Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 06-14-2011, 07:13 PM   #51
robnolimit
robnolimit's Avatar
Re: 63-87 rack and pinion
You can see the upper shaft connecting to the column and top u-joint.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-14-2011, 07:15 PM   #52
robnolimit
robnolimit's Avatar
Using factory G.M. lines, we plumbed the power steering hoses.
Old 06-14-2011, 07:25 PM   #53
jake696
This looks better than my wife's rack. Heres my credit card number
4756 9693 1245 1965 ex 01/65 . Just kidding looks awsome .
jake696 is offline   Reply With Quote
Old 06-14-2011, 07:55 PM   #54
gringoloco
A guy with a truck
gringoloco's Avatar
SEKSEE! How much clearance between TREs and framerails? I.e: how much can you section the crossmember before you have clearance issues? Looks nice
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-15-2011, 07:12 PM   #55
robnolimit
robnolimit's Avatar
Our 72 JT is running this. We raised the crossmember 1 1/2". And there is no need to 'C' for TRE clearance. When this install is done, I'll measure it for you, this will have all of the production parts on it. Should be done on friday.
Old 06-17-2011, 02:08 PM   #56
robnolimit
robnolimit's Avatar
Here's the last steps. We finally recieved the adjuster sleeves today! The hex shock is threaded with 5/8" x 18 on one side, and 14mm x 1.5 on the other. We then had them heat treated. Tie rod ends are high-mis-alignment 5/8" chromoly.
Old 06-20-2011, 01:41 AM   #57
lownbad71
lownbad71's Avatar
What is the latest on this install? Any idea what it is going to cost?
lownbad71 is offline   Reply With Quote
Old 06-20-2011, 02:42 PM   #58
robnolimit
robnolimit's Avatar
Sorry about that... power went down, couldn't get to the pictures
Here you go............
Step 2
Start by removing the spring clamps on the rack boots
Old 06-20-2011, 02:51 PM   #59
robnolimit
robnolimit's Avatar
Thread the rod end into the adjuster sleeve. Leave approx 1/4" of thread showing, tighten the jam nut - TIGHT!
Old 06-20-2011, 02:53 PM   #60
robnolimit
robnolimit's Avatar
** Thread the adjuster sleeve onto the inner tie-rod end. Leave approx 1" of thread showing. Leave the JAM NUT Loose
Old 06-20-2011, 02:58 PM   #61
robnolimit
robnolimit's Avatar
Bolt the new tie-rod assembly to the bottom of the steering arm. The large U.S.S. washer installs on the bottom, as a saftey stop for the rod end.
Old 06-20-2011, 02:59 PM   #62
robnolimit
robnolimit's Avatar
The Complete Install. Toe adjustment is made between the inner tie-rod end and the adjuster sleeve. Don't forget to put the spring clamp back on for the rack boot. For smooth cruisers, set toe at - 1/8" . For more spirited driving, try 1/8" toe out.
Old 06-20-2011, 05:27 PM   #63
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
just what I've been waiting and looking for.....now just need to dig up the scratch to pay for it....
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-22-2011, 11:19 AM   #64
Custom 68
Custom 68's Avatar
very nice product and write up Rob, glad it is coming together.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-02-2011, 04:10 PM   #65
65Short
Any way we can get pics of this? Did you section the crossmember or Z the frame? Thanks, Jon.
65Short is offline   Reply With Quote
Old 07-04-2011, 01:25 AM   #66
Jenkins Classics
How much is the kit and when will it be available.
Jenkins Classics is offline   Reply With Quote
Old 07-19-2011, 05:34 PM   #67
Slammed50
What kind of rack and pinion are you using for this set up? Looks great, just what I am looking to upgrade next on my truck.
Slammed50 is offline   Reply With Quote
Old 07-19-2011, 06:01 PM   #68
doubleRdazz
Whats the price?
doubleRdazz is offline   Reply With Quote
Old 07-20-2011, 07:44 AM   #69
rob32472
http://67-72chevytrucks.com/vboard/s...d.php?t=441047 check out this thread it will tell you guys what you need to know
rob32472 is offline   Reply With Quote
Old 09-18-2011, 09:28 AM   #70
mac
Active Member
mac's Avatar
Rob- any movement on the "isolator" delivery?
mac is offline   Reply With Quote
Old 11-17-2011, 12:38 PM   #71
robnolimit
robnolimit's Avatar
All the parts are in, and all current orders have shipped. Thanks for the patience. We're all really happy with how this turned out. Hopefully our extra work will provide many truckers with years of happy cruising. Now, how long will it take the others to copy??
Old 11-18-2011, 06:50 PM   #72
SBTork
Garage wrench
SBTork's Avatar
I am curious about this too. It will happen, I am sure someone will copy this. It's too bad, but I am sure it will happen.
On the plus side, you guys did an awesome job and are offering a great product, so kudos
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-18-2011, 09:38 PM   #73
robnolimit
robnolimit's Avatar
Thanks. I know it will happen too. I hope that joking about it ahead of time will put the copiers on notice that we know they are .... can't say that word here.
Old 12-16-2011, 07:30 AM   #74
DUTCHMAN
DUTCHMAN's Avatar
Hi Rob, I'm not such a gearhead but trying to understand all the info here on the board.
I'm wondering what are the benefits from your rack and pinion vs my oem power steering? Does it handle better and has it a shorter turning ratio?
thanks
06 BMW 330d aut touring full option
83 Jeep CJ7 360 aut sold
71 GMC Suburban
67 Chevrolet C10 stepside
54 Ford F100 sold
49 Chevrolet coe
48 Ford f6 coe
Strijen
the Netherlands
"NO MISTAKES NO PROGRESS"
DUTCHMAN is offline   Reply With Quote
Old 12-31-2011, 06:44 AM   #75
rs72z
rs72z's Avatar
Anyone know what the price is on this setup? I didnt see it on their web site.
rs72z is offline   Reply With Quote
