Old 09-04-2011, 07:05 PM   #51
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Re: 68' Chevy c10
Sanded the firewall, and painted it. hoping to have my motor primed and painted tomorrow.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 09-04-2011, 08:24 PM   #52
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
Looks good!
Old 09-05-2011, 11:22 PM   #53
XxCHEVYMANxX
Re: 68' Chevy c10
finally painted the block/heads. still have to do oil pan, water neck, brackets etc... the last pic without camera flash looks closest to true color.
John
Facebook LoL
Old 09-06-2011, 12:14 AM   #54
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
Nice progress. That looks really good. Is it the duplicolor engine paint or something else? Orange or red-orange chevy color?
Old 09-06-2011, 08:14 AM   #55
XxCHEVYMANxX
Re: 68' Chevy c10
Thanks VA72C10, It is Dupli-color engine paint Chevy Orange.
John
Facebook LoL
Old 09-06-2011, 08:54 AM   #56
Pop's C-10
Pop's C-10's Avatar
Re: 68' Chevy c10
nice work sofar & is that a F-body i see..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-06-2011, 09:08 AM   #57
XxCHEVYMANxX
Re: 68' Chevy c10
Thanks Pop's, yeah thats the wifes 77' T/A. I can hear her now "when are you going to work on my car?"
John
Facebook LoL
Old 09-06-2011, 12:30 PM   #58
72SWBChevy
72SWBChevy's Avatar
Re: 68' Chevy c10
Looking good!!
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 09-06-2011, 12:38 PM   #59
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
cool, that's what I have to use on mine. Combined with extreme temp black for the ram horns and will match the valve covers and brackets in black.
Old 09-06-2011, 06:54 PM   #60
XxCHEVYMANxX
Re: 68' Chevy c10
Thats gonna look nice VA72C10, I'm doing pulleys,and brackets in black also.
I said in the post w/engine pics that the last pic shows true color better. not so, it looks closer to the pic of the block. I used all duplicolor, primer, chevy orange, and high temp clear.
John
Facebook LoL
Old 09-06-2011, 09:01 PM   #61
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
The prep is what made the difference....then having primer and the clear...definitely looks better than a lot of the spray bomb jobs I've seen!
I was going to run without the clear, but seeing it made me decide to add it on.
Old 09-06-2011, 11:10 PM   #62
XxCHEVYMANxX
Re: 68' Chevy c10
Yeah, the clear adds more depth to the color, plus the added protection.
heres some more parts.
John
Facebook LoL
Old 09-06-2011, 11:28 PM   #63
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
Those parts look great! Mine won't be quite as nice in my current truck because I'm not going to pull the engine. Probably will take off the carb and detail it and take off the accessories and do new belts and paint the brackets separate, but the block and intake and oil pan will all be together....
Old 09-07-2011, 12:01 AM   #64
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: 68' Chevy c10
lol i [painted it all together!
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 09-07-2011, 09:14 PM   #65
XxCHEVYMANxX
Re: 68' Chevy c10
I would paint it all together to if I was'nt taking the motor out or apart. it will still look really good. like you said VA72C10 it all in the prep. y'all know the drill, clean,clean, clean. tape off or cover what does'nt get paint, and it'll look 10 times better.
I got a couple pic of the motor being built.
John
Facebook LoL
Old 09-08-2011, 07:46 PM   #66
XxCHEVYMANxX
Re: 68' Chevy c10
got the grill blasted.
and fan clutch.
then painted fan clutch with flat clear.
a couple pulleys and upper radiator mounts.
could'nt get the stains off the intake, so its getting painted chevy orange.
John
Facebook LoL
Old 09-08-2011, 08:02 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
Looks good. So do you blast them yourself or have somewhere you take them?
Have you seen n2billet's engine? I'm going to mimic mine roughly after his.....
what are your plans for valve covers and air cleaner?
Old 09-08-2011, 09:19 PM   #68
XxCHEVYMANxX
Re: 68' Chevy c10
Thanks. I take the big parts to a local place. I do the small stuff, and that motor is awesome! I'll have to check out n2billet's build. As far as air cleaner I have one of those edlebrock triangle style. for valve covers I would like to have some vintage finned aluminum. right now I have some new chrome cheapos.
I just dug this out.
fan got blasted and painted too.
John
Facebook LoL
Old 09-08-2011, 10:23 PM   #69
heeroyue2002
fat old dude
Re: 68' Chevy c10
those triangle ones will set your truck on fire!
Old 09-09-2011, 12:27 AM   #70
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
If it's the mesh top style with the gray foam insert the definitely can....
...if it's a standard style element with a triangular lid and base then it'll be fine...
Old 09-09-2011, 01:34 AM   #71
heeroyue2002
fat old dude
Re: 68' Chevy c10
those are the ones i meant. foam =]
Old 09-09-2011, 08:18 AM   #72
XxCHEVYMANxX
Re: 68' Chevy c10
Thanks for the heads up. I did'nt know that. Ok plan B for the air cleaner.
So what happens, does the foam combust from a backfire?
John
Facebook LoL
Old 09-09-2011, 03:22 PM   #73
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
yep...I've seen it happen before...in my 80Z28....thankfully I was working on the carb settings at that moment and had a rag I threw on top and put it out...I quickly took the filter off and put the factory air cleaner back on until I had the cash to buy another air cleaner...
Old 09-09-2011, 06:19 PM   #74
XxCHEVYMANxX
Re: 68' Chevy c10
Had a chance to stop by my mechanic's, and snap a few pics of assembly.
he's cool like that.
John
Facebook LoL
Old 09-09-2011, 06:22 PM   #75
XxCHEVYMANxX
Re: 68' Chevy c10
A couple more.
John
Facebook LoL
68 chevy, c10 2wd fleetside
