07-16-2011, 04:53 PM | #1 |
Center link rubbing crossmember
1972 2wd. Why is my center link rubbing my crossmember? I had the crossmember off to clean and sandblast. I also replaced the pitman and idler arms. Now the link is rubbing against the front of the crossmember. I can't remember if there is some adjustment in the crossmember itself or if i got the wrong pitman/idlers.
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
07-16-2011, 05:04 PM | #2 |
Newbee
Re: Center link rubbing crossmember
Is it in backwards? Nuts for the tie rods face front. Pics may help.
07-16-2011, 05:05 PM | #3 |
Moderator
Sounds like it is in backwards.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-16-2011, 06:33 PM | #4 |
tie rod nuts are facing the front....are the holes on the crossmember slotted for adjustment? I don't think the frame holes are slotted...
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 07-16-2011 at 06:41 PM. |
07-16-2011, 06:38 PM | #5 |
Newbee
if the upper a-arm bolt holes in the frame lined up, I would say it has to be the pittman/idler arms then.
07-16-2011, 09:38 PM | #6 |
Sorry, I should have said we had the front suspension completely torn apart. Now that its all together, the center link rubs the crossmember at the driver side and has about 1/8" clearance at the passenger side of crossmember. Looking at it, the pitman and idler arms are the only thing that controls where the center link sits.
07-16-2011, 10:07 PM | #7 |
laying low
There are different part numbers for standard and power steering parts from 67-72 and 73 up. There is no adjustment for the crossmember so your prob is in the new parts you've used. I suggest check the part numbers and applications where you bought them.
07-17-2011, 11:38 AM | #8 |
i got all the parts from Early classic in their rebuild kit. Would the fact that i have dropped spindles be a problem?
07-17-2011, 11:38 AM | #9 |
* Could a mod please move this thread to the suspension forum *
07-17-2011, 12:12 PM | #10 |
Take some pics of your set-up & post them. This will prob help identify any potential issues.
07-19-2011, 06:47 PM | #11 |
you can see in the one pic that the bar angles toward the driver side of the cross member
07-19-2011, 07:47 PM | #12 |
My pitman arm measures 5 1/4 center to center.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-20-2011, 08:27 AM | #13 |
anything looking out of place?
07-20-2011, 01:09 PM | #14 |
The drag-link should be parallel all the way across. Something is either tweaked or is the incorrect length.
If there's no indication of either frame rail being hit & all the idler mounting holes look correct, I would focus on the parts that are new. Since these parts were replaced, it's possible the length of one or the other isn't correct. Also, you mentioned the x-member was removed for clean-up. While the holes don't allow for a lot of play, I do recall there is some there. I would check the x-member to make sure it's square within the rails. Some simple diagonal measurements from fixed points on the rails to similar points on the x-member should give you an idea.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-20-2011 at 01:14 PM. |
07-20-2011, 02:09 PM | #15 |
Chiming in...I have a similar problem on my 69, except my center link rubs all the way across. No new parts, no damaged frame. I gave up on mine a while back.
69 C10 SWB LY6 T56 70 Chevelle SS 396 4spd |
07-20-2011, 02:16 PM | #16 |
If it rubs all the way across, it's usually installed backwards (an easy mistake). Which direction are the castle nuts that secure the tie-rods to the center-link facing (to the front or rear)?
07-20-2011, 02:18 PM | #17 |
Nope, its installed in the correct orientation
07-20-2011, 02:34 PM | #18 |
Something has been changed then. They don't rub from the factory so something has been changed along the way or removed/re-installed incorrectly.
07-20-2011, 03:29 PM | #19 |
Heres my thread when I looked into the issue
http://67-72chevytrucks.com/vboard/s...d.php?t=438119 Truck is still that way as I gave up. I purchased a new frame that I have modified and will be swapping the body and suspension over to eventually. That frame had manual steering installed and did not have the rubbing issue.
07-20-2011, 06:56 PM | #20 |
is there a pic of how it's supposed to look? How much gap is there supposed to be between the center link and the cross member?
07-20-2011, 07:02 PM | #21 |
About .500" or so gap.
07-20-2011, 07:15 PM | #22 |
is 5 1/4" the correct center to center distance for the pitman arm?
07-20-2011, 07:55 PM | #23 |
What does you pitman measure? That is the measurement on my 72 with power steering. Just trying to give you something to look at.
07-20-2011, 08:35 PM | #24 |
my truck is at the bodyman's. Just trying to get all the info before i go there.
07-20-2011, 09:32 PM | #25 |
on my rolling frame with manual steering it was about a 1/4"
