70 power steering swap
Hey guys I have a 70 c10 Lwb I have converted the front brakes to disc from a 71 setup now I'm considering up dating the steering I'm trying to decide wether I should just replace the sloppy manual box or upgrade it to a power unit. My main question is what all I need to change I know I would have to add a power steering pump and a power steering box but would I have to change the column or will a ps box bolt right up? And would I need to change any of the front suspension will the pitman arm ect... Thanks I'm advance for any advice
Posted via Mobile Device |
Re: 70 power steering swap
mine already came with a ps box. but im 99% sure it will bolt up to your steering column. no problem there. just make sure you get the correct ps pump. and the installation is a breeze. you dont need to make any adjustments what so ever. POWER STEERING is so much better. =)
PS pitman arm is different than the manual pitman arm.
Dano
![]() ![]() It ain't yours, if you didn't build it! |
Hey guys thanks for the info I had a feeling it would be pretty much a bolt up but I wanted to check first
