hj,
I just replaced all the steering components in my 4x4. My advice to you is to have someone jiggle the wheel back and forth while you watch the box, pitman arm, and tie rod ends. You'll be able to tell pretty easily where the play is. Then you can get a better idea of how much it's going to cost you. New tie rod ends run about $25 apiece, new pitman arm can be found for $40 or so. Those are the most likely to go. My pitman arm was causing 90% of my play. Steering box can be bought for $180 or so, but I doubt that's the real problem. Labor would be pretty expensive, I would imagine. I did all mine myself. GM parts would also be more expensive. Hope this helps.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
