09-02-2011, 10:57 PM | #101 |
Re: 2 for 1, My son's first Square Build
Hey guys if yall need some help I am just around the corner from you. Just give me a holla. Live on McDade place. on the left with the grey shop in the back.
09-09-2011, 12:53 PM | #102 |
Oh, cool! i like your blazer, i'm soooo jealous of your shop
"As I walk through the valley of rice i fear no honda, for i have torque!" |
09-09-2011, 03:47 PM | #103 |
Stop by anytime would be glad to meet you and show you around.
10-08-2011, 04:26 PM | #104 |
one of my first mig welds We have gotten alot done since my last post, we got the cab off, the rear x member off, the front xmember off, we cut a buncha little mounts that were riveted to the frame, and have decided to raise the front x member 1.5 inches into the frame, drop spindles, drop springs in the front. in the rear i am gonna do a flip kit and maybe take a leaf out. i really want a sport bumper in the rear but if i can't find 1 for a good price then a roll pan is goin on. i can't decide between american eagle 225s or ridler 695s in grey, both in 20x8.5 in front and 20x10 in rear, big brakes all the way around, red paint, now i'm gettin ahead of myself. once we cut the c notch and raise the front xmember its gettin sandblasted and painted.
10-08-2011, 05:45 PM | #105 |
Cool project, Get the Eagle 225s and paint them gray! Would look awesome!
10-08-2011, 06:19 PM | #106 |
Drag Racer
You can find a NOS GM sport bumper at www.classicparts.com. I bought one from them and have been very pleased with it. Even came in an original GM stickered box! How much total drop are you looking to get? Can't wait to see your truck come together more!
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
10-09-2011, 01:56 PM | #107 |
i am going for a 5/6 or 7 drop i forgot to mention that in the rear i will probably do a lowering hanger too. hopefully get the frame cut today for the x member
10-09-2011, 05:15 PM | #108 |
We started the notching of the front frame to raise the crossmember 1.5".
There is every thing marked out. We are going to remove the section between the upper and lower tape lines. All cut out... That's me cutting the 1.5" wide piece from the section we took out. We cleaned up the cuts and put a bevel on both sides for the weld. We had to stop here since I have to go to a student council meeting this afternoon. I might get to work on it more after the meeting since we do not have school tomorrow.
10-09-2011, 10:13 PM | #109 |
me gettin ready to weld
me welding grinding down some tack welds will try to finish tommorow, i have to put a filler plat in and grind down some welds, because the xmember bracket has to sit flush, more pics to come tommorw. i really love welding.
10-09-2011, 10:17 PM | #110 |
http://www.classicparts.com/1973-80-...info/65-071RC/
is that the bumper you got prostreet? if so, can you get some pics?
10-09-2011, 10:26 PM | #111 |
1 thing at a time is progress.
Nice progress. Welds look nice as well.
Alan
Philippians 2:14-16 |
10-10-2011, 09:30 AM | #112 |
I'm just glad to be here!
Korbin has been taking a metal shop class at school. I set up the heat and wire speed for him and walked him thru where to weld. He did all the welding once I had the parts tacked into place. His welding is really good for such a youngster only doing stick welding for about 4 weeks. Looks like he might make a good fabricator some day.
We made good progess this weekend and hope to finish the front section this week. Then on to the back.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
10-10-2011, 09:32 AM | #113 |
I looked at the bumper link. That is the wrong year model for you.
You need: 1981-87) * Bumper-Rear-Chrome-Fleetside/Suburban/Blazer Product : 65-072RC
10-10-2011, 12:56 PM | #114 |
O, woops, just noticed that.
10-10-2011, 03:58 PM | #115 |
It's much easier to fabricate when you have 10 fingers to work with. Get some leather/cowhide work gloves on when you're working w/sharp tools (esp cut off wheels). This was after it cut through my leather glove. No glove on & I would have cut my thumb off....
10-10-2011, 05:07 PM | #116 |
Be careful Korbin. A cool truck is not worth getting hurt for. You've made a lot of progress this weekend, but slow down some and stay safe.
10-10-2011, 05:28 PM | #117 |
Thanks SCOTI, and mr. kilgore, we are stayin safe, it took us a while for us to do all of that. Actually, dad cut himself when he picked up a peice of sharp metal, then about 10 min later, i did the same exact thing, neither of em were bad enough for stitches, but still a reminder.
10-10-2011, 05:49 PM | #118 |
I aggree with Scoti and Mr Kilgore. I should not have let Korbin do that without gloves. I personally do not like wearing gloves when using rotating tools, but the cut off wheel is an exception. The other major thing that was wrong with the grinder set up is the lack of the guard around half the wheel. We were using the only wheel I had left which was a little larger in diameter. I stocked up on more of the correct wheels now for when we get to the rear.
Tonight we plan to weld in the plates to finish boxing in the notch area and grinding the outside of the frame smooth. He will have to have his chores and room clean before we start...
10-10-2011, 08:31 PM | #119 |
That truck is going to be awesome! It's cool when a kid builds his own truck and have it when he starts driving. It will be a nice truck when it's done. Looking forward to seeing it all done
I wanted to build my own Chevy k10 so bad when I was younger and have it to drive when i got my license, but I couldn't find a good enough deal!!!
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
10-11-2011, 12:34 AM | #120 |
Wow, keep up the awesome work and grades!
stone sends... 78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201) 06 Dodge Charger Daytona R/T 05 Suzuki GSX-R 1000 |
10-11-2011, 11:03 PM | #121 |
Didn't get a whole lot done today, lotta homework, ill keep yall updated
10-13-2011, 06:06 PM | #122 |
Great project!
I used 4wd leaf springs along with perches I made to flip the axle for some extra drop.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
10-13-2011, 07:38 PM | #123 |
what do 4wd leafs do?
on another note, has anyone ever had kfc's double down? its sooooo good.
10-13-2011, 07:59 PM | #124 |
The 4wd leafs have less arch than the 2wds do so they give you some extra drop, maybe 2-3 more inches. There is a picture of the springs sitting on top of each other in my build thread.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now Last edited by Conundrum; 10-13-2011 at 08:08 PM. |
11-13-2011, 08:57 PM | #125 |
Got the cab cleaned out!
cleanin up the leaves for paint when the frame is finished the cab, bed and frame and all body panels will be sent off to bet sandblasted. then paint
Tags |
project, son, square body |
