Old 08-07-2011, 10:46 AM   #176
SOON2BLAZE
SOON2BLAZE's Avatar
Re: Project: NO-LIFE,...
Looks great!
SOON2BLAZE is offline   Reply With Quote
Old 08-07-2011, 12:05 PM   #177
Painter D
Painter D's Avatar
Nice progress
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 08-07-2011, 05:30 PM   #178
CheyenneShop
CheyenneShop's Avatar
Good to know on the Brothers floor covering - as I have thought about getting one before - Love the Red carpet - so it all works out
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 08-07-2011, 09:04 PM   #179
lowdownstar
big guy
lowdownstar's Avatar
Keith
Looking really nice my friend, I love the red carpet adds a touch of class!
Ray
lowdownstar is offline   Reply With Quote
Old 08-07-2011, 10:08 PM   #180
lolife99
67-72 parts collector,…
lolife99's Avatar
I bought a NICE new floor mat from Tim Christian.
It is an exact replica of the original floor mat.
It will be going in my stepside.
Keith
Convert to disc brakes.
Old 08-07-2011, 10:09 PM   #181
lolife99
lolife99's Avatar
Originally Posted by lowdownstar View Post
Keith
Ray
Thanks Ray.
Hope you are doing good.
Any new projects???
Keith
Old 08-07-2011, 10:17 PM   #182
lolife99
lolife99's Avatar
I worked most of the day and didn't make much progress.
I cleaned the grease covered trans crossmember and painted it.
Removed an exhaust hanger and found out the doughnut gasket at the manifold is shot.
Started to install the TH350.
I have ALOT of distance between the new converter and the original powerglide 153 tooth flexplate.
(3/8"-1/2",... just guessing,... but that's too much)
So I dropped the trans back out.
I'm not sure what's going on.
I checked NAPA's websited and they show a 168 tooth flexplate for $87,... so I'm going to try that.
(that means a new starter)
I bought an assortment of moulding clips to fix a few pieces of loose trim.
Got the upper tailgate and one lower trim piece secured,... but I got the wrong clips for the upper bed side mouldings.
Gotta make another order now.
Keith
Old 08-07-2011, 10:43 PM   #183
mcbassin
Still Learning
mcbassin's Avatar
That crossmember turned out great. So, what's the deal the powerglide takes a different flexplate? I didn't know that. Keep up the hard work.
Old 08-07-2011, 10:55 PM   #184
lolife99
lolife99's Avatar
The crossmember took a couple hours to get clean enough to paint.
The grease was an inch thick on that thing.
I get sidetracked with painting sometimes,... when it doesn't really matter.
The powerglide takes a smaller flexplate.
NAPA only carries the 168 tooth 14" flexplate for the 292.
I have a stock SBC flexplate,... but it won't work.
The 292 has 1/2" crank bolts. (SBC has 7/16")
Plus the 292 flexplate has 3 locating dowels,... the SBC has only 1.
Keith
Old 08-07-2011, 11:01 PM   #185
m6z
m6z's Avatar
I used 10 "nutserts" to hold the new cover in place.
These are great for attaching a nut to a blind hole.
I'm going to steal that idea. I just used self tapping screws on mine. Didn't really want to, just wasn't sure how else to do it.
What size nutserts did you use?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 08-07-2011, 11:17 PM   #186
lolife99
lolife99's Avatar
I used 5/16".
(the drilled hole size it a little bigger than 1/2")
Plenty of room for my incorrect drilling. Ha.
Plus you can use some old "washer head" fender bolts to hold it in.
Keith
Old 08-07-2011, 11:45 PM   #187
VA72C10
VA72C10
VA72C10's Avatar
very nice work on the interior!!!
Old 08-07-2011, 11:46 PM   #188
SCOTI
SCOTI's Avatar
My brother from a different mother..... Tell me about it. I scubbed & scrubbed the splash shields for the front brakes on the dually. Prob spent 1hr on each one getting them clean & smooth enough to shoot w/a rattle can & not look like crap.
Did I mention that was on both the spindle side & rotor side. Yesterday it was the th400 (including the inside the bellhousing where the input shaft is)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-08-2011, 12:16 AM   #189
CheyenneShop
Sweet - I will check it out. Thanks again
72 3/4 long 4X4
69 SWB "Prospector"
Old 08-08-2011, 12:22 AM   #190
lolife99
lolife99's Avatar
I agree.
I watch the clock, and wonder where the day went.
(that's where a giant blast cabinet would come in handy)
My TH350 needs a repaint.
These tranny shops think rattle can over the 3 layers already on there, will be good enough.
I decided to not repaint it.
I'm going to pull the 292 someday for a rebuild.
(I'll detail the tranny then)
Right now I just want to get it "road worthy".
Keith
Old 08-08-2011, 06:11 AM   #191
n2billet
Village Idiot....
n2billet's Avatar
Great progress! You'll be happy you went through all this pain once you get behind the wheel.......
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 08-08-2011, 07:47 AM   #192
72BlckButy
Tot Roddin'
72BlckButy's Avatar
... on your way to KS.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-08-2011, 09:38 AM   #193
tommyd241
tommyd241's Avatar
The carpet looks great!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 08-08-2011, 06:37 PM   #194
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I feel the pain with both you guys, I spent 5 hours on saturday and 4 hours sunday clearing 2 wheels. I've been working on these 2 off and on since june, only on weekends though. I still have 2 more to prime, paint and clear. It looks like it'll be january before I finish them.
Keith, I'm jealous!! Both your truck are what I strive for when I'm finished with mine. I'm just too limited on garage space. Keep up the great work.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 08-08-2011, 08:57 PM   #195
gringoloco
A guy with a truck
gringoloco's Avatar
...I scubbed & scrubbed the splash shields for the front brakes on the dually. Prob spent 1hr on each one...
Been there. I think I had at least an hour in each. No one knows but me- and they'll just get dirty again
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-09-2011, 12:02 AM   #196
Meatman
Meatman's Avatar
Dont let him fool you guys. He says paint looks bad but I think its perfect. Ive been to his place before to buy a bed for buddys truck and got to ogle and drool all his trucks and stuff. Paint on no life has perfect patina.
Good progress Keith, trucks looking awesome.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 08-11-2011, 07:31 PM   #197
72BlckButy
Tot Roddin'
72BlckButy's Avatar
The truck looks good.
-Nate
Old 08-13-2011, 09:29 PM   #198
lolife99
lolife99's Avatar
Small update.
My new TH350 is finally in.
Had to buy a new flexplate and starter to make this work with my 292.
Also my new flexplate only had the "big" converter bolt pattern.
I had purchased a stock converter with my new trans.
The TH350 converters have the "small" pattern.
Lucky for me,... the guys at the trans shop swapped it out for a TH400 converter with the big pattern.
If you need a transmission in central Missouri,... check out these guys.
(http://mandmtransmission.com/)
Spent last night hooking up all the little things.
Today I installed the radiator, hoses, pulley, fan, belts and the fan shroud.
(does anyone know if the 292 trucks had a 6-cylinder specific fan shroud?)
Doesn't sound like much,... but it was a long day.
Also bent up a new modulator vacuum line.
(The 5' stick of 1/4" steel line was about 2" short. Ha.)
I wish I had time to paint the engine up nice,... but I'm trying to get this truck running for the Kansas Goodguys event at the end of the month.
I think all the steel lines would look better, if they were black.
Here's a few pics,...
Keith
Old 08-13-2011, 10:07 PM   #199
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good Keith!
Once KS is over, I agree with you, the lines will look good in black.
-Nate
Old 08-13-2011, 11:13 PM   #200
n2billet
Village Idiot....
n2billet's Avatar
Detail the motor and the lines will look right at home......
