Old 06-11-2011, 12:01 AM   #101
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
Originally Posted by fredscarryall View Post
va72c10 i dont think i need a residual valve. unless your master cylinder is below the bleeder valves. like in a frame mounted master cylinder set up.the residual valve prevents fluid from backflowing to the master cylinder causing a spongy pedal.the master cylinder being lower thenthe bleeder does something with the pressure and gravity. i bought a disc/disc combination valve that does metering (which holds off pressure until rears catch up)and proportion (which gives the rear full pressure to a certian point so the back doesnt lock up)
yeah, I wasn't sure if it was just the master or also the prop. Just figured I'd throw that out there in case..
Old 06-11-2011, 12:02 AM   #102
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
Looking good....any side shots
Old 06-11-2011, 12:58 AM   #103
fredscarryall
fredscarryall's Avatar
Re: slamburban
i will post side shots next week when i get the front sheet metal on
fredscarryall is offline   Reply With Quote
Old 06-11-2011, 01:24 AM   #104
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: slamburban
never been a big carryall suburban fan but you have sure got me loving this one, excellent workmanship, cool paint and overall theme, great work, you may have converted this guy look forward to your updates
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-11-2011, 02:00 PM   #105
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
cool! Looking forward to seeing those especially when you get the running boards mounted and it's laid out
Old 06-16-2011, 10:25 PM   #106
fredscarryall
Re: slamburban
i got the inner fenders,splash shield,latching plate and core support back from the powdercoater. i also got a radiator from superior radiator on ebay. i bought it for $199 and $24.00 to ship.it a all aluminium 3 row and its good to 750 horsepower.
Old 06-16-2011, 10:31 PM   #107
fredscarryall
Re: slamburban
i removed the shifter bump on the column.i cut it off and filled it with steelwool and jb weld. then i sanded and primed it. i'm going to paint it blue tomorrow.
Old 06-16-2011, 10:43 PM   #108
fredscarryall
Re: slamburban
someone it the 80s descided that the carryall need a sunroof. it would probably be o.k. if the hole was cut in the right spot. its about a foot to far back. so i am going to have a roof section cut out from a rusted out cab of a truck and have insane wayne weld it in tomorrow.
Old 06-16-2011, 10:57 PM   #109
fredscarryall
Re: slamburban
here are some pictures or the hood lace i got from jim carter. the screws,the rubber lace and little metal brackets cost about $20. also got some powdercoated hinges off of ebay from 69powderkeg.the guy used eastwood single stage reflective chrome powder. looks like aluminium and its alot cheaper then chrome. he did a really nice job.also installed the power brake double boost and master cylinder. charlie bled the brake for about 2 hours and couldn't get a pedal. it was a cheapo ebay. i think there is something wrong with the master cylinder.
Old 06-17-2011, 12:27 AM   #110
tantrumpipeline
Re: slamburban
looking great keep it up, never did get the whole sunroof trend in the 80's, the engine bay looks unreal!!
20 Duramax tow pig
52 short project
Old 06-20-2011, 01:42 AM   #111
sgtusmc
sgtusmc's Avatar
Re: slamburban
I just read through your build. Friggin insane man...I love it.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 06-20-2011, 02:43 AM   #112
tmoble
Re: slamburban
on the bleeding problem, did he bench bleed the M/C first? if not it will take forever and 2 or 3 days to get a pedal.
tmoble is offline   Reply With Quote
Old 06-20-2011, 12:18 PM   #113
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: slamburban
I hope the single stage chrome powdercoat lasts awhile for you. I used the same powder on a job and wound up having to redo it and buy new decals again too. The single stage chromes are not quite scienced out yet. The finish won't hold up compared to usual chrome powder topped with a clearcoat. Just make sure and not touch it any more than you have to. The body oils seemed to do the damage to the finish.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-21-2011, 12:48 AM   #114
fredscarryall
Re: slamburban
i have always bench bled a master cylinder. this time i didnt. charlie thought you would get the same result if filled both resevoirs with fluid and take a brake bleeding kit and run the both hoses to a jar until all the bubble are gone. then run both tubes back into the master cylinder and pump the brakes until all the air is gone. what is the difference between bench bleeding with a screw driver and bleeding the master cylinder in the truck with it hooked up to the pedal?
Old 06-21-2011, 01:05 AM   #115
fredscarryall
Re: slamburban
here are some pics of the sunroof and gas door filled in. the roof of the truck and the roof of the suburban dont have the exact same curve. so it could not be butt welded. he over lapped it and welded it in. then he hammered and dollied it out and only had to use an 1/8 inch bondo. i am going to use seam sealer in the interior part and paint the outside of the roof tomorrow. i forgot to remove the screwdriver before i took the picture.
Old 06-21-2011, 01:12 AM   #116
fredscarryall
Re: slamburban
i here the worst thing for single stage chrome powder coat is heat.i figured i would be o.k. with the hinges. but i will try not touching the hinges with my bare hands to much.
Old 06-21-2011, 01:31 AM   #117
tantrumpipeline
Re: slamburban
looks sweet, nice patch work
20 Duramax tow pig
52 short project
Old 06-21-2011, 01:44 PM   #118
SnyderCreations
Re: slamburban
Looks awesome! I have been thinking about picking up a carryall locally, I think I'm sold now!
SnyderCreations is offline   Reply With Quote
Old 06-21-2011, 11:58 PM   #119
fredscarryall
Re: slamburban
i had to go to a 3rd master cylinder.i got 2 bad corvette masters and had to use a 72 chevelle one. then it bench bled just fine on the firewall and i finally got a pedal back.
Old 06-23-2011, 12:34 AM   #120
fredscarryall
Re: slamburban
painted the roof today
Old 06-23-2011, 12:37 AM   #121
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
Cool! Looking good...like the teaser pic
Old 06-23-2011, 01:51 AM   #122
tantrumpipeline
Re: slamburban
stance is perfect, paint looks great, we know there's more and you're holding out
20 Duramax tow pig
52 short project
Old 06-23-2011, 08:53 AM   #123
oldman3
oldman3's Avatar
Re: slamburban
Very niiiiiiiice. Looks really good.
oldman3 is offline   Reply With Quote
Old 06-24-2011, 10:33 PM   #124
fredscarryall
Re: slamburban
here's the chevelle master cylinder. a bit bigger, bulky and not as pretty but it works.
Old 06-24-2011, 10:39 PM   #125
fredscarryall
Re: slamburban
i made my own inner fender to firewall filler panels out of 18 gauge steel
