Old 06-16-2011, 07:01 PM   #1
eightyfive
eightyfive's Avatar
Need more help!
Hey, every time i shut the ignition off or turn it on, my heater makes a buzzing noise for about 5 seconds and then is quite. It still works fine, but after a while that sounds gets pretty fricken annoying.
Thanks in advance!
parts truck- 1982 suburban GMC Sierra Classic
first project- 1985 GMC Sierra Classic
first truck- 1988 GMC Sierra sle
"New" Hot rod 1999 Chevy silverado 5.3L
Workin my way up the food chain
eightyfive is offline   Reply With Quote
Old 06-16-2011, 07:05 PM   #2
eightyfive
eightyfive's Avatar
Re: Need more help!
BTW, its a 1988 gmc sierra sle 2wd with a 305.
Old 06-16-2011, 10:34 PM   #3
Boog
laying low
Boog's Avatar
Re: Need more help!
One of the hvac doors is most likely going back to open or closed position making that noise. My 88 did the same thing. If everything works like it should you don't have a problem.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-18-2011, 02:24 PM   #4
eightyfive
eightyfive's Avatar
Re: Need more help!
yeah everything works, so thats normal for these trucks?
Old 06-18-2011, 05:30 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Need more help!
I think that's what he's saying. If your heat and a/c work okay, and your blower functions in all speeds and you can select heat, air or defrost without any issues...but you have that annoying noise....yeah, it's good.
Member Nr. 2770
Old 06-18-2011, 07:37 PM   #6
Boog
laying low
Boog's Avatar
Re: Need more help!
Right. It's normal.
Boog
primer is finer
Old 06-19-2011, 07:07 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Need more help!
Yea my buddies truck does the same exact thing. Everything works just fine but that sound does get old fast haha!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
buzzing, heater
