Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-18-2003, 12:21 AM   #1
Alex Hayley
Question tool for cutting steel
What tool would you recommend for cutting 10 to 14 gauge sheets and 1/8th inch angle iron?
Alex Hayley is offline   Reply With Quote
Old 07-18-2003, 12:34 AM   #2
danho
Pesemistic Optimist
danho's Avatar
Metal shears (electric/air), plasma cutter, metal chop saw.
danho is offline   Reply With Quote
Old 07-18-2003, 01:31 AM   #3
79 K20
I've always had good results just using a zip cut (cutting wheel) on a grinder. As long as you could run it straight it will cut no problem.
Q
79 K20 is offline   Reply With Quote
Old 07-18-2003, 01:32 AM   #4
1971 Cheyenne
1971 Cheyenne's Avatar
If you want a good clean cut, it's not for you, but i've always liked the good old oxy-acetylene (how DO you spell that?) torch for cutting steel.
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 07-18-2003, 02:47 AM   #5
Blue_71
Bloo
Blue_71's Avatar
i'll second the torch, but if you set it up right you can get a realitivly straight cut on thicker metal (i was cutting a frame)
when you get the oxygen set right, lean the tip where it heats up a long strip of the metal to almost dripping melted, then hit the button and go through it as quick as you can and still cut it
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-18-2003, 03:05 AM   #6
marcuspboldt
Registered Abuser
marcuspboldt's Avatar
If you have a power saw (i.e. skill saw), you could use a carbon blade in it and get really good results that way.
marcuspboldt is offline   Reply With Quote
Old 07-18-2003, 04:52 AM   #7
sgtjed
What if?
sgtjed's Avatar
i use a zaw-zall for most of my metal cutting,works pretty good if ya keep it straight. heck even a jigsaw with a metal blade works good.
2002 red extended cab Silverado
2002 Wheatland yellow Suburban
sgtjed is offline   Reply With Quote
Old 07-18-2003, 08:51 AM   #8
Mike C
Mike C's Avatar
Depending on the size of the piece to cut, the best thing I have found is the little horizontal/vertical bandsaw from Harbor Freight. About $175. I also have a chop saw that has not been out of the closet since I got the bandsaw.
It works great for cutting off long stuck even up to 1" thick. Just takes awhile. But it's quiet. If you need more speed for big stuff, use the torch. I just can't recommend a chop saw ever over the bandsaw. I have the cheap saw but some moderately priced Starrett blades for it that make a big difference.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-18-2003, 12:39 PM   #9
Randy70C-10
Randy70C-10's Avatar
I agree with sarge, a sawzaw or a jigsaw works best fo me as well, and you can make curved cuts with a jigsaw.
Randy70C-10 is offline   Reply With Quote
Old 07-18-2003, 12:48 PM   #10
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I agree. Plasma cutters are worth weight in gold IMO.
67Fleetsidedream is offline   Reply With Quote
Old 07-18-2003, 08:41 PM   #11
casey
casey's Avatar
I like the jigsaw but I always hate how the blades are held in, maybe I need a better saw
casey is offline   Reply With Quote
Old 07-18-2003, 08:49 PM   #12
cdowns
cdowns's Avatar
i'd love to have a plasma cutter and a nice upright bandsaw but for now like the other guys said the old $30 jigsaw with a good carbon or bimetal blade works pretty darn good up to 3/8 inch steel
Old 07-20-2003, 08:01 AM   #13
Blue Beard
Blue Beard's Avatar
Just a tip for torch users.
Take a center punch and place small dimples along your cut line about every 1/2 to 3/4 inch apart.
When you cut these show up very nicely and makes the cuts a little nicer with practice.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 07-20-2003, 10:32 AM   #14
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Another tip for torch users:
Clamp a piece of angle iron about 1/4" away from your line. Use the angle to support / guide your torch while you cut.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
