Old 03-26-2011, 09:14 PM   #1
Lightfoot
Lightfoot's Avatar
3 speed transmission identification. *HELP*
I recently picked up a 3 speed to use in my '67. I was told it came out of a 1966 Pontiac Tempest with a 6 cylinder, but what does that make it? Could anyone tell me?
Casting #'s
Case- 3858986
Cover- 3858992
Tail- 3878886
Lightfoot is offline   Reply With Quote
Old 03-26-2011, 09:32 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: 3 speed transmission identification. *HELP*
It really does not matter what the Trans come out of, In basic terms its a GM 3 speed. They were use in many applications. what's more important is the gears. On the tail shaft are grooves from none to 3 groves. Gearing is as follows. wityh No photos it can be somewhat difficult to ID.
also is there a back up switch?
Saginaw 3-speed 1st 2nd 3rd
No Lines (grooves) 2.85 1.68 1.00
1 Line (groove ) 2.54 1.50 1.00
2 Lines (grooves) 3.11 1.84 1.00
3 Lines (grooves) 3.50 1.89 1.00
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 03-26-2011, 09:58 PM   #3
Lightfoot
Lightfoot's Avatar
Thanks for the help. I believe mine has no grooves. Which one would be best for a sbc and 3.73 setup or does it really matter? Ill try to get a picture of it soon.
Old 03-26-2011, 10:50 PM   #4
ol_skool_chevy
In my mind it does not matter if your using a SBC unless your talking about how strong the trans is and the Propose its being used and the weight of the truck your putting it in.
Some might say the 3 speed is not a very strong trans. I would have to agree. But if you only using it for daily driver it should be a nice little around town trans.
No groves is the 2.85 1.68 1.00 trans.
Its will be some what faster to start off then say the 2.54 1.50 1.00 but in the end they all are 1:1 on the Hwy. I would say with a 3.72 read end it would be nice
Mark with Chalk
Cut with a torch
Old 03-26-2011, 11:08 PM   #5
Lightfoot
Lightfoot's Avatar
Thanks for the help. I plan on cleaning it up and getting a hurst master shift. I got the transmission for $50 at a swap meet.
