Old 05-24-2011, 10:15 PM   #1
'68 Pieces
'68 Pieces's Avatar
door wont open
welll i put my door back on tonight and i shut it after fiddling with it for a while and........
Now it wont open, what did i do to deserve this???? lol
any advice at all? can get that sucker open.
i must just suck at this.
1968 Chevy short bed restoration/ build/ put back together/ whichever you wanna call it!
I shall call it :"Rusty Tomato": its in the works
" Anything free is worth saving up for "
" If you dont know where to start, go back to the beginning "
'68 Pieces is offline   Reply With Quote
Old 05-24-2011, 10:47 PM   #2
Sammy
Re: door wont open
Might need a bit more info to help you out. Why you had the door off? Do you have the interior door panel removed? Can you tell if the rod that activates the inside release is working? Is the exterior handle button stuck? Was the door working right before it was removed?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-26-2011, 12:42 AM   #3
'68 Pieces
'68 Pieces's Avatar
Re: door wont open
oh sorry, i had the door off, and it is all together no panel removed, yes the door worked before, the outer and inner handle both worked to open the door. yup worked right before i took it off.
Old 05-26-2011, 10:14 PM   #4
eseaton
eseaton's Avatar
Re: door wont open
If you put new weatherstrip on you might have to push in on the latch side just under the handle while u try to open it.
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction
04 GMC 1/2ton daily
07 GMC Acadia wifes daily
eseaton is offline   Reply With Quote
Old 05-26-2011, 11:40 PM   #5
67chevy1series
67chevy1series's Avatar
Re: door wont open
ok in order to fix it you will need to take door panel off and try to manualy open it any way you can.
67chevy1series is offline   Reply With Quote
Old 05-28-2011, 09:59 AM   #6
'68 Pieces
'68 Pieces's Avatar
Re: door wont open
thanks guys ill try and figure it out
