Old 01-04-2011, 06:22 PM   #76
Kokomoooo
Re: Should I leave the Fuel Tank in the Cab?
Putting mine under the bed. My Dad constantly moaned about my gas tank being in the cab, I found out a couple weeks ago after I told him that I'm reloacting it that he saw two people burn to death in a chevy truck like mine.
As far as drivers air bag, I would if I knew how, but I am considering putting a roll bar behind the seat for side impact protection, and adding a 5 point harness.
Kokomoooo is offline   Reply With Quote
Old 07-31-2011, 02:33 AM   #77
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by lakeroadster View Post
The best location, based on crash testing, is between the frame rails, in front of the rear axle.
Unfortunately that is tough to do, especially on "truck arm" suspensions like ours.
I've thought about there also, but was concern about if the drive shaft came flying loose.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-31-2011, 03:18 AM   #78
Grimpala
Grimpala's Avatar
Originally Posted by Bad70sbchevy View Post
I moved mine and I love it. I did it at first for safety reasons since its my daily driver and thats the last thing I want to have behind the seat in a crash. I did notice a major improvement in ride quality once I put mine in the back. Also like mentioned before you will get some added traction in the rear. If you do change gas tanks, I highly reccomend using a 1969 Camaro gas tank if you do want to change yours to the rear. It lets you hide the filler neck behind the license plate (no holes in the bed), the fuel sender works with the gas guage, and it does not hang down hardly at all compared to the Blazer tank conversion (Also its cheaper than the blazer tank).
Along those same lines, has anyone looked at using a tank from a 94 = 96 B body car (caprice, impala, roadmaster) They are poly, hold 23 gallons and have aa rear mounted filler neck that could be used with a flip down license plate.
Grimpala is offline   Reply With Quote
Old 07-31-2011, 05:41 AM   #79
67chevy1series
67chevy1series's Avatar
KEEP IT IN SO ITS NOT GETTING WEATHERED lol
67chevy1series is offline   Reply With Quote
Old 07-31-2011, 08:51 AM   #80
stich626
I'm in the middle of moving mine..
I did it because mine was leaking and I want somewhere to put some tools and them to be out of sight...
I also don't like the idea of fuel behind me,, and track time.. if it was a sealed system and the gas cap couldn't be knocked off in a wreck.. then maybe it stay..
but moving it. gets me weight over th e rear wheels and room for a tool box and some extra parts a jack and lug wrench.. and two side speakers
stich626 is offline   Reply With Quote
Old 07-31-2011, 08:54 AM   #81
Steve Hafner
Steve Hafner's Avatar
I'm keeping mine in the cab. I figure, if ten gallons of gas goes BOOM, I'll die just about seven tenths of a second later then if it had been moved to the rear. Since there is room, a lot of todays front wheel drive cars have the tank in front of or over the rear axle for that same reason . . . and don't forget the . . . P I N T O !!!!
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 07-31-2011, 11:14 AM   #82
Red68
Red68's Avatar
This is an interesting thread, for all of the trucks I have seen with the tanks relocated under the bed on the board and in magazines, mine included, the general consensus is to leave it behind the seat!!
I moved mine under the bed first with a poly tank and tried to use the marker light for a fill location, did not work well for me. Then I had an alum tank made and installed a filler in the bed floor. Worked much better, and as others have said gave me room for a sub behind the seat and a little storage room.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 07-31-2011, 05:30 PM   #83
1972RedNeck
1972RedNeck's Avatar
Originally Posted by 72lb4x4 View Post
Just for perspective, the 73-87 side tanks are also considered unsafe. So in the cab, in the back, and on the side are all unsafe.
Where should the tank be?
We should all drive electric cars
Originally Posted by RBC67 View Post
seriously, if the sloshing bothers you, your exhaust is to quiet....
I like the gas filler where it was from the factory, I think it"s cool! Either way, it is an old truck and that is awesome.
I am going to leave the tank in the cab and put one in the rear and maybe one on each side too. Here in Montana you have to drive 100+ miles to get to a Walmart (YEE HAW!!) and at 8 MPG I can't even make it on 1 tank. I'd like to be able to hold at least 80 gallons.
Didn't some Internationals have the filler neck right in front of the door? Where were those tanks located at?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-31-2011, 10:31 PM   #84
ls1nova71
ls1nova71's Avatar
Well that pic puts a real damper on my idea of the Pinto gas tank mod. Was thinking of cutting the rear frame rails out completley, and just putting a roll pan behind it to protect it. Gonna have to go back to the drawing board....
When I read this, it came out as "I'd like to be able to have a $300 fill up"
ls1nova71 is offline   Reply With Quote
Old 12-21-2011, 02:26 AM   #85
LostMy65
LostMy65's Avatar
I'm currently searching the forums to find if anyone has done that.
I found this for an older truck:
Old 12-21-2011, 03:09 AM   #86
Bad70sbchevy
Bad70sbchevy's Avatar
Well there's an easy way to accomplish that, just bolt a fuel cell in the bed. The only thing that sucks is you lose the use of a bed, but you do get the pro street look.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 12-21-2011, 06:26 AM   #87
xb9rguy
xb9rguy's Avatar
I keep going back and forth on this too and my main reason was for leg room but after reading this ya I won't gain any no matter where the tank is since the head rests already touch the rear window lol. And as far as smell goes I love the smell of gas I just wish I could smell it, and the sound of sloshing I agree can't hear it over the exhaust. As far as safety you can never predict where you may or may not get hit so if that is the death of me at least I will die happily in my good old truck! Glad I found this thread cuz now I will definitely keep it in the cab and save the money and time for something else that it needs like heater controls and a million other little things.
Jeramy
CURRENTLY OWN,
72 c10 project/driver
2010 Kia Forte Koup SX daily driver
88 cherokee wheeler and dog hauler
2001 drz 400
Miss my 2004 firebolt (stock) and 2001 superhawk with a ton of modifications and many other previous vehicles.
xb9rguy is offline   Reply With Quote
Old 12-21-2011, 10:25 AM   #88
aventur1
aventur1's Avatar
Where can you find those card board covers for the gas tank?
aventur1 is offline   Reply With Quote
Old 12-21-2011, 10:53 AM   #89
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
Originally Posted by rbagley View Post
If your pickup were to end up on its side somehow the gas cap would get yanked off and gas would spill out and probably all over the driver. If you were sliding and generating sparks there would probably be a good chance of becoming dead.
lol well said!
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=242380
Sequoyah is offline   Reply With Quote
Old 12-21-2011, 11:21 AM   #90
WAAF
everyone is focused on the boom..
how many are scared crapless of the big C???
they didn't move the tanks in 73 because of fire hazzard... it was because of lung cancer.. from fuel... not the boom.. truck goes boom .people die..
people get sick.. they can sue..
WAAF is offline   Reply With Quote
Old 12-21-2011, 11:52 AM   #91
no moa
no moa's Avatar
I'll probably move mine for the space behind the seat, and my spare as someone said will be AAA.
I've seen one of these trucks on its side, gas pouring out (plow truck) he didn't get hurt, but it spilled about all of it in the tank freaked him out, so he put and outbard tank in the back to plow the driveway/road. lol
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 12-21-2011, 11:55 AM   #92
leddzepp
Moderator
leddzepp's Avatar
Here we go again...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-21-2011, 11:57 AM   #93
no moa
no moa's Avatar
I know its been awhile, but i saw this thread. The tank is poly, but it also has a bladder in it. i actually have a tank out and am going to see if it will fit between the frame rails, but i think its to wide. when i look closer at it last weekend.
I'll post up pics if it works.
Old 12-21-2011, 01:19 PM   #94
domeier
domeier's Avatar
If I had some money, I'd move mine out for the safety factor. But then again... the biggest safety problem in these trucks is no shoulder belts and and non-collapsing steering column. I guess I probably won't care about fire when the steering wheel is already shoved through my chest.
domeier is offline   Reply With Quote
Old 12-21-2011, 04:51 PM   #95
Gobbles
Gobbles's Avatar
I moved mine, I considered the safety factor for a little bit but then went back to welding! Anyway, I moved mine so that i can have some dry storage space, that's basically it. I couldn't hear the sloshing because the BBC was TOO LOUD!!
Also, as for lung cancer, don't the vents do a good enough job to make any damage negligible? I mean we breath the exhaust all day every day, I can't image the little bit of vapor in the truck causing much/any damage. Just a thought, no actual facts.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 12-21-2011, 09:34 PM   #96
domeier
domeier's Avatar
If you light up a cigarette, you can't smell the gas and get cancer.
Old 12-21-2011, 09:36 PM   #97
72chevyk10
I built it
72chevyk10's Avatar
thats terrible but funny
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 12-21-2011, 09:52 PM   #98
pat 70/71
pat 70/71's Avatar
I changed the location to under the bed on all three of my trucks mostly because of the safety factor & the vent line that runs over the cab on the cali trucks just plan stinks up the cab. plus I like the way the trucks look without the filler cap on the cab. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 12-22-2011, 01:30 AM   #99
ItsRandy
ItsRandy's Avatar
I like this thread...very entertaining, reading everyone's opinion. So, here's my opinion: Getting the gas tank out of the passenger compartment and as far away from the passengers as you can has got to be safer than having the gas tank inside where the passengers are. Moving the tank to the back may expose it to rear end collisions (rear end collisions are more common than side impact or head-on collisions), however, it is relatively far away from the passengers, the bed of the truck is covering it up and you have the back wall of the truck cab protecting you from the splash/spray of gas and possible fire. Let's face it, no matter how hard you work building safety into your old truck, a meteor is gonna' come smashing through the roof of your truck to ruin your day. I moved my gas tank to the back to move some of the weight, it's aluminium and let's not forget...it looks cool, really cool.
ItsRandy is offline   Reply With Quote
Old 12-30-2011, 05:24 PM   #100
David67
David67's Avatar
Originally Posted by leddzepp View Post
Here we go again...
What have I done
Mines staying in the cab!
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
