04-26-2011, 11:32 PM | #201 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Pulled the floor off again to clean up the backside of the holes and prep it all for final assembly. Once it was ready, I bolted it onto the framerails and started laying down the wood. I like the fact that the mounting hardware will be completely hidden beneath the planks Still need to cut and drill for the bedsides and tubs, then it will all get tightened down...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-26-2011, 11:40 PM | #202 |
Did you cut down your 'body pucks'? They look slightly shorter than my 3" ones (might just be how they appear in the monitor).
Wood looks good!
04-26-2011, 11:57 PM | #203 |
A guy with a truck
Yes, I took 1 1/8" out of them to accommodate the thickness of the wood stacked on top of the metal floor ribs. They are now 1 7/8" tall. Thanks for the comment- it still needs a little work, but should turn out nicely
04-27-2011, 12:03 AM | #204 |
VA72C10
very nice!!!
Looking for a 67-72 swb or blazer project in or around VA. |
04-27-2011, 11:59 PM | #205 |
A guy with a truck
Thanks! Getting there- slowly today...
Managed to get the bed floor bolted down tight after doing some more routing/trimming as some of the boards decided to warp on me What fun lying on my back running 50-plus nuts and washers onto the carriage bolts, all while snaking around the framerails, tank, and exhaust and finding creative ways to keep the bolts from spinning. Once everything was snug, I cut the wheelwells and drilled the perimeter mounting holes. Bed floor- DONE. Okay, still have to trim for the rear stakepockets... My neighbor stopped by as I pulled the truck outside and commented on how nice the bed floor looked, and then asked if I was gonna treat the wood with anything. "Nope." Going for the 'weathered' look. Got an odd look. I'm sure he thinks I'm ruining it Also, after making a huge mess with seam sealer and breaking my caulk gun, I installed some nutserts for the wheel tubs with a homemade 'tool'. Works pretty well, especially considering the actual installation tool is over $100. I woulda liked to have one, though, after about the third nutsert, as these things takes some 'oomph' to get them to crush. I am not looking forward to doing the other bedside...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-28-2011 at 12:03 AM. |
04-28-2011, 12:04 AM | #206 |
VA72C10
those are cool. Going to look factory to many people when done!
04-28-2011, 09:13 AM | #207 |
67cheby
nice work
04-28-2011, 10:25 AM | #208 |
Where did you get those nutserts? Those could be VERY usefull
04-28-2011, 11:36 PM | #209 |
So Many Ideas, So Little Money
agreed!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
04-28-2011, 11:41 PM | #210 |
A guy with a truck
Thanks- that's the idea. You guys will know, though...
Thanks! Yeah, pretty cool little gadgets. Picked 'em up through Grainger.com. Should be able to get 'em at your local store or on Amazon.com as well.
04-28-2011, 11:42 PM | #211 |
Still Learning
That bed floor looks awesome! Great idea with the nut serts. I may have to borrow that one myself. Nice!
04-28-2011, 11:54 PM | #212 |
A guy with a truck
Had some fun with the spray gun today after welding up the corner bracing and drilling holes for the rear cross-sill in its raised position. Sanded and scuffed the panels in preparation for primer- and then sprayed 'em. The primer looks grey in these pics, but is really black (this may be important later). The header panel is a truer representation of color than the bedsides; guess they were in the sun...
04-29-2011, 12:18 AM | #213 |
A guy with a truck
Gave them some time to dry while at my daughter's tee-ball game, then scuffed 'em again so that the color would stick I shot two wet coats of the HRF and maaaan does it lay out nicely. It is very forgiving unless you are a complete bonehead, like I was...
I got in a rush (dumb thing to do while painting) and had the panels too close together, so that I had to squeeze between them while painting, causing me get too close to the header and run it :cry: Also had a leakage issue with the gun that got a few drips on the 'sides since they were laying flat. I'll have to decide if I can live with it when it dries completely, but will most likely be sanding and respraying the header- at least the front side- the back is just fine All in all, I like this paint, and look forward to shooting more of it. I think it's gonna be cool In the pics, the jambs are mostly dry, as is the header, but the insides of the bedsides are still wet, hence the glossy-ness...
04-29-2011, 12:21 AM | #214 |
A guy with a truck
These things are awesome, but a bit of a pain to install without the special tool. It can be done, but definitely eat your Wheaties!
Thanks a lot! This is why I put these things up here: in hopes that someone might get some entertainment or use out of it. Also don't mind the motivation
04-29-2011, 01:21 AM | #215 |
Collector of Projects
I found them on eBay for less then the local stores or online....
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT |
04-29-2011, 11:50 AM | #216 |
very nice !!!! keep up the good work.
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
05-02-2011, 11:41 PM | #217 |
A guy with a truck
Thanks! Trying to keep the momentum- stuff just keeps getting in the way- stupid responsibilities...
I did manage to make a little progress by popping out the back glass using the extension cord trick and getting some primer on the back of the cab and paint on the wheeltubs. I didn't paint the cab, as it will get wetsanded before color... It is killing me to not be perfectly bodyworking this truck before paint. I keep wanting to do it 'right'. I think the technique will pay off though, as the reward for not having worried about the details now is not sweating parking it at Home Depot- or loading it with the junk I buy there. Just might end up with a sweet faux-tina, too
05-03-2011, 01:17 AM | #218 |
Big Red - Now its a SWB!
Looks good!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
05-03-2011, 08:48 AM | #219 |
A guy with a truck
Thanks! I hope to actually have a complete truck again soon...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 05-03-2011 at 08:50 AM. |
05-03-2011, 09:03 AM | #220 |
Howdy,
My project is down to the frame right now and I'm within a month or so of pulling the trigger on whether to paint or powder?? How did you like the powder coat when you got your parts back? It looks very very nice. The word on the street is that powder is the way to go?? What are your thoughts? THanks.. |
05-03-2011, 09:24 AM | #221 |
67cheby
Looking good
05-03-2011, 06:43 PM | #222 | |
A guy with a truck
Thanks! We're getting there... Posted via Mobile Device
05-03-2011, 07:29 PM | #223 |
Thank god you changed the bed that was my biggest worry,
Posted via Mobile Device |
05-03-2011, 08:59 PM | #224 |
Tot Roddin'
Nice progress GL! Love the floor/bed mods.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-03-2011, 10:32 PM | #225 | |
A guy with a truck
Thanks! Hope to have it back together soon
