Old 07-16-2011, 04:53 PM   #1
72gmcshorty
72gmcshorty's Avatar
Center link rubbing crossmember
1972 2wd. Why is my center link rubbing my crossmember? I had the crossmember off to clean and sandblast. I also replaced the pitman and idler arms. Now the link is rubbing against the front of the crossmember. I can't remember if there is some adjustment in the crossmember itself or if i got the wrong pitman/idlers.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 07-16-2011, 05:04 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Center link rubbing crossmember
Is it in backwards? Nuts for the tie rods face front. Pics may help.
Dunenutt is offline   Reply With Quote
Old 07-16-2011, 05:05 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Sounds like it is in backwards.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-16-2011, 06:33 PM   #4
72gmcshorty
tie rod nuts are facing the front....are the holes on the crossmember slotted for adjustment? I don't think the frame holes are slotted...
1992 Gmc 2wd
Old 07-16-2011, 06:38 PM   #5
Dunenutt
Newbee
Dunenutt's Avatar
if the upper a-arm bolt holes in the frame lined up, I would say it has to be the pittman/idler arms then.
Old 07-16-2011, 09:38 PM   #6
72gmcshorty
Sorry, I should have said we had the front suspension completely torn apart. Now that its all together, the center link rubs the crossmember at the driver side and has about 1/8" clearance at the passenger side of crossmember. Looking at it, the pitman and idler arms are the only thing that controls where the center link sits.
1992 Gmc 2wd
Old 07-16-2011, 10:07 PM   #7
Boog
laying low
Boog's Avatar
There are different part numbers for standard and power steering parts from 67-72 and 73 up. There is no adjustment for the crossmember so your prob is in the new parts you've used. I suggest check the part numbers and applications where you bought them.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-17-2011, 11:38 AM   #8
72gmcshorty
i got all the parts from Early classic in their rebuild kit. Would the fact that i have dropped spindles be a problem?
1992 Gmc 2wd
Old 07-17-2011, 11:38 AM   #9
72gmcshorty
* Could a mod please move this thread to the suspension forum *
1992 Gmc 2wd
Old 07-17-2011, 12:12 PM   #10
SCOTI
SCOTI's Avatar
Take some pics of your set-up & post them. This will prob help identify any potential issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-19-2011, 06:47 PM   #11
72gmcshorty
you can see in the one pic that the bar angles toward the driver side of the cross member
1992 Gmc 2wd
Old 07-19-2011, 07:47 PM   #12
Lee H
Lee H's Avatar
My pitman arm measures 5 1/4 center to center.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-20-2011, 08:27 AM   #13
72gmcshorty
anything looking out of place?
1992 Gmc 2wd
Old 07-20-2011, 01:09 PM   #14
SCOTI
SCOTI's Avatar
The drag-link should be parallel all the way across. Something is either tweaked or is the incorrect length.
If there's no indication of either frame rail being hit & all the idler mounting holes look correct, I would focus on the parts that are new. Since these parts were replaced, it's possible the length of one or the other isn't correct.
Also, you mentioned the x-member was removed for clean-up. While the holes don't allow for a lot of play, I do recall there is some there. I would check the x-member to make sure it's square within the rails. Some simple diagonal measurements from fixed points on the rails to similar points on the x-member should give you an idea.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2011, 02:09 PM   #15
ADub
Chiming in...I have a similar problem on my 69, except my center link rubs all the way across. No new parts, no damaged frame. I gave up on mine a while back.
69 C10 SWB LY6 T56
70 Chevelle SS 396 4spd
ADub is offline   Reply With Quote
Old 07-20-2011, 02:16 PM   #16
SCOTI
SCOTI's Avatar
If it rubs all the way across, it's usually installed backwards (an easy mistake). Which direction are the castle nuts that secure the tie-rods to the center-link facing (to the front or rear)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2011, 02:18 PM   #17
ADub
Nope, its installed in the correct orientation
69 C10 SWB LY6 T56
Old 07-20-2011, 02:34 PM   #18
SCOTI
SCOTI's Avatar
Something has been changed then. They don't rub from the factory so something has been changed along the way or removed/re-installed incorrectly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2011, 03:29 PM   #19
ADub
Heres my thread when I looked into the issue
http://67-72chevytrucks.com/vboard/s...d.php?t=438119
Truck is still that way as I gave up. I purchased a new frame that I have modified and will be swapping the body and suspension over to eventually. That frame had manual steering installed and did not have the rubbing issue.
69 C10 SWB LY6 T56
Old 07-20-2011, 06:56 PM   #20
72gmcshorty
is there a pic of how it's supposed to look? How much gap is there supposed to be between the center link and the cross member?
1992 Gmc 2wd
Old 07-20-2011, 07:02 PM   #21
SCOTI
SCOTI's Avatar
About .500" or so gap.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2011, 07:15 PM   #22
72gmcshorty
is 5 1/4" the correct center to center distance for the pitman arm?
1992 Gmc 2wd
Old 07-20-2011, 07:55 PM   #23
Lee H
Lee H's Avatar
What does you pitman measure? That is the measurement on my 72 with power steering. Just trying to give you something to look at.
Old 07-20-2011, 08:35 PM   #24
72gmcshorty
my truck is at the bodyman's. Just trying to get all the info before i go there.
1992 Gmc 2wd
Old 07-20-2011, 09:32 PM   #25
ADub
on my rolling frame with manual steering it was about a 1/4"
69 C10 SWB LY6 T56
