Old 03-22-2011, 09:12 AM   #151
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Thanks for your input, I'm gonna wait till I actually get it outside to make a decision on the bumper. You know how things look different when you can really step back and think it over. If I do anything it will be tuck it like was mentioned, I hope to get the plastic tank cover at the junkyard or paint it black to conceal it better.
RB, question....is there a way to hook power up the truck (without actually connecting the battery) that would trip itself if something was wrong for my maiden attempt to crank it? I am SOOOOOOOO scared that something is going to fry, and I'm ready to drive this baby without having something major put up a roadblock. TIA
1952ssr is offline   Reply With Quote
Old 03-22-2011, 09:31 AM   #152
watahyahknow
watahyahknow's Avatar
Re: Freddy's '52
i think they make gadgets for that they send 12 volts at a verry low amperage through the system and shuts down at the first sighn of trouble maibe you could lend a regulated labratory powersuply they do about the same you can turn up the power slowly get everything to light up without smoking the cables
you should do it in stages big powereaters are halogen lights and wipermotor
indicator lights interiourlight dashboardlights radio (a normal headunit) electric antenna gps handsfree telephone and alarmsystem dont take as mush power
the starter should be tried last on full power to get it to turn over , the relay doesnt take as mush but only aply for a short burst to hear it clicking or you might burn the fieldcoils in the starter because of the lack of amps
another test you could do is put a ohmmeter on the batteryclamps and turn stuff on see if the ohms exeed the suspected values indicating a short .
dont be realy scared if you measure resistance with everything turned of , the radio , clock and sumtimes the interiourlight (when the door or bootlid is open ) allways take a little current to find it you could systematicly unplug stuff , thats the best way to find a short too
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-22-2011, 08:57 PM   #153
RootBeer 6117
RootBeer 6117's Avatar
Re: Freddy's '52
SSR
watayaknow has some good advice. You might also consider an in line low amp circuit breaker like I have seen on a lot of 70-80 gm cars. or a very low amp fusible link. I have a power probe it allows me to power or ground circuits and has a breaker that trips if there is a problem.
I bet you be fine you took your time on it.
Joe
RootBeer 6117 is offline   Reply With Quote
Old 03-23-2011, 10:42 AM   #154
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Thanks for the input guys and encouragement. I kept all the fuse links from the Z28 power block and everything has a fuse either from the S10 fuse box or the Z28 underhood fuse box. And I have tried to double check each connection before I soldered them.
I went to the junkyard and retrieved the hard heater hoses from the Z28 (thankfully he still has the z after 2 years) and the EVAP cannister. Got the lines mounted last night and boy am I running out of room under the hood.
Old 03-29-2011, 10:01 AM   #155
1952ssr
1952ssr's Avatar
Re: Freddy's '52
More progress on the wiring Saturday and mounting of underhood relay/fuse block. Also got my hard line heater hose in place. Last night did a little bondo sanding. Looks like trip to ROD RUN is a bust since it won't be running in two weeks. Probably head down to Year One's first show of the year.
Old 03-30-2011, 09:05 PM   #156
RootBeer 6117
Re: Freddy's '52
SSR Are those the heater hoses running in the cab throungh the blower fan hole? If they are what are you doing for the heater core?
Old 03-31-2011, 09:08 AM   #157
1952ssr
1952ssr's Avatar
Re: Freddy's '52
They are, the unit I'm using from Southern rods is a a/c - heater combo.
Old 03-31-2011, 10:23 AM   #158
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Need some help guys. My wiper motor has only 2 wires coming off of it, neither a chassis ground, with a toggle switch control. I'm thinking that the motor is a 1 speed style (it's an autolite =I'm guessing old) the only wire lacking hooked up to the toggle is the supply. I want to hook it to the s10 wiper harness which has a wire for supply, low speed and hi speed. Any ideas how to hook it up.
Old 03-31-2011, 10:38 AM   #159
RootBeer 6117
Re: Freddy's '52
SSR
Not sure, it does look like a Ford style wiper does it ground through the body of the wiper?
I found this for an 84 ford truck the earliest I can get for a ford it does show the wiper grounds through the body.
Joe
Old 03-31-2011, 10:46 AM   #160
1952ssr
1952ssr's Avatar
Re: Freddy's '52
SSR
That's what I'm wondering...there were no other wires attached. I think I will hook up the (supply) wire to my battery and see what happens using the toggle.
Old 03-31-2011, 10:54 AM   #161
RootBeer 6117
Re: Freddy's '52
I posted a diagram in my last post check it and see if thats close to the wire colors
Joe
Old 04-04-2011, 04:46 PM   #162
SouthernRodder
Re: Freddy's '52
SSR,
Great looking truck. I just joined today after reading multiple threads on this forum. Very, very good info on this forum, thanks to guys like you. I am in the planning stages of the S-10 frame swap myself, (well been planning for 2+ yrs) but the time has finally come to turn some wrenches. Will begin demolition in the upcoming weeks. I am curious to know a little more about the guage setup, does that seem like it is going to work properly, fuel sending unit and speedo?? It makes sense that it would. I guess you'll know after you fire it up and take it for a spin. Also what size tires are you running? And what wheel offset / spacers did you or are you using (you may have mentioned already).
I will not be one of these that bugs you with the same old questions already answered on this thread and other threads, but these are really important for me. I have everything else kinda figured out in my mind, just hung up on offset and tire size. And after seeing what you did with the guages I fell in love with that. Any info would be greatly appreciated.
Oh yeah my truck will be vortec 4.3 / 18&20 combo / flat copper pearl.
SouthernRodder is offline   Reply With Quote
Old 04-04-2011, 04:49 PM   #163
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Well I tried hooking up my wiper motor to the battery, nothing. So, I went to the junkyard today looking for a Chrysler mini van, found one and think it will work although it's motor sits in the middle of the cowl area. Then.....I spot a pontiac transport van, and its wipers wipe inside-out also. I'm going back to get its motor cause it is more offset to one side like ours are and the hook up should be the same or close to the S10 harness. I also found other items needed as well. Man I love junkyard hoping.
Old 04-04-2011, 05:09 PM   #164
bretcopsey
Re: Freddy's '52
You might also consider Chevy Venture/Pontiac Montana/Olds Silhouette as I believe they also wipe from inside out.
By the way, I just sent a pm with a question about your guage setup.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 04-04-2011, 07:20 PM   #165
RootBeer 6117
Re: Freddy's '52
Amen Brother, I have spent many a Saturday morning roaming through salvage yards (I like to call them salvage yards out of respect to some folks that take offense to being called "junk yards") I noticed a few weeks ago my wife's 2000 S10 blazer has a two speed rear wiper motor, Thadius(sp) has a cool set up for S10 blazer rear wipers but I think he might use the earlier S10 blazer 1 speed wiper. 98-200 something Jeeps also use a 2 speed rear wiper.
Old 04-04-2011, 08:14 PM   #166
Thadious
Re: Freddy's '52
Just to chime in, and hopefully give you a little heads up of what I went through in my search!
The original vacuum powered wipers work on a self-reversing setup, where the motor pivots (about 120-140 degrees), stops, then reverses its direction. The only motor I found that would repeat that was the ones from an early 90's S10 Blazer (not to say there isn't more out there), but it's what I found.
If you're looking for a motor, this is something to watch closely. Most modern wipers work parallel to each other and the AD trucks are opposed (they both go from center, up and outwards). This is due to the wiper motor working in a single directional rotation. You will need to find a motor with a secondary gearbox in it to get the reversing rotation and then work out the wiper arm setup.
Please, if you do find a motor like this, that is two speed, LET ME KNOW! As I would love a dual speed as well! (I may be able to find a way to make it worth your while if I can make it work, as I already have a two speed delay wiper setup figured out)
Best of luck!
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 04-05-2011, 06:53 AM   #167
RootBeer 6117
Re: Freddy's '52
Best of luck!
Ted.
Ted
I am not 100% sure it what you are looking for but my wifes 2000 s10 blazer rear wiper is two speed it is similar in shape and size to the earlier blazer rear wiper motor.
Old 04-05-2011, 02:39 PM   #168
1952ssr
1952ssr's Avatar
Re: Freddy's '52
I had my buddy at the local chevy dealer fax me over the layout for the transport wiper assembly. Check it out and see what you guys think.
Old 04-05-2011, 08:40 PM   #169
RootBeer 6117
Re: Freddy's '52
looks like an octopus hope I never have to fix one.
Old 04-08-2011, 09:10 AM   #170
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Hadn't had much time to work lately, but last night got my brake switch mounted. I used the original pieces from the S10 bracket just did a little cutting and bending. The piece mounted to the brake arm was simply bent 90 degrees, then the piece that the switch mounts into was trimmed of the cruise switch mount extra piece of metal and bent at a 90 and attached to the existing piece in the same location. I should have tooks pictures of each piece before I modified them but, I hope the pictures will help my explanation.
Old 04-09-2011, 07:45 AM   #171
RootBeer 6117
Re: Freddy's '52
One step closer, when put the brake pedals in from the Buick my bracket sat at an angle to get the booster to set level it looked strange but it worked.
Old 04-19-2011, 11:57 AM   #172
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Made some progress, Monday night got the rest of my firewall painted. Now I can mount my hood finally. Dash is next. Taking some time off next week so I plan on getting the a/c heater in and be right at the verge of cranking it.
Old 05-02-2011, 04:55 PM   #173
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Actually pushed the truck outside and washed it Saturday. I bought me a auto-darkening helmet and man the best money I've ever spent. I got my front clip braces made, but I had to fight with my hood to fit right. So the grill is now 2 inches higher than before. So I may be tucking the bumper up and in. I intergrated the S10 hood latch cause time has improved them, then attached the radiator top support to that.
Old 05-02-2011, 05:27 PM   #174
watahyahknow
Re: Freddy's '52
if you can find an extra grille you could add one more beam at the bottom and close the gap that way
Old 05-02-2011, 06:37 PM   #175
RootBeer 6117
Re: Freddy's '52
Looking good dude! you'll be driving it before you know it... I'd like to see more on the hood latch
