Old 06-14-2011, 01:14 PM   #51
Pro Performance
Pro Performance's Avatar
Re: 84 C10 Project
I just measured it using the rear bed mounting bolt as a reference point. It looks like this will clear that bed brace by 1/4"! Just barely made it.
Pro Performance is offline   Reply With Quote
Old 06-14-2011, 03:22 PM   #52
luifer76
luifer76's Avatar
Re: 84 C10 Project
truck is looking really good man and its gonna look just right with that drop like the renderings......keep up the good work bro and keep the pics coming....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 06-14-2011, 04:22 PM   #53
Pro Performance
Re: 84 C10 Project
Thanks for the words.... I was always worried it might not get low enough without changing the crossmember, but I like the more "hot rod" stance, so I think it will be alright. Do you have a build page for yours?
Old 06-14-2011, 05:56 PM   #54
luifer76
luifer76's Avatar
Re: 84 C10 Project
yep check out my 73 c10 project......
Old 06-27-2011, 09:36 AM   #55
Pro Performance
Re: 84 C10 Project
Got some more work done on it this weekend. Still have to mount the VIAIR compressors. But half the frame is painted.
Old 06-27-2011, 11:16 AM   #56
Cherub
Cherub's Avatar
Re: 84 C10 Project
looking good. I was planning on doing the same notch on my suburban
Cherub is offline   Reply With Quote
Old 06-27-2011, 11:27 AM   #57
Pro Performance
Re: 84 C10 Project
I liked the notch. The frame is straight in that section so it fit well, and it is only $39.
Old 06-28-2011, 12:20 AM   #58
Pro Performance
Re: 84 C10 Project
Here is how the tanks will be mounted.
Old 06-28-2011, 02:25 AM   #59
luifer76
luifer76's Avatar
Re: 84 C10 Project
looking good man keep up the good work.....
Old 07-08-2011, 12:07 PM   #60
Pro Performance
Re: 84 C10 Project
Got the rear suspension back together and everything painted. Just have to paint the driveshaft, and the rear backing plates and drums. It is getting there though, and i am impressed with the Eastwood Chassis Black.
Old 07-08-2011, 07:29 PM   #61
luifer76
luifer76's Avatar
Re: 84 C10 Project
nice and clean work bro....you may have allready covered this but what size of valves and lines are you gonna be running?
Old 07-08-2011, 07:57 PM   #62
Pro Performance
Re: 84 C10 Project
I am running 3/8" valves with 3/8" air line. Ordering them next week, and probably end up going with SMC's.
Old 07-08-2011, 07:58 PM   #63
luifer76
luifer76's Avatar
Re: 84 C10 Project
good choice bro....
Old 07-10-2011, 11:48 PM   #64
maxxxy
maxxxy's Avatar
Re: 84 C10 Project
Nice build man. Did you say you used eastwood something to paint your frame? Where did you get it? and What did you like/dislike about using it?
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 07-11-2011, 09:38 AM   #65
Pro Performance
Re: 84 C10 Project
I used Eastwood Extreme Chassis Black. I don't have any dislikes, other that the cost. It works really well, and bonds well to the metal. I used their primer as well, but I am sure it works equally as well with another brand of good primer.
http://www.eastwood.com/extreme-chas...inish-set.html
Old 07-11-2011, 06:10 PM   #66
Pro Performance
Re: 84 C10 Project
Just ordered valves. I ended up using ASCO 3/8" valves, which is what Macs Springs recommended.
I am hoping to have them installed by this weekend, and the bed back on.
Old 07-12-2011, 12:04 AM   #67
luifer76
luifer76's Avatar
Re: 84 C10 Project
cool.... ASCO are good valves post some pics of the set up once you mount them...
Old 07-12-2011, 12:56 PM   #68
Pro Performance
Re: 84 C10 Project
Will do.....
I also worked on another rendering idea last night. Let me know what you guys think. Not quite as bright, but very clean and simple looking. Which I like.
Old 07-12-2011, 01:38 PM   #69
kikkegek
kikkegek's Avatar
Re: 84 C10 Project
sick! go for it!
kikkegek is offline   Reply With Quote
Old 07-12-2011, 10:30 PM   #70
Pro Performance
Re: 84 C10 Project
I kind of got an idea of where I want to mount my 2 compressors. The leader hose is a little bit of a stretch but I think it will work.
Tanks mounted in:
Old 07-12-2011, 11:36 PM   #71
maxxxy
maxxxy's Avatar
Re: 84 C10 Project
I like the newest rendering a lot. But I think it might look better with the brushed wheels.
Max
Max's bagged 81
Old 07-20-2011, 10:27 PM   #72
Pro Performance
Re: 84 C10 Project
Made a lot of progress in the last couple days. Got the gas tank and brackets cleaned up, and the picture shows the gas tank half painted, but it is done now. I Painted the frame rail underneath the cab, and under coated the bottom side of the cab. I also removed the tranny crossmember, and and painting that now also.
Old 07-21-2011, 12:24 AM   #73
luifer76
luifer76's Avatar
Re: 84 C10 Project
Will do.....
this rendering looks bad ass bro....
Old 07-21-2011, 12:26 AM   #74
luifer76
luifer76's Avatar
Re: 84 C10 Project
good progress in the last couple days....i like the way you set up the air tanks and the gas tank looks like new.....
Old 07-25-2011, 09:52 AM   #75
Pro Performance
Re: 84 C10 Project
Got the bed on this weekend, but like some of you thought, the cross member I added on top of the frame, does hit the be floor. So now, I think I am going to put a small raised section in there for the rear center to clear better, and the cross member. I really don't want to re-do the cross member on top of the frame and cut that our of there.
