#51 |
Momma Tried.
Re: Do's/Don'ts of Engine Cleaning (Tell us your experiences...)
Thanks dude. Any suggestions on my build would be great. Check out my thread.
Ross 1980 c10 4x4 project (Sold):http://67-72chevytrucks.com/vboard/s...d.php?t=377155 1999 F-150 4x4 (DD) Saving up for a 64 ![]() 17 and loving it. |
#52 |
'67 Chevy C-50
Since we're talking about do's and don'ts of engine cleaning, my experience tells me don't do it. Haha. But I know that doesnt help anyone. I detail at a dealership and we degrease and powerwash the engines, but if they don't run right after it's not my problem, it just goes back to the mechanics. And about half of them don't. Its always the older or high mileage ones. So I'm lead to believe that if you have good ignition parts-spark plug wires, etc. you'll be fine. Also my boss says always turn on the A/C if afterwords to dry the compressor. Otherwise it can rust inside overnite and ruin it. Dunno if its true, I just do what he says.
Bad Riv '67 C50 Flatbed Dump '98 Z71 Ext. Cab |
#53 |
Your right about the ignition parts. I have seen many a decent running cars brought to a stop from faulty/old ignition parts getting wet---more specifically spark pulg wires. A really good quality wire will save you some hassles. If its an OEM application on a daily driver, i always insist on factory wires. If you happen to drive a Mitsubishi, i can not stress enough to get a factory wire (coming from experience working in a dealerships).
About the A/C compressor---i feel its a good idea to run it, but its not because the compressor itself will rust away, its the fact the you can get rust buildup on the clutch of the compressor. So yea, run it and get the clutch dried out. If you have belt squeal, you can very carefully take a scotchbrite pad and lightly hold it to the inside of the belt while the engine is running. I can not stress the importance of being careful doing this so you dont get your hand caught in the pulleys/and/or mechanical fan. All your tring to do is deglaze the belt some. It might just save you from buying new belts if the old ones are still decent.
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 |
#54 | |
Blaze-Air
I'm trying to figure out if this stuff from Eastwood called pre paint prep is the same as carb cleaner as far as a prep for paint. http://www.eastwood.com/eastwood-pre-painting-prep.html I know carb cleaner is harsh stuff, and a lot cheaper than the Eastwood product. Carb cleaner is what lifted my paint to begin with when I was cleaning my intake. BUT, when carb cleaner dries does it leave the surface ready to paint, or primer, then paint? OR, should I just use simple green? My engine is already relatively clean, light light grease. Is the surface ready for paint after rinsing and drying with simple green? |
#55 | |
Watchin the rust grow
![]() Join Date: Oct 2008
![]() ![]() Well I got somewhere. It's hard to keep a truck clean when you live out "here" and with this melting snow....sometimes it's fun to throw some mud.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done ![]() 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
#56 |
Tot Roddin'
Progress is progress.... and I know all about gravel roads.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#57 |
DUNNEZ this stuff is AWESOME!!!!! Its A CONCENTRATE and you use straight on or dilute with water for different applications. My favorite part is it smells like cherry and is non-toxic, like you could take a bid swig and not worry about a thing. I personally have used it to clean oil off a motor block, degrease a commercial used deepfryer, use to clean the greasy floor, ink out of clothing, food stains out of a carpet and to clean windows. I LOVE THIS STUFF. And its pretty cheap. Dont be afraid to haggle with them.
dunnez.com |
#58 | |
![]() Dad's 1970 Chevy C10 Custom 350, auto, armstrong power windows and doorlocks "My carbon footprint is bigger than yours" ![]() ![]() |
#59 |
Blaze-Air
That's the mental picture I had when I read that remark, fingers flying.
#60 |
Moderator
![]() Join Date: May 2007
Simple green works great for clean up on an engine that is already relativley clean to begin with and touching up/maintainance. If you want to get 40 years of grease build up removed initially, POR Marine clean is the only way to go. It makes grease fall off like butter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#61 |
Hand Crafted C-10
![]() Join Date: Aug 2006
Glad you brought that up leddzepp.
Years ago, I had access to commercial bilge cleaner. The stuff works better than anything I've ever used for tough, caked-on grease. |
#62 |
Grandpa in the rustmobile...
can you pick up the amazing marine cleaner in parts stores or something? I vote for purple power..stuff worked wonders on my crappy engine bay made it better than it was...hopefully this summer it'll look GOOD.
what can I spray on my slotted wheels to clean that wont hurt em (too much time polishing to ruin em). And will they oxidize after polishing should I wax em up after??? thanks keep it commin'
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#63 | |
Moderator
I use purple power too, it is my second choice. I bought a 5 gallon bucket of it from Home Depot and that is what I use to soak parts in in a large tub. After parts sit in it a few days the same effect, grease falls off like butter.
#64 |
so vinegar or sandblasting, im on a budget but could afford the extra $ if its that much of a difference. I gota gallon of white vinegar but I dont think its gonna be enough...
So how many gallons of vinegar for 2 ram horn manifolds. or should i just blast em? and what should i paint it with?..
#65 |
ok i just pulled my motor I need some stuff you put on and it comes off like butter with garden hose...
what can i get at the parts stores/locally that works good getting oldnasty CRAP off?
#66 |
whats the best thing to clean rusty headers with
![]() ![]() '82 ![]() (Hot Rod) '90 ![]() (Daily Driver) '53 m38a1 Willys Jeep (Toy) |
#67 |
headers or exhaust manifolds
I dont know either one, may try wire brush (cheapest) but longest time taking...ll
#68 |
since i just spent 3hr under the hood polishing i figured i would chime in. i start off with simple green to get ride of any grime and to clean the firewall and fenders. next i use eagel one neverdul polish on all the chrome apply and let sit to a glaze and buff to shine with rag. for my billit i use maguires alum polish and a buffer to bring them to a shine. i also use tire spray not foam for the plastic pieces to give a shine a little goes a long way. why do we do it???
1972 ![]() my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=418015 |
#69 | |
Momma Tried.
#70 |
Tryin to resurrect an old thread here, was wonderin if any of yous have new methods/ new products to use?
#71 |
I just read through all the pages on this thread and it made me think of a cleaner degreaser I used years ago called SLAM its not the same as another cleaner out there called grandslam. anyways this stuff worked great spray it on and hose it off and if you let it set for a bit it would take most heavy grease off so I started looking for it and found it its made by a comany in stockton ca
http://www.goestores.com/storename/p...care/home.aspx they make a lot of cleaning and detailing supplys if you click on cleaners you'll find it and it isnt cheep but you delute it with water 5 gallons lasted me for about 3yrs and I wash and detail a lot of cars and I used it to clean alot of other stuff
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#72 |
![]() Join Date: May 2009
Pig Rig witch one was it? I didn't see anything called Slam on the link...Vernski
#73 |
![]() Join Date: Feb 2011
I'll be getting some of the simple green and see how it works on the 44 years of build up dirt, grease and oil in this engine bay. I'll post before and after pics and what was done once complete, but for now - only before pics.
Brad 67 Chevy SWB stepside - http://67-72chevytrucks.com/vboard/s...d.php?t=449426 89 Ford Bronco 92 Suzuki Sidekick 94 Kawasaki Vulcan 750 06 Honda Aquatrax |
#74 |
![]() Join Date: Jul 2009
Does simple green or purple power take off firewall markings? I am going to clean 40 years of oil off my engine bay and would like to keep the firewall markings
#75 |
![]() Join Date: Jun 2006
THE best oil remover I have ever used is called Oil Eater but the first thing I would do is find a place renting a steam cleaner not a pressure washer. Cover the Dist. and Alt. with plastic bags and completely bag your carb or FI. Next raise the vehicle off the ground with ramps or if at home jack stands and go for it. After that you will probably need a couple good scrapers lots of rubber gloves and eyewear and scrape off what didn't come of with the steam. Get some Easy Off oven cleaner and hammer that on, let it work then resteam clean.
