Old 03-23-2011, 02:19 PM   #1
29od1
LMC Fan Shroud Quality
Does anyone have any information on the quality of the fan shrouds that LMC is selling for 2WD small blocks (part #32-2820 and 32-2825)?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=117
It seems they are almost half the cost of what some companies are asking, but I'm concerned that the cheaper cost may be because of flimsy or poor fitting parts.
Any help would be great!
29od1 is offline   Reply With Quote
Old 03-23-2011, 02:54 PM   #2
clear
Re: LMC Fan Shroud Quality
LMC has a bad habit of sending me the wrong parts. As far as quality I have been happy with every thing I have ordered from them. I have ordered bumpers and other stuff from them and they seem to be good quality just bad about sending **** for the wrong year of truck.
clear is offline   Reply With Quote
Old 03-24-2011, 07:34 AM   #3
29od1
Maybe no one has actually bought a fan shroud from them?
Old 03-24-2011, 08:00 AM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
i bought 2 4wd shrouds, for my 71 and the wife's 67 (our motors are mounted in the rear holes like a 4x4 so i have to use the deeper shroud.) They fit ok did have to fight with them some but for the savings it was worth it.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-24-2011, 08:28 AM   #5
c50rob
I ordered the same one you are referring to and was completely satisfied with the quality and fit. Like you I was skeptical because other vendors ranged in price from $99 to $129.
c50rob is offline   Reply With Quote
Old 03-24-2011, 10:56 AM   #6
HOOKEDon1
HOOKEDon1's Avatar
Mine was for a 72 Blazer 4wd... heavy duty radiator. So far its performing stellar... doesn't rub under acceleration or road vibrations... I'm very happy with it. Would order from them again. Their body panels don't always have the best fit... but the shroud and interior parts I used from them were perfect fit first time.
HOOKEDon1 is offline   Reply With Quote
Old 03-24-2011, 12:16 PM   #7
29od1
Cool, thanks guys for the input!
Old 07-14-2011, 10:21 AM   #8
29od1
Just an update after getting my A/C fan shroud from LMC. I'm very happy with the quality and the price so I would recommend it to anyone else looking for a new shroud.
Old 07-15-2011, 12:42 PM   #9
67chevemall
67chevemall's Avatar
Cool, thanks for the link. $60 is a great price!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-16-2011, 09:12 AM   #10
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I have one that I've been using since 2006. Only issues I had was using it with the 4 row radiator brackets when the radiator was only 3 row. Correct brackets fixed all issues!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 10-30-2017, 07:32 PM   #11
vancelot69
vancelot69's Avatar
First, let me apologize for the thread necro. I saw a few other threads, but this one looked like the best one to reply to.
I got the 4x4 fan shroud from LMC (32-2826) and when I finally got around to trying to put it on, it doesn't fit. The bottom goes into the holders and sits little bit away from the radiator, maybe 1/2 inch or less, then the shroud touches the radiator going up the sides, and it looks like it touches on the top, but the top mounting screw holes are about 1/2 inch away from the radiator mount. Did I get the wrong shroud, or do I have a different model radiator?
Thanks!
My toys:
1971 GMC Jimmy
2008 Hummer H3 Adventure
2003 HD Road King
vancelot69 is offline   Reply With Quote
Old 10-30-2017, 08:26 PM   #12
Jason Banks
Jason Banks's Avatar
Your radiator looks odd. The end tanks are not centered on the core.
Jason Banks is offline   Reply With Quote
Old 10-30-2017, 09:22 PM   #13
B. W.
B. W.'s Avatar
Good eye, if the core was centered it would bring the shroud in were it should be.
B. W. is offline   Reply With Quote
Old 10-30-2017, 11:30 PM   #14
vancelot69
vancelot69's Avatar
Well that sucks. I was planning to replace the radiator anyway, but I wanted to do (several) flushes to try to get the block completely clean so remnants of the crap doesn't contaminate the new radiator. I guess I'll be doing that without the shroud.
My toys:
1971 GMC Jimmy
2003 HD Road King
Old 10-31-2017, 09:22 AM   #15
bigmac73
bigmac73's Avatar
In regards to your off center core I did buy a three core radiator from lmc 6 years ago and it is still going strong
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-07-2017, 08:40 PM   #16
vancelot69
vancelot69's Avatar
Thanks for the heads up. The one from LMC is kind of expensive, but it's good to know it works.
My toys:
1971 GMC Jimmy
2003 HD Road King
