06-26-2011, 07:48 AM | #51 | |
Re: Pretty ticked right now...Rally wheels
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-26-2011, 08:25 AM | #52 |
KEEP ON TRUCKIN'
I agree, it's the powder coating not the wheel. You can do this yourself, get a grinding wheel that you can put in your drill, take your time and slowly grind away the powder coating from the center rim.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
06-26-2011, 09:43 AM | #53 |
I just measured the 1984 rear axle hub flange at 3.175" So a bit more would be needed for clearance. I don't Know where the wheels come from but maybe some of the big chryslers had a 5x5" bolt pattern. I have some of the chrysler wheels on my utillity trailer and I know for sure that they are 5x4.5".
What are yours measuring? Last edited by 1LowToy; 06-26-2011 at 03:31 PM. |
06-26-2011, 10:18 AM | #54 |
Gentleman Jim Driver
Jeff,
Here are the wheels that are on now on my 85. I think they came off my 87 shortbed diesel but may have been off my 86 longbed. I had them powder coated in 2003 for my 86 project but it has gone nowhere. I bought my little plain jane 85 after the red diesel got totaled and put these wheels on. They were tight over the centers but fit. As I tightened them down, the rotors/rear axles pushed some powder coating out. They look like your first pic. They are 15x8 and the truck has 1" front brakes and a 10 bolt.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
06-26-2011, 12:18 PM | #55 |
went and checked mine on a 1986 long bed they all have the raise screw holes for the wheel center
06-26-2011, 06:03 PM | #56 |
not sure if this was mentioned, but the rims with the raised centers are for the older style cap, bolts from the rear, the flat ones are for the cap that bolts from the front, has notches were the wheel nuts are, compared to a nice smooth round cap like the early 70's. bolt pattern is the same, so just pull out the die grinder.
06-27-2011, 08:31 PM | #57 |
yeller
The "cap mounting from behind" makes sense with the raised mounting....can anyone confirm the early caps did indeed mount from behind? Pictures to prove it? That might just be it, and if so, an early rally wheel design I was unaware of.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-27-2011, 08:36 PM | #58 |
Watch out for your cornhole !
The earliest rally wheel caps definitely mounted from behind. I've owned them personally.
06-27-2011, 08:38 PM | #59 |
yeller
I hang my head low with great embarrassment...and relief too!
I finally had time tonight to mess with the 75 a little. I picked up a matching fifth Rally wheel (round center), because I wanted all four to match...even though you will never siee it...just because I am anal. I pulled off the drivers front wheel/tire, and the Rally slid right on. Sweet! So I took out the drill and grinding bit, and removed the powdercoating from the inside hole diameter on one of the wheels...and wouldn't you know, it slid on perfect. Did the other three while I was at it. Tonight I will spray some grey epoxy primer/paint on the bare surfaces and be done with it. The tire shop was way off in their measurements, and I simply took their word for it because I didn't have a spare wheel to test their theory on. What kind of had me baffled too was my 88-98 powdercoated Rally wheels fit my 77 just fine...no grinding required. So anyhow, I dropped off the fifth wheel for powdercoating, and should have it back shortly so I can finish getting these wheels and tires on the truck. I will also now have a semi-matching powdercoated spare...lol! Thanks for everyones help and feedback. I learned a lot about Rally wheels here, something I don't think I will ever forget.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 06-27-2011 at 08:41 PM. |
06-27-2011, 08:41 PM | #60 |
Jeff,
Do you mind telling what your guy gets to blast and coat a rally wheel ? I ask just to gauge my prices against other shops. Also, do they do just the face of the wheel or the entire wheel, front, back, bead area and all ? Is it single stage or did they clear the wheels ? You can PM me if you prefer rather than posting here. Again, I'm not trying to drum up work just see where I stand with my prices.
06-27-2011, 09:00 PM | #61 |
yeller
Kevin, no problem
For a 15" steel wheel, they TYPICALLY charge $100 per wheel. That includes media blast, and two coats of finish for the entire wheel (front/back/bead). Because I am a return customer (have had wheels, brackets, and valve covers done), they only charged me $75...and I got three coats on these (prime, color and clear). They do real good work and are nice guys, and are comparable to other shops in the area. Their turnaround time is about a week.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 06-27-2011 at 09:01 PM. |
06-27-2011, 09:03 PM | #62 | |
06-27-2011, 09:13 PM | #63 |
yeller
Are you pretty close to that? I really like the return customer discount, wish more places did that. Keeps business, and encourages word of mouth advertising. Regardless, I have seen your work, and wish you were closer to do mine.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 06-27-2011 at 09:14 PM. |
06-27-2011, 09:18 PM | #64 |
I'm at 60 for single stage, 90 for two stage for the entire wheel.
06-27-2011, 10:50 PM | #65 |
The only time I've seen a rally wheel like the one in the 2nd picture (with the raised areas) was a 6 lug rally wheel.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
06-27-2011, 11:07 PM | #66 |
A bit more on the wheels...
The wheels on my Gentleman Jim mount the center caps from the front. I have seen the rear mounted center caps, but I don't know what years they were offered. I'm confident the wheels on the Gentleman Jim are original since they are in the matching gold to the stripe on the truck. It would be nice to document when the changes from rear to front mounted center caps happened. I'm glad your wheels ended up fitting. I was really wondering how your hubs could be an odd size...
06-28-2011, 08:09 AM | #67 |
Looking at the GM parts book it appears the change was mid 77....
The early caps (C10) show as 359758 and 341430 Mid 77 changes to 469664 A note in the book mentions change in attachment The special retaining bolt for the late caps is also listed ....14003421 |
06-28-2011, 12:01 PM | #68 | |
Happy to be here
Glad to hear you got your mystery solved...
06-28-2011, 12:49 PM | #69 |
I've had a ton of these old trucks, and countless sets of rallye wheels, and I have never seen the caps mount from the back side. So do those caps not have holes all the way through? If anyone has some I would like to see a pic. Then I can say I saw them.
06-28-2011, 01:09 PM | #70 |
Right side of the picture. They were round instead of scalloped and had three threaded bungs in the back side. The holes did not extend through to the front of them.
06-28-2011, 05:39 PM | #71 |
Thanks TX, Those look like the police car caps. I guess I've never had a set of those. Dang learned something.
06-29-2011, 12:23 AM | #72 |
I'm going to say that the early caps probably had an issue with the bolt threads pulling out, so they were usually replaced with the revised caps.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
06-29-2011, 08:11 AM | #73 |
FYI: The 6,000 mile truck on ebay has the center caps that bolt from the back. I had a 71 cheyenne that had those as well.
http://cgi.ebay.com/ebaymotors/All-o...item2a11baf940 |
05-28-2019, 12:31 PM | #74 |
Dragging this back up and here is another visible difference between wheels. Note the inner ring on the rims. Painted pic is of ones with 1984 stamping and other is 1910. Ring is more pronounced on the painted wheels.
Life is too short to drive a boring vehicle. |
05-28-2019, 01:32 PM | #75 |
How many slots in the first wheel? Corker makes one with sixteen slots, my factory's only has 10. I can't tell by the pic but it looks like more then ten.
