Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-14-2010, 06:04 PM   #226
jaros44sr
jaros44sr's Avatar
Re: AJ's '72 Cruiser Crawler Build
Originally Posted by Burt4x4 View Post
I often wonder what kinda of number I would get if I added up all my recipts from over the years....I may not want to know
My recipt stack is about 5" thick in my tool box
That number doesn't bother me, but IF my wife found out, she could very well no longer be my wifesome things in this universe are better off not to be discussed
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-15-2010, 09:42 AM   #227
Burt4x4
Burt4x4's Avatar
hahahah For Sure!! My wife would also **** a brick and then try and hit me with it
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-15-2010, 09:50 AM   #228
vtblazer
vtblazer's Avatar
but multiply X like 70 billion.
Whew...if she only knew the 'real' figure and not just the stuff I let on about.
vtblazer is offline   Reply With Quote
Old 02-17-2011, 06:20 PM   #229
CTENTA1
Registered 1971 K5
It's nice too see your still going at it. It's coming along really good. This is the kind of stuff that motivates me on my build. With that said, enough looking. I got to go work on mine!
CTENTA1 is offline   Reply With Quote
Old 03-31-2011, 05:52 AM   #230
vtblazer
vtblazer's Avatar
Any updates AJ?
How's it lookin' for spring?
Old 03-31-2011, 08:20 AM   #231
AJs72K5
AJs72K5's Avatar
Updates are coming. I've got a pile of new parts at the shop. I'm shooting for early summer.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 04-01-2011, 12:38 AM   #232
jaros44sr
jaros44sr's Avatar
come on! can't you give a little more info than that? what's in the works
SAFETY FIRST
AS usual, off topic
Jim
Old 04-01-2011, 04:00 PM   #233
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If there's no pics there's no evidence..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-02-2011, 12:36 AM   #234
AJs72K5
AJs72K5's Avatar
Here's your teaser.... I stopped by my painter this afternoon and picked up an SUV full of shiny black parts. And these are just the ones you can see...
- AJ
Old 04-02-2011, 09:43 AM   #235
FRENCHBLUE72
PROJECT 7DEUCE
wow!!!!!! Those inner fenders are awesome I don't think I have ever seen a set reflect like that..
MEMBER #6377
Project "7DEUCE"
Old 04-10-2011, 06:27 PM   #236
AJs72K5
AJs72K5's Avatar
UPDATE 4/10/11: Finally some post-worthy progress.
Been doing a bunch of work on the front Dana 44 over the past few weeks. I couldn't justify upgrading to a D60 with what I already had in the D44 and how I plan to drive the truck. However, I did want to make sure it could handle the BBC. So, here's my recipe for building one up:
Take one ARB locker...
And put it here...
then button up the pumpkin with a Ruffstuff diff cover
Bolt the axle in with a set of spring plates from Kert @ DIY4X
Now slide in a set of Yukon 4340 chromos with Superjoints
Finally, close up the hubs with a set of Warn Premiums.
I figured while I was at it, I might as well upgrade the steering. I contacted the Huisken boys at WFO Concepts for some crossover goodness. Start with a forged 2" steering arm to clear the Alcans
Add a 2wd steering box and a WFO pitman arm
Finally add a 1.5" .219 DOM drag link and tie rod. I still need to cut to length and get the inserts welded. I threw a rattlecan into the pic for reference.
That's all I have for the moment. More to come as parts are accumulating.
- AJ
Old 04-10-2011, 08:50 PM   #237
AJs72K5
AJs72K5's Avatar
OK....so that wasn't enough for you? I also got some of the freshly painted parts on.
AC Delete heater box. I had to rework the right edge to match the contours of the firewall dish since I had opened it up to clear the BBC.
Core support and the new battery tray
Radiator hold down / cover from Hot Rod Dynamics (LINK)
Its amazing how just the core support will make it start to look like a truck again.
That's really it for today...
- AJ
Old 04-11-2011, 10:30 PM   #238
7D2N
7D2N's Avatar
AJ, very nice work. I have enjoyed following the build and glad your still at it, oh and by the way I also think chevy big blocks are for blazers.
7D2N
7D2N is offline   Reply With Quote
Old 04-12-2011, 05:40 PM   #239
vtblazer
vtblazer's Avatar
way to go bud!!
Old 04-21-2011, 11:17 AM   #240
Jtrux
I'm a poor spectator
Jtrux's Avatar
Looking good. I'm about to send my LQ4 computer out to have the anti theft removed and i'm gonna start chopping up the wiring harness pretty soon. Hopefully one of these days we can get them all back on the road.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 05-28-2011, 11:31 PM   #241
AJs72K5
AJs72K5's Avatar
UPDATE 5/28/11: Big ticket items. Mr Brown dropped off a couple more big ticket items recently. Spent some time at the shop today getting my radiator installed and my fuel cell test fitted. A nice bit of progress today.
Entropy Radiator. Aluminum, two row, 1" rows. Designed for a 67-72. Includes the dual Spal fans and the shroud.
Talk about laying a nice bead. That some welding right there.
Hot Rod Dynamics radiator cover fit smooth over the Entropy Radiator. No adjustments needed. Was kinda weird, others who'd tried this combo had some minor fitment issues.
20 gallon EFI fuel cell from Fuelcellguy here on the forum. Really nicely made.
Sits as high up as possible for maximum ground clearance. Doesn't hang down much for a 20 gallon tank.
Finished up my crossover steering.
Final fit on the fuel cell's next, then time to start plumbing.
- AJ
Old 05-28-2011, 11:49 PM   #242
VA72C10
VA72C10
VA72C10's Avatar
Nice progress! Looking great!
Old 06-07-2011, 12:41 AM   #243
Bull72
Bull72's Avatar
Nice updates! Thanks and keep it coming!
Thank you god for all your blessings!
My mini build (I had a great starting point)
http://67-72chevytrucks.com/vboard/s...d.php?t=440743
Bull72 is offline   Reply With Quote
Old 06-07-2011, 07:20 AM   #244
Big J
Its lookin' like a Blazer!
Big J's Avatar
Its comin' together. I'm really liking the radiator. Cross over steering is pretty sweet too.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 07-04-2011, 11:23 PM   #245
Bull72
Bull72's Avatar
Itching for the updates!!!! Where you at AJ?
Old 07-05-2011, 07:13 PM   #246
AJs72K5
AJs72K5's Avatar
I'm here. Been sending a bunch of $$ to Summit lately gathering parts to redo most of my fluid plumbing. AN fittings add up really fast in the shopping cart.
- AJ
Old 07-05-2011, 09:36 PM   #247
Bull72
Bull72's Avatar
Yes they certainly do! It's going to be one nice rig when you are finished though!
Old 09-04-2011, 05:54 PM   #248
AJs72K5
AJs72K5's Avatar
UPDATE 9/4/11 - Fuel Lines. Been slowly collecting AN fittings, hose, and tubing to plumb the truck. Finally found some time to get the fuel lines run. I'm going with -8AN supply and -6AN return.
Bent some aluminum tubing down the length of the frame for the hard lines. Supported about every 13" - 14". Used padded tube clamps and made up some spaces to get them off the frame rail.
Mallory fuel filter. Short run of Aeroquip braided stainless from the tank.
Engine side. Need to make a small bracket that will attach to the top bolt of the water pump. It'll hold a tubing separator to keep the lines in place.
Tranny cooler and power steering lines are next when I can find time.
- AJ
Old 09-07-2011, 06:49 PM   #249
CTENTA1
Registered 1971 K5
Is their a certain reason why youre running the fuel lines away from the frame rail?
Old 09-07-2011, 07:49 PM   #250
AJs72K5
AJs72K5's Avatar
It was a bit easier to clear the brake line and the other frame brackets this way. Additionally, since I'm running aluminum lines, I wanted to make sure I could isolate as much vibration as I could.
- AJ
