Old 01-15-2011, 04:19 PM   #1
Hubscrub
Cruzin
Hubscrub's Avatar
700r4 shift linkage
I have a 71 chevy 350, 700r4 trans. with a factory style auto column and i have the lokar cable shifter currently installed but i really don't like it i can't seem to adjust it enough to get more gears i can get P R N OD and sometimes D if i pull enough (the cable is hitting the column). So has anyone tried the shift linkage tha ECE sells or any other hard linkage that works better? My motor is also mounted in the rear holes (like a inline 6 and a 4x4) if that affects the line of travel any. thanks here is a pic of the shift linkage on the ECE website.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-15-2011, 05:35 PM   #2
6772owner
Gearhead
6772owner's Avatar
Re: 700r4 shift linkage
I have the Kugel Komponents shift linkage (basically looks exactly like your picture) I dont have any issues with it. I cannot seem to get the lower gears (1,2,3) to line up exactly with the indicator, but it doesnt bother me any.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 01-15-2011, 05:37 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
yea thats the brand name of it, not bad for $45 i think when i paid around $120 for the cable linkage thanks
Proverbs 3:5,6
Old 01-15-2011, 09:22 PM   #4
hotrodimpy
Hubscrub I just read your post. We designed that cable linkage years back. About a year or so we revisited the cable shift linkage kit. We redesigned the lower shift arm that goes on the transmission selector shaft. If you call our tech department and talk to Jeff or Eric they will be able walk you through adjusting the cable so you can get all your gear positions it is just in the adjustment. Hope this helps. 865-966-2269
hotrodimpy is offline   Reply With Quote
Old 01-15-2011, 09:38 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I had Kugel Komponents in my other truck with a 350/700 R4 combo. I dialed it in and it was perfect. Great price and great design....far better than a cable in my opinion.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 04-20-2011, 06:31 AM   #6
J-Rod67
Anyone tried the shift linkage kit offered by LMC truck for 700r4 in the 73-87 catalog?
J-Rod67 is offline   Reply With Quote
Old 04-20-2011, 07:09 AM   #7
mac808
mac808's Avatar
hotrod and/or leddzepp, is this simple 'adjustment' done just on the rod itself by loosening the collars on both ends and lengthening/shortening the amount of thread?
My gear indicator on my column doesn't quite line up either. I thought it was because the acrylic lense was for a 3 speed when mine is upgraded to a 4 speed but it still doesn't line up just right.
Any tips you could provide would be great.
mac808 is offline   Reply With Quote
Old 04-20-2011, 09:19 AM   #8
NicoSlam
I have the same setup as you mentioned and I just installed the Kruegl linkage. Perfect and easy to adjust although I had to trim the rod a little (3/8"). Its fun cutting stainless with a hack saw.
NicoSlam is offline   Reply With Quote
Old 04-20-2011, 10:36 AM   #9
tqlspec
tqlspec's Avatar
I have the Lokar cable shifter and it works fine in all gears.
Retired Navy
1972 C10 Cheyenne fleetside
350 sbc, 700r4, 3.42 rear
tqlspec is offline   Reply With Quote
Old 04-20-2011, 12:38 PM   #10
zellway
zellway's Avatar
I have the CPP kit on my 68. hard to bend the rod a bit to help the joints from binding but it works great.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 04-20-2011, 01:37 PM   #11
nobull2
nobull2's Avatar
x 2 Kruegl linkage I used it and works really well
nobull2 is offline   Reply With Quote
Old 04-20-2011, 06:45 PM   #12
1972RedNeck
1972RedNeck's Avatar
I just used the factory turbo 350 linkage on mine.
1972RedNeck is offline   Reply With Quote
Old 04-20-2011, 06:52 PM   #13
leddzepp
Moderator
leddzepp's Avatar
It has been a while, but I did that, as well as rotated the assembly that attaches to the transmission. You should be able to find a combination between the two to make it work.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 04-20-2011, 10:14 PM   #14
jugernot
Life, Be In It.....
jugernot's Avatar
I have the original linkage now, but have thought of using the Lokar cable because it looks like the stock linkage will be in the way of the exhaust coming off the Sanderson Headers I have.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 04-21-2011, 08:27 AM   #15
mac808
mac808's Avatar
Thanks leddzepp! Will try it and see how it goes!
