![]() Join Date: Jul 2010
Universal side molding
Has anyone ever used the universal side molding they sell at JC Whitney?
I was thinking of putting the lower molding on since I don't have the dough for a "real" kit. I'm not really trying to stay orginal, I just don't want something that looks cheap. Thanks for the help. |
the boat guy
Re: Universal side molding
it looks cheap. Factory stuff or nothing imho.
![]() Join Date: May 2007
Save your $ for the real thing. You'll be glad you did!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Thanks for the input guys. Does anyone have any picture of trucks with the universal trim? Also, where can I get the best deal on factory stuff? How easy is the factory stuff to install? Mine doesn't have any trim on it now, so it would be a fresh install with no holes. Thanks again for the input.
This suburban is in Truck of The Month it appears to be universal stick-on moulding.... looks good in these pics..I'd like some more info from guys on what they are using and pics.
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 |
That looks pretty good to me. I was actually thinking about the same style trim. Keep the pictures coming.
I'd say if you can obtain the kind of results shown in the pics, go for it. The thin lower universal makes the truck look leaner. The stock lower trim on 69&ups is kinda chubby.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
I think the stuff at JC Whitney will look like what it is, cheap, cheap, cheap..... I think a good quality stick on is the way to go for a nice looking, simple and clean driver. It's also easy on the budget. I used molding from Trim-Gard, lots of choices and proce was not bad.
I used a stick on upper and will use stick on to replace the lower, by the time I polish, replace woodgrain, buy clips and everyhting it would cost way more to use oem. If anyone wants to buy a full set of driver quality molding and go through the pain I have it.... |
#9 | |
Thanks for the info I will check out trim-gard. What do you plan on using for the lower? Do yo have a picture of what you did with the upper? |
Grandpa in the rustmobile...
Salvage junkyard trim....?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
http://www.autoamenity.com/Body-Mold...UV-Molding.htm
*Mods sorry if I'm not supposed to post links?? I am not affiliated with this palce in anyway just something I found. here is what I found that I am thinking of using they offer alot of GM type of trim and different sizes that will work and look similar to stock. ![]() bottom molding I was thinking of using it is 2 & 1/4 width ![]() or this one which is more textured looking in the middle ![]() then this one for the top it is available in different widths this stuff looks closer to the stock one because it is chrome on the outside and blk on the inside.
#12 | |
