01-22-2011, 10:43 AM | #26 |
low n' slo
Re: Best Paint for Rally Rims??
i really wanted to get these blasted but after checking over them they have a lot of nicks...so i figured i wouldnt waste the time or money getting the stripped. i just used a wire wheel are the rusted areas and nicks and around the lip, and then just used 80 grit to rough up the rest. then sprayed with self etching primer, 3 coats. gonna get them painted today and hopefully get the tires either today or monday.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-13-2011, 10:11 PM | #27 |
kinda late but might be useful to others reading this post...I had mine blasted and painted them with silver chassis saver
02-14-2011, 04:48 PM | #28 |
low n' slo
i think they turned out nice!
heres mine, painted with valspar tractor paint, high gloss, 2 coats. with a 215/70/15 whitewall tire..
04-22-2011, 12:39 PM | #29 |
The best results that I have found is the Mopar Argent Silver and then a clear coat!!
07-03-2011, 12:05 PM | #30 |
Do you sand/media blast the entire wheel, or just the front and or the back? Will paint around the rim where the bead seats cause any issues?
08-15-2011, 04:21 PM | #31 |
Farm Truck
Anyone use Eastwoods?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
08-30-2011, 03:27 AM | #32 |
so i used the rust-oleum hammered on some steelies and it turned out great they have held up nicely on my dd for the past 2 months
Uploaded with ImageShack.us |
09-01-2011, 10:24 PM | #33 |
Here is Eastwoods Argent Silver with a clear coat.
By claypool782 at 2011-08-01 By claypool782 at 2011-08-01 |
09-02-2011, 11:22 AM | #34 |
Moderator
Duplicolor silver wheel paint looks the same and holds up great, and is readily available.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-29-2011, 03:26 PM | #35 |
I had mine painted with Duplicolor rim paint with Duplicolor clear over it and it ended up looking like crap after a few years. Rust started coming up from under the paint so, my suggestion would be get em powdercoated. Most shops do it pretty cheap or, for the same amount, you can buy the HotCoat gun from Eastwood for $120 I think... and a old oven and you can powdercoat everything cheap!
My 2 cents Aloha!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
12-29-2011, 08:23 PM | #36 |
Redefining LowBudget
Hope this help But I just had 4 rims done for my dump truck ( 11x24 bud wheels) $35 each the color is stardust silve powder coat........most heavy truck shops can do them and they look great
they sand blast them x ray for cracks and powder coated..yep $35...Cheap!! |
12-30-2011, 05:08 PM | #37 | |
Moderator
01-13-2012, 01:35 PM | #38 |
Almost fifteen years ago, I had to replace a rim on my last truck, an '86 Suburban. I used Eastwood's argent silver to paint the rim- they come in black primer from GM. I drove it another 12 years and the paint was a perfect match, kept the same finish/shine as the others, and never flaked or peeled.
I'd give it two thumbs up!
Semper Paratus |
