02-22-2011, 08:53 PM | #1 |
Cheap Altitude Adjustment
Thought I'd post up some pics of the drop I just did on my '69.
Front: Cut two coils off the spring. I will likely have to trim the bumpstops a bit, cause they're pretty close to hitting now. Rear: Used stock Jeep wrangler (TJ, I think is what the jeep guys call them) coils. Before: After: I should mention that by doing this, you severly limit the load carrying capacity. I wouldn't recommend doing this if your planning on hauling anything remotely heavy in your truck. I'll also need make an adjustable track bar to recenter the rear. mR |
02-22-2011, 09:05 PM | #2 |
Grandpa in the rustmobile...
Re: Cheap Altitude Adjustment
Interested on how you make your adj. tracbar..
Ive always heard more than 1- 1 1/2 coils you'll have problems aligning it.. You can make your own shock relocators too: http://67-72chevytrucks.com/vboard/s...d.php?t=359399 ps your pics dont show up for me..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-22-2011, 10:09 PM | #3 |
dazed and confused
how good does it ride with the jeep springs?
members met: redbaron69, billsbowtie,nc67 |
02-22-2011, 10:09 PM | #4 |
Do you mean you cut 1 coil off each side= 2 coils because I was told 1 coil would equal 2 1/2".My jeep springs lowered my rear 3" ,I'm gonna cut the fronts if I ever get the fricking ball joints off.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
02-22-2011, 10:12 PM | #5 |
Ive always heard 1 coil=2"
I cut 1 coil up front and jeep springs in the rear. Im going to cut another 1/2 coil I think.
02-22-2011, 10:18 PM | #6 |
To be sure I understand, you guys are using the stock rear coils out of a Wrangler for 3" drop? Humm.. I think I have a set in the garage. Do they seem to work ok? The ride is ok, not too soft with a decent load in the truck?
02-22-2011, 10:20 PM | #7 |
I cut two full coils off each of the front coils. I could have went with 1.5, but I wanted it a bit lower in the front.
I haven't driven it yet, just finished it up tonight. Jake |
02-22-2011, 10:27 PM | #8 | |
mR |
02-22-2011, 10:54 PM | #9 |
Yeah, the jeep TJ springs dont hold up to any load without bottoming out..but they look good
heres mine TJ springs 1 coil cut
02-23-2011, 11:32 AM | #10 |
My rear was quite a bit lower than yours, oldblue... guess they were a little more whopped out, which is why I had to go with 2 coils in front vs. 1.
mR Last edited by memphisrain; 02-23-2011 at 11:33 AM. |
02-23-2011, 01:55 PM | #11 |
vw guy & now c-10 guy
truck looks good OldBlue! I like it!
02-23-2011, 09:20 PM | #12 |
Thanks Mike! I still evny your truck looks killer lol
02-23-2011, 10:09 PM | #13 |
dazed and confused
how well does your truck ride oldblue?
02-23-2011, 10:20 PM | #14 |
Well, Its been so long I cant remember what it used to ride like (old shocks stock height springs old bushings no swaybar etc).
I didnt tell a difference when I cut the front coils, but the rest was so fast/long ago I dont remember
03-22-2011, 09:09 PM | #15 |
Got a deal on some 20's
Looks pretty good, for the little bit of money I spent, IMO. mR Last edited by memphisrain; 03-22-2011 at 09:11 PM. |
