Old 09-02-2011, 04:26 AM   #26
OARNGESI
OARNGESI's Avatar
Re: what seats did you put in your 67-72 Chevy truck ?
Just an idea but the 2000-05 deville has some really comfortable seats its a bench seat with built in armrest and cupholders leather heated and full power plus there realitively low i bet theyed be perfect in one of these trucks plus i seen them at junkyards cheap
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 09-02-2011, 06:29 AM   #27
taank
05 silverado seats in mine. It's tight with the factory big wheel and no tilt.
taank is offline   Reply With Quote
Old 09-02-2011, 10:43 AM   #28
Tmwoodall
Like these?
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 09-02-2011, 11:14 AM   #29
pops45
Junior Member
pops45's Avatar
Got this middle seat out of a 93 Suburban. Cut the brackets down to lower the seat and drilled and re-enforced the floor. The seat bottoms pull up for storage underneath.
pops45 is offline   Reply With Quote
Old 09-02-2011, 11:53 AM   #30
yunkyarddog
yunkyarddog's Avatar
dirty and nothin fanzy 84 c10 but wuts best its i found it like it is and my local pull and save
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 09-02-2011, 03:00 PM   #31
Tmwoodall
I like those a lot. Bench-ish but comfort of buckets. How are they for a long drive? Do you happen to have a picture from the back? I'd like to see how much they stick up above the glass. Also do you have enough room to be comfortable in there? I have a big frame at 6'1" 220lbs.
Seems like these are what you have, no?
Old 09-02-2011, 03:40 PM   #32
From a 90 Chevy C1500. No longer in the truck, but looking for another 90-94 seat to use since I was stupid enough to get rid of the seat.
Old 09-02-2011, 03:49 PM   #33
Tmwoodall
Ha I just gave one of those away with a parts truck.
Old 09-02-2011, 05:30 PM   #34
67C10BUB
67C10BUB's Avatar
Mine are out of a 2003 Avalanche.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 09-02-2011, 05:54 PM   #35
Andy4639
Old member
Andy4639's Avatar
Wink Re: what seats did you put in your 67-72 Chevy truck ?
60-40 out of a 1989 Chevy 1500.
No cutting just braced the underside of the floor and drilled new holes.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-02-2011, 08:40 PM   #36
pops45
Junior Member
pops45's Avatar
Yep that one looks the same. Check around as you can probably get a better deal and condition seat. I cut the brackets down but its still a little high for me and I'm only 5'6". I'm trying to keep the seat bottom pull up feature and the backs also fold forward, so I don't want to hack them all up. Also passenger side slides forward on a track so heighth is hard to adjust to keep it matched up to the driver side.
I haven't really done any long drives bit they are comfy around town. I think I'm going to shorten the steering column as the wheel is still too close, and I'm kinda anal about getting it perfect
I'll get some better pics.
Old 09-02-2011, 10:09 PM   #37
Tmwoodall
Awesome. I'd love a few more pics. I love looks of a bench but want some bolsters. Looks like this is a nice happy medium. I had an 05 f150 and the seats were super comfy but with no bolstering the only thing keeping me in my seat in a corner was my grip on the wheel. I'd like to avoid that in a truck that will be tons faster and tossed into corners more than that one ever was.
Old 09-03-2011, 04:24 AM   #38
mikey531
mikey531's Avatar
Check post # 19
mikey531 is offline   Reply With Quote
Old 09-03-2011, 05:54 AM   #39
OARNGESI
OARNGESI's Avatar
Like these?
yes if there the right width theyd feel perfect
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 09-03-2011, 02:23 PM   #40
pops45
Junior Member
pops45's Avatar
More pics. It is a center seat form a 95-99 Suburban.
Old 09-04-2011, 02:31 PM   #41
Brock
upgrading to an older model
Brock's Avatar
Mine are a whole lot like Classic69's except yellow and black. I built a frame to mount the seats on (out if 1 1/4" square tubing) bolts to original seat mounting holes. For belts i went with PEAK racing harnesses. The lap belts use the original seat belt holes. I took removed the gas tank, cut a peice of 1 1/4" square tubing that went all the way across the cab, mounted the bolts for the shoulder straps then bolted the bar to the top mounting holes from the where the gas tank was mounted.
I tried to take some pictures but my camera is screwed up...I got one decent one but then I gave up on the pics and just took a video
68 stepside, short-box, multi-colored (for now)
Brock is offline   Reply With Quote
Old 09-08-2011, 06:53 PM   #42
howard_m18
howard_m18's Avatar
We put in 2002 Mustang buckets with the driver seat is powered. Can't move very far backwards,though. Howard
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI.
howard_m18 is offline   Reply With Quote
Old 01-27-2013, 11:42 PM   #43
montgeeze
I found someone in town selling 70's Camaro seats. I was worried about height as I just bought them but they look awesome! When it's closer to finished I'll get some leather seat covers for her and that'll be all she wrote!
montgeeze is offline   Reply With Quote
Old 02-22-2013, 11:18 PM   #44
mortoyz
Active Member
I picked up my seats from the upholstery shop today. These seats are out of a 2011 chevy truck. We cut them down about 4 1/2 inches, they should sit right at the bottom of the window.
mortoyz is offline   Reply With Quote
Old 02-22-2013, 11:25 PM   #45
buckskins4ever
buckskins4ever's Avatar
99 f150 40/20/40 split bench........drill holes...gives nice fit and very soft seat.
buckskins4ever is offline   Reply With Quote
Old 02-23-2013, 12:19 AM   #46
67_ShortFleet
67_ShortFleet's Avatar
They look great!
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 02-23-2013, 07:40 PM   #47
54belair
54belair's Avatar
These are the seats Ive decided to put in mine. They are black leather trailblazer seats. Both are power and heated.
I dont have them yet (still in transit) so I have no idea about fabbing the mounts. (supposedly they are relatively easy to install)--We'll see.
** I have since received the seats and they Will take some fabbing on the inside rails (outside rail is at least 2 in. higher) No hill for a stepper!!!!
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 03-13-2013, 02:16 AM   #48
FrankenCub
FrankenCub's Avatar
Love the different options seen here ! My stock bench is in really good shape but not so good on a messed up back. I like the newer Chevy seats with built in seat belts, really easy install. Also really want something with the head rests. I was in an accident quite a few years back, my ex and I were stopped waiting for traffic to clear and got rear ended by someone doing 65 (according to the investigating sheriff). The only reason our heads didn't go through the back window is a gun rack with my shotgun in it, our heads hit the gun. The rack did push the top of the window out about 3/4 inch though. The head rests may not look as clean but they sure are much safer. Something to think about ...
FrankenCub is offline   Reply With Quote
Old 03-20-2013, 06:33 PM   #49
nuke82
nuke82's Avatar
I just picked mine up from a local salvage out of a 2005 Silverado, the whole package for only $250. They are mint for 05, just need to clean the pop off from the wreck. The drivers seat is electric. Hopefully it's an easy install.
nuke82 is offline   Reply With Quote
Old 03-20-2013, 06:47 PM   #50
mikey531
mikey531's Avatar
Nuke82
They are real simple to install I used the holes in the middle to bolt the console and seat then marked the other holes and drilled those. You will want to reinforce under the bolts and I shimmed the back of the track with front end alignment shims so the seat would travel back. Let me know if i can be any more help
