheel & remove the lever. Spray WD -40 or similar in the hole. Put the lever back in & work it up & down. If this doesn't do it spray the opening at the bottom of the column where the lower lever comes out. This usually will cure it.
03-20-2011, 10:27 AM | #7 | |
Roadtrip!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-20-2011, 12:19 PM | #8 | |
Born Psycho
i use JB120 or PBBlaster personally but all good penetrating oils will do the trick.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
03-20-2011, 01:43 PM | #9 |
awesome, that is the kind of fix I like, thanks!
03-20-2011, 04:21 PM | #10 |
this happened to me over the winter. the problem was behind the steering wheel in the column. used some brake caliper grease and she's good as new.
03-20-2011, 04:54 PM | #11 |
thanks again guys
03-20-2011, 06:11 PM | #12 |
its all about the +6 inches
almost always in the column, very poor design
03-20-2011, 06:13 PM | #13 |
That worked! This board is awesome!
03-20-2011, 06:30 PM | #14 |
I had a similar problem even that you got yours fixed I thought I would post this here maybe to help someone down the road. I found that the plastic pointer that is in the gear indicator had broken and had fallen downinto the shifter and would not let it past neutral going up. Had that happen on two coloums in one week. Jim
03-20-2011, 08:39 PM | #15 | |
Born Psycho
