Old 04-15-2011, 10:11 PM   #76
(joey)
(joey)'s Avatar
Re: Project...praise the lowered
thanks fellas.its a little slow going lately.mostly small boring tedious jobs.but today i did get most of the front clip in filler.im not a psychic but i see alot of block sanding in my future haha.i should have some pics tomorrow.when i get home.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 04-17-2011, 07:03 PM   #77
(joey)
(joey)'s Avatar
nothing too exciting in this update.i spent the weekend blocking,and blocking and more blocking.im going to have to say the shaping grill will probably be the most time consuming part of the body work.so many curves and sharp edges but it turned out well.had a buddy come over and help out so that was a bonus.
Old 04-17-2011, 07:17 PM   #78
dnd1978
dnd1978's Avatar
Looks great! You just got to love blocking & blocking & more blocking. But in the end it looks great!
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 04-22-2011, 07:50 PM   #79
(joey)
(joey)'s Avatar
still blocking.i moved to the roof and the door gap.so far so good.my buddy showed me a great way to spread filler perfect along gaps.use a sign like a garage sale sign and stick it in the gap when your applying filler.it worked great.hers a few more pics.had my better half over today giving a hand.its amazing how well she does with body work.
Old 04-22-2011, 10:29 PM   #80
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks pretty good..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-23-2011, 04:41 AM   #81
slick copper
slick copper's Avatar
Thumbs up Re: Project...praise the lowered
Good work!!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 04-23-2011, 11:25 AM   #82
yukon ratrod
yukon ratrod's Avatar
looks awsome! going to be a one off for sure.
yukon ratrod is offline   Reply With Quote
Old 04-23-2011, 05:12 PM   #83
(joey)
(joey)'s Avatar
as always thanks guys.and happy Easter weekend.dont have much for pics but today i was.....you guessed it..blocking.should have the roof close to being ready for primer tomorrow.if i do anything exciting in the next few days i will post some pics
Old 04-24-2011, 11:46 PM   #84
Rigwelder1976
Pipeliner
good luck. you have a very clean truck on the way.
Rigwelder1976 is offline   Reply With Quote
Old 05-02-2011, 09:37 AM   #85
67cheby
67cheby
67cheby's Avatar
WOW...i hadnt checked up on your build in a while.... man looking KILLER !!
67cheby is offline   Reply With Quote
Old 05-02-2011, 04:41 PM   #86
dnd1978
dnd1978's Avatar
Your truck looks killer! How hard was removing your drip rail? Any tips you can pass on?? It look great! Keep the pictures coming .
Old 05-02-2011, 06:48 PM   #87
(joey)
(joey)'s Avatar
good to see you guys are still checking my build out.not much to update lately.still blocking filler but it has come a long way.and i got some goodies.b&m hammer shifter,and paddle switch/double needle gauge combo and some small stuff.i did manage to get some more parts blasted and painted and have the front half of the frame stripped/primed and sprayed with boxliner so the front suspension should be bolted into place real soon.also have a set of trailing arms in the making and just waiting for the rear axle to get blasted so i can make some out side frame mounts and rear bag mounts.i will get some pics real soon for you guys still following it.
Old 05-02-2011, 06:55 PM   #88
(joey)
(joey)'s Avatar
thanks dude.well if your going to attempt it i would do it with the windshield still in or keep checking the shape by putting the window in once in a while because mine was way off when i tried to set in the windshield the first time.do small sections at a time and if your bringing in the side to match the tops of the doors like i did,do a small test section to see how much of a strip you have to cut out to line it up proper.and again just do a little at a time.all said and done get ready to block bodyfill until your arms fall off.hope this helps in some way.any other questions feel free to ask
Old 05-03-2011, 11:42 PM   #89
allen123
It'll buff out
allen123's Avatar
Man this truck is sick! I can't wait to see how it looks once its all back together. It makes me want to get out there and start working on my truck.
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 05-05-2011, 08:43 PM   #90
thor
thor's Avatar
That truck is smoove! Your coefficient of drag will be under 0.30 if you keep this up! Maybe even under 0.25, the drag of the hideous Prius.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 05-06-2011, 06:13 PM   #91
(joey)
(joey)'s Avatar
i cant wait to get it done either.probably wont be done for my wedding day but soon after it should be rollin.
the drag of the prius comment got me laughing my a$$ off.good one
on a side note,got the rear end blasted,brackets shaved off and new brackets for the control arms and primer/paint should be the first of the week.this weekend will be more blocking and shaping.stay tuned
Old 05-07-2011, 12:31 AM   #92
yunkyarddog
yunkyarddog's Avatar
SIR may i request closeup pick of your well done grill?
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 05-07-2011, 07:54 AM   #93
(joey)
(joey)'s Avatar
yeah dude for sure.did you want the billet part?or the whole thing?any place you want close ups of?i can get some pics tomorrow when i go over to work on it.
Old 05-08-2011, 01:13 AM   #94
yunkyarddog
where the grill meets the light buckets and top & bottom just wanna see how you made it work
THIS IS BY FAR THE BEST LOOKIN GRILL FOR GMC PICKUPS BYFAR IMO IT SHOULD HAVE BEEN STOCK
Old 05-08-2011, 11:50 AM   #95
kev2809
low n' slo
kev2809's Avatar
man, just read the whole build. nice!!! im diggin the cluster swap...turned out sick!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-08-2011, 06:33 PM   #96
(joey)
(joey)'s Avatar
ok man,i went over today before i saw your post.i got a few pics if they dont work for you i will get more.what i did was simple.cut the center cross out,..the 4 missing sections where the cross meets the sides and top i simply welded in pieces i cut from the cross piece.bought a billet grill for a 73-83 then laid it on top of the 67 grill.traced looking down around the headlight buckets and used a cut off wheel to cut it out.then used a press to get the right bend i needed.hope this helps
Old 05-08-2011, 06:39 PM   #97
(joey)
(joey)'s Avatar
thats a long read mr.thanks for checking it out.heres a few more pictures of the progress.so close to primer time.
Old 05-08-2011, 11:56 PM   #98
slick copper
Sweet man! Can't wait to see it all primered up! Keep it up!
Raymond
Old 05-09-2011, 01:28 PM   #99
dnd1978
dnd1978's Avatar
Thanks for the info. I probably would have removed the windshield. I can see what you mean by bringing in the side to match the tops of the doors in the new pictures. Did you drill the spot welds and remover the lower part of the drill rail that is inside the top of the door frame or leave it in?
Oh yea one more question. How did you get your lady to work on your truck? That is quality!! HAHA
Later
Old 05-09-2011, 05:44 PM   #100
(joey)
(joey)'s Avatar
Later
haha.shes been helping me with cars,trucks,motorcycles,snowmobiles since day one.lucky catch i guess.
as for the drip rails i didnt drill any spot welds.just took out about a 1/2 inch or a little less section then brought the outer edge in to meet the inner.
