Old 08-04-2003, 01:57 AM   #1
jasonrog
jasonrog's Avatar
700r4 users
For those of you who have put a 700r4 with a quadrajet, what tv cable mount did you use?
Jason
jasonrog is offline   Reply With Quote
Old 08-04-2003, 06:01 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
When I was carburated I used one from Jeg's or Summit
here is the ad in summits site.
http://store.summitracing.com/defaul...+cable+bracket
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 08-04-2003, 08:09 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Any mid 80s Chevy truck with a Q-jet and 700 should work. There a billions of them in the junkyards. Just look for a pre 87 (EFI) truck with the overdrive PRNDLL thing on the dash.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-04-2003, 09:36 AM   #4
Custom 68
Custom 68's Avatar
Bobby what do you use now with the TPI?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-04-2003, 10:43 AM   #5
ckhd
ckhd's Avatar
I got a thing from Bowtie Overdrives that adapted my carb to work with the TV cable. Has to have the right linkage on the carb though...
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-04-2003, 11:11 AM   #6
jasonrog
jasonrog's Avatar
How do I tell if my carb has the right linkage or not?
Old 08-04-2003, 11:28 AM   #7
iluvmy72
boneyard time
go to the bone yard......look for an early 80's chevy sedans and wagons I find great parts on the capriece and malibu's and ofton the chevy vans
iluvmy72 is offline   Reply With Quote
Old 08-04-2003, 01:20 PM   #8
bigvinnie
bigvinnie's Avatar
The one in BobbyK's post is the one I'm using with my QJet... I think I got mine from Summit...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 08-04-2003, 03:23 PM   #9
jasonrog
jasonrog's Avatar
So would anything from a rear wheel drive and quadrajet work? As long as it was a 700 or 200 trans?
Old 08-04-2003, 06:41 PM   #10
BobbyK
BobbyK's Avatar
Custom 68
I use the stock mount that comes on the TPI air plenum.
Old 08-04-2003, 09:02 PM   #11
Don Smith
I used TV cable P/N 25515598 and Bracket P/N 22504927. Bracket has cutouts for Accel. cable and TV cable. Looks factory.
Both are available from GM . Bracket mounts to two rear bolts on Carb.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
