Old 05-03-2011, 09:48 AM   #126
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Originally Posted by chevyrestoguy View Post
man, that looks awesome!!!
Originally Posted by 66-PMD-GMC View Post
What color is that color?
It is the color my truck interior was originally or darned close.
I want to do the interior of my 63 that color...
Nice build, aren't you glad you "took the plunge"?
Thanks Guys! Having the cab back on the frame makes me feel like the end is in sight. For the interior colors, I gave the following codes to my paint shop, and they were able to match them. I'm out of town for the week, but I'll post the actual codes they used when I get home. The exterior color is the factory Saddle Poly code 22683. I think the colors look great, I couldn't be happier.
Medium Fawn: 60% gloss
DuPont: #9171-L
Ditzler: #DL-22571
Rinshed-Mason: #65B84
Dark Fawn: 0% Gloss
DuPont: #9202-L
Ditzler: #DIA 22568
SFTorange is offline   Reply With Quote
Old 05-05-2011, 08:32 AM   #127
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: The Brown Truck
Originally Posted by SFTorange View Post
Got the cab mounted up.
that upper bbw seam came out great!
did you use panel bonding adhesive?
Old 05-05-2011, 02:42 PM   #128
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Yep. Panel adhesive on top and spot welds everywhere else. It definitely looks factory.
Old 05-09-2011, 09:53 PM   #129
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Started with the sound deadening this evening. It'll be a pretty big job, but should be worth the effort.
Old 05-13-2011, 04:13 PM   #130
SFTorange
SFTorange's Avatar
Re: The Brown Truck
My custom made white oak bed wood was delivered today. I'm very happy with how it turned out. I'll post pictures later this afternoon.
Old 05-15-2011, 04:59 PM   #131
SFTorange
SFTorange's Avatar
Re: The Brown Truck
I mocked up the unfinished wood with my stainless strips from Mar-K. My plan is to hit the wood with a high quality Marine Varnish. Notice the mirrored grain on the two center pieces... pretty cool.
Old 05-17-2011, 10:54 AM   #132
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: The Brown Truck
that cab looks CLEAN nice going man.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-20-2011, 12:01 AM   #133
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Thanks!!
Here's a progress update from tonight. My dad came to town for the weekend, and it made things more fun having someone else in the shop.
We got the M/C and booster installed and the new brake lines run. We also kept plugging away at the sound deadening.
Old 05-22-2011, 07:54 PM   #134
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Here are some more pics of the sound deadening, and of the wiring harness. We made a lot of progress this weekend, I just need to order crimpers from American Autowire.
Old 05-22-2011, 10:53 PM   #135
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: The Brown Truck
Very Nice work.
Alan's Classic is offline   Reply With Quote
Old 05-22-2011, 11:57 PM   #136
Orangetonicclicc
Orangetonicclicc's Avatar
Re: The Brown Truck
I just finished staining my bed!!! It turned out great! For best results!!! Stain once get a 300 grit foam and drain again!!!!! I have my entire process on my thread, but you seem pretty knowledgeable on most stuff!!!! Great job!!!!
Orangetonicclicc is offline   Reply With Quote
Old 05-25-2011, 08:40 AM   #137
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Originally Posted by Alan's Classic View Post
Very Nice work.
Thanks Alan! It's coming along. I'm trying to keep my nose to the grindstone.
Thanks! I looked through your build, and your bed wood looks great. I think I'm going to leave mine the original color and just coat it with several coats of Epiphanes spar varnish, sanding between coats.
I ordered the special crimpers from AAW the other day, so hopefully I'll be back on track soon. It shouldn't be long before I have the interior ready, then I'll be probably waiting for the body again...
Old 05-26-2011, 11:23 AM   #138
SFTorange
SFTorange's Avatar
Re: The Brown Truck
I thought I'd say a little about the sound deadening products I've been using. It is the Edead product line from Elemental Designs. I ended up using three different products. For most of the cab, I laid down two layers of 45 mil Edead butyl rubber deadening mat. (the 80 mil product was out of stock so I ended up installing two layers of the thinner mat). For the very contoured places, I used Edead V3 liquid sound deadening. I also ended up using the liquid on the back of the cab because I had extra left over and ran out of the mat. Both do a great job of keeping vibrations down. Finally everything will be covered with a high density foam mat that is designed to control higher frequency sounds.
Here's a picture of the three. I'm hoping that this effort will make for a nice quiet ride.
Old 05-26-2011, 01:02 PM   #139
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: The Brown Truck
Will those products work for those of us that prefer a rubber mat over carpet?
Personally speaking, I would prefer to hose out my truck if water wasn't so damaging to the metal in my cab.
Carpet is on my never use it list in my own trucks and since I brought it up, are there any suggestions for a vendor for a good high quality rubber floor mat for our trucks?
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 05-26-2011, 01:06 PM   #140
jimmydean
jimmydean's Avatar
Re: The Brown Truck
Nice work. I just used the regular peel and seal for my cab, but used a closed cell industrial foam pad from the firewall to the back, then carpet over top. The difference it made in the sound inside the cab was HUGE. And that was before my doors were done, should be wicked quiet now.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-26-2011, 01:23 PM   #141
SFTorange
SFTorange's Avatar
Re: The Brown Truck
I would imagine that the butyl rubber mat would work great with the rubber pad for the floor. I might worry a bit about the foam pad if you want to spray out the floor though. It might end up being fine.
I believe that most of the vendors sell a factory-style rubber mat, but I can't speak at all to their quality.
Excellent! I can't wait to drive this thing! Plus, as a bonus, my wife won't have to worry about her feet breaking through the floor!
Old 05-26-2011, 07:55 PM   #142
66-PMD-GMC
66-PMD-GMC's Avatar
Re: The Brown Truck
As much as I would like to hose out the truck I wouldn't for fear of causing rust problems.
I ordered a mat from one of mail order guys and it's a $99 POS.
Doesn't fit right and won't even if I trim it.
I'm looking for something better.
Projects..
440CID 2X4 Pontiac
Old 06-07-2011, 09:11 AM   #143
SFTorange
SFTorange's Avatar
Re: The Brown Truck
I finally got my special crimpers in from AAW, and set out on the wiring. The kit works very well for the most part. There is some splicing required to wire in the lights for the dash cluster. I've got everything wired up in the cluster, including a voltmeter out of a square body truck in place of the ammeter. Thanks for working through this Roy!
Can anyone tell me where bulbs were installed in the factory cluster? There are 6 round inserts for bulbs in the back of the cluster that appear to be for gauge illumination, but I can't imagine that they were all used from the factory.
I got the steering column bolted up and wired, and I test fit the condenser in front of the radiator.
I'm now trying to figure out a good place to install my trans cooler without blocking the flow of the condenser.
Old 06-07-2011, 01:04 PM   #144
RoyL
RoyL's Avatar
Re: The Brown Truck
looking good! make sure you "Calibrate" your voltmeter so it runs kinda in the center. I thought I had mine right, but it's about 3/4 where it operates. I'm too lazy to pull it out and fix it . . . You going with the original hardline oil pressure hookup?
Roy
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 06-07-2011, 01:23 PM   #145
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Roy
I think I have the gauge centered pretty well, but we'll have to see. I do plan to run the original hardline for oil pressure.
Old 06-07-2011, 03:00 PM   #146
kieth
kieth's Avatar
Re: The Brown Truck
If you do not mind not looking totally stock I picked up a full rubber mat that goes from the top of the firewall to the back of the cab. I to am going to be driving my truck and wanted it to be rubber instead of carpet. This rubber mat allowed me to use the equivalent of dynamat all over the firewall and floor of my 66 gmc, then put the rubber on top so it is easy to keep clean. Kieth I cannot remember where I got it but I can look it up if you are interested.
kieth is offline   Reply With Quote
Old 06-07-2011, 04:37 PM   #147
66-PMD-GMC
66-PMD-GMC's Avatar
Re: The Brown Truck
I got a funny PM and see that I worded something wrong. I don't install a rubber mat over carpet, I meant I prefer a rubber mat to carpet.. LOL
YES, by the way, I want a rubber mat that goes firewall to cab rear and can be held down by the sill plates on the sides. That would be perfect.
In Arizona, carpet is baked fast then falls apart and holds in TONS of dust and dirt. I can wipe out and nasty stuff with a damp sponge if I have a rubber mat.
Side note;
One of the vendors I have ordered from recently phoned me to express their frustration with my returning things. Well, if it wasn't Asian made garbage it would be in my truck.
The rubber mats I have ordered were thin crappy junk.
Projects..
440CID 2X4 Pontiac
Old 06-09-2011, 10:10 PM   #148
SFTorange
SFTorange's Avatar
Re: The Brown Truck
My new radiator came in today. After a lot of deliberation, I decided to go with the one from Engineered Cooling Products over the Champion radiator. Both products seem to be similar, but one is a two row with 1" tubes and the Champion is a three row with smaller tubes. I doubt there is any difference between the two. The ECP radiator is advertised as having a bigger trans cooler than the others but who really knows. I'm pretty happy with the product. There are a few fins that are a bit tweaked but nothing major. It'll definitely make the engine compartment look nice.
Here's where I'm thinking of installing the auxiliary trans cooler. Hopefully it works out ok. It's a big unit, but I don't want to fool around when it comes to heat on my new transmission. I'm trying to keep it out of the way of the a/c condenser as much as possible. I'm open to suggestions as to other places to mount it if anyone has any.
Old 06-09-2011, 10:22 PM   #149
66-PMD-GMC
66-PMD-GMC's Avatar
Re: The Brown Truck
I am still up in the air on what Radiator to go with.
It is good that you are putting thought into it and not just doing what everyone else is.
Leader not a follower, thats how I roll....
Projects..
440CID 2X4 Pontiac
Old 06-09-2011, 11:15 PM   #150
SFTorange
SFTorange's Avatar
Re: The Brown Truck
Thanks! I'll be sure to let everyone know how it works. I'm installing a transmission temp gauge too, so I'll know how everything is working.
